Question about Saeco Vienna Espresso Machine
Saeco vienna deluxe espresso machine
When I push the bottom for a cup of coffee I hear the grinding but no coffee comes out. The grounds feel a little wet when they are dumped so some water is getting to them but not emought water is being pumped through to get any coffee. Same thing here.  I push the button, I hear it grind, no coffe comes out, and it dumps the grinds which are wet.
  • 1 more comment
  • ilovecoffe Oct 04, 2008
    I have the same problem. Machine dispenses no coffee, but grounds seem hot and mildly damp. Additionally, I cannot get steam from the steamer wand. Ran it and began to smell motor burning aroma so shut the machine off. I opened the machine hoping that it would be easily resolve from cleaning out plastic tubes but cant locate where blocking may be located.
  • Andrew Battistella
    Andrew Battistella Jan 31, 2014
    What is the glass ball for? Does it sit under the spring?
    Hi @Dale Parsons , are you able to help?
Clean the ball and valve assembly located in the Brew Group. It ocassionally gets "dirty" and needs cleaning. Be careful you don't lose the glass ball which is very small. Use a q-tip or small wire for cleaning the tubular area.
Posted on Jan 27, 2009
I have a Saeco Vienna Delux, coffee is being grinded but it is not making its way out. I removed the nozzle which divides coffee into 2 but a few drops are coming out. what can i do?
Hi
I think this will help you.
There are a couple of things on a delux that can cause this.
Your grind is to fine ( the big knob in the bean hopper is below 8. If it is turn the big knob to a larger number. You can turn the big knob any time but it has to be grinding to turn it to a smaller number. 3 cycles before it has changed the grind in the brew unit. You can push the button to stop so you don't have to wait for it to finish. If that is not it go to the next solution.
http://www.fixya.com/support/r9150937-vienna_not_make_coffee_or_very_slow
May 07, 2011 | Saeco Vienna De Luxe Espresso Machine
My Saeco Vienna at times seems to extract a cup of coffee extremely slowly (drips out). The next cup will come out at a normal rate. I've tried the grind at various settings, but the problem remains. Any...
HI You might need new burrs. When the burrs get dull, they will crush the beans instead of grinding them into small grounds. You start to get powder instead of grinds. They will slow the extraction, but then the next time they will produce the correct shot.
Feb 19, 2010 | Saeco Vienna De Luxe Espresso Machine
Red warning light comes on in my saeco vienna deluxe I just aquired this unit and to date have not been able to make a cup of coffee. All the green lights light up and coffee starts grinding but after that...
Hi
More than likely your grind is to fine and you are using oily beans (shiney). There is a small knob in the bean hopper. turn it down to the minus side. Turn the big knob to the # 18. If that doesn't work you are going to have to take the grinder apart and clean it.
Jan 07, 2010 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna. Wet cofffee grinds in the dump box.
It could be the grind on the coffee or the red group o-ring and the 2 o-rings on the white plastic valve need to be replaced.
Nov 05, 2009 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna grinds too much coffee.
Hi
If you have the Delux or Digital there are 2 knobs in the bean hopper. Turn the small knob back 1 mark and see if that will help.
Jul 12, 2009 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna Deluxe leaking problem and grinder problem
I would repair it, it sounds like the grinder needs to be adjusted (burrs may be dull), and the leak on the bottom may be coming from the small drain hole on the back of the brew chamber. If you remo;ve the chamber you will see the white water valve that the chamber connect to, if you look below the white valve the small chamber in there will be filled with water, below that there is a small discharge use a stit stick or paper clip to clear hole.
May 07, 2009 | Saeco Vienna De Luxe Espresso Machine
Diverting all of the coffee flow into the bottom tray rather than the cup.
You might want to check and clean the coffee outflow spout ( the adjustable double spout on the outside of the machine) . If it is all plucked up that might be the cause.
Sep 09, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna Delux Expresso Maker
Try to descale the machine, also try to set the grinding to little more coarse.
Aug 22, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna Deluxe odd burning smell
gears are probably broke. Happens when to much coffee and coffee ground too fine get compacted into the brew drive unit.
Shreds the plastic gears like butter.
Machine has to be sent out for service, gear replacement is long and impossible for anyone untrained. Trained techs it takes at least an hour if not more.
Apr 21, 2008 | Saeco Vienna De Luxe Espresso Machine
adjust the water flow look for a knob that turn right to left minus less water plus more water
Jun 08, 2007 | Saeco Vienna Espresso Machine
Saeco Vienna Espresso Machine Logo
319 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
