Question about Motorola Mobility RAZR V3
Power on Problems
When I push the red power on button the keys flash on and off and nothing else happens. No water or drops when it started.
    Scholar:
  • 87 Answers
Sounds like your battery is dead. Does the phone respond when you plug in the charger? If it does not respond, you may either have damage in the charging port, or a bad charger. If the phone recognizes the charger, shows that it is charging, but still won't work when you unplug it, I would recommend trying a new battery. You should be able to go to a retail store that sells razr's and ask them to try a different battery in the phone to see if it works. If it powers on with the new battery, buy it.
Posted on Sep 18, 2008
The Dryer won't start. Power light just flashes red on and off
There are too many problems that it could be, anything from the Button going bad, to the Door Shut Switch being defective, to the Motor, Relay inside the circuit board, to loose wire during the move, and the list goes on and on. Unless you can test each component that sends the START signal, nobody will be able to assist you with the information you have provided.
Mar 01, 2014 | Hotpoint Ariston AWD129 Front Load...
When I turn on the coffee machine flashing red button calcing. and 'put in a container for water descaling solution., when I hold the button for more than 5 seconds nothing happens.
push it for 5 second and if its still flashing doesn't matter turn the steam knob anti-clockwise end let the machine do to the descaling cyrcle, when then water tank emptied the rest of buttons starts to flashing, turn the knob off and your machine is ready!!
Jan 12, 2014 | Gaggia Syncrony Compact Coffee...
Zanussi zwf 1430s,power going to machine but when button pressed green light does not come on just a red light nothing on display panel
Count how many times the red light flashes and how many the green light flashes.If its 1 green and 1 red thats water problems.If 2 flashes of red light check filter is clear and pump is free to turn.
Hope this helped.
May 18, 2010 | Washing Machines
When the power button the red button flashes but nothing else hap
the red light flashing means the set is in auto shut down, could be a power supply problem or a convergence IC problem. tech should first check all diodes and caps in power supply then replace convergence IC's
Jan 11, 2009 | Panasonic PT-53WX42 53" Rear Projection...
It wont turn on
Sounds like water damage but try this......... 1) press the * and # and Power button all at once - if the screen fires up with a black screen and some info - then you can flash the phone and hopefully recover it; 2. If the above works - you need to find a flash file and the software to flash it with Good Luck
Aug 01, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Dual MXD55 W/6/5 SP CD Problems
make sure the speaker grounds are connected to the speaker ground wires on the deck and not the "chassis" ground. also make sure both power wires are hooked up to a power source. the thinner power wire is supposed to be a switched source (like the ignition key or an accessory switch) that turns the unit on and the thicker one is a constant source which actually powers the deck once the switched source is turned on.
Jul 01, 2007 | Dual MXD55 AM/FM/CD/Weather Receiver
Filter light still on "Red"
try holding ice type and child lock together for 3 seconds that worked on mine
Mar 30, 2007 | Maytag MSD2454G Side by Side Refrigerator
Motorola Mobility RAZR V3 Logo
59 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
