Question about Dishwashers
I have GE Madellion 870 Washing machine I guess I have motor problem motor stopr after smoke Now Motor spins for few second then stops after 15~ 20 minutes, it will run again for few seconds if my motor burnrd then why it still runs for few seconds
  • Anonymous Mar 31, 2014
    Motor running but the machine will not spinn
  • 750 Answers
Hello ashankhan,
huuum,happy to assist you!
You said,
motor stops after smoke
if my motor burned then why it still runs for few seconds.
The motor is shot and it still works until it heats up, and then it binds up after it over heats!
How old is the appliance?
If the appliance is 10 years old or more you may not be advisable to put good money into bad! New appliances are so much more efficient today that they can save you a lot of money in energy.
Therefore they pay for them selves in only a few years.
You can buy New and save today.
Find the small privately owned and operated appliance store and you will get better service and good treatment! They also will be the best informed!
Bless You, let me know how it goes.
huuum
Please give me a good rating for my fine advice before you sign off.
Thank You
Posted on Sep 18, 2008
How to fix my Ge washer THAT SPINS SLOWLY AND DOES NOT DRAIN CLOTHES COMPLETELY.The clothes are still wet at the end of the cycle.
Wild guess, It's Out of balance, as a result, it's smart enough to stop spinning. To check, try to rebalance. Maybe overloaded. Remove clothes but fill with water and see if it will spin out. Second guess, belt drive on the bottom of the machine is worn, or belt tensioner is off or bad bearing. Also, possible the motor has a problem and shuts down because it's overheating a bit. If this is the case, though unlikely you will need a service man, but not cheap. If it's an old machine you might consider a replacement.
Dec 21, 2014 | GE Washing Machines
Samnsung Front Load washer; stopped spinning/agitating and smoke billowed out at end of cycle. Now washer will fill, but not agitate/spin or turn at all. Drum spins smoothly by hand. I'm guessing moto
the DC motors seldom go out but the motor control panel can and a burning oder/smoke would be consistent. I would expect a service technician would have to diagnose. This can get expensive.
Oct 20, 2014 | Samsung WF218AN Front Load Washer
My washing machine is turning 1 turn left than stop,turn 1 turn right and stop,when spinning : start and stop every few seconds.
This is probably a motor/board issue if you want to supply make/model number I can advise on how to test the motor with a multimeter
Apr 12, 2014 | Washing Machines
My washing machine trips the electric
take out the plug
remove the motor
now clean it ??
check the brushes or replace them if worn
or if you do not do this a new motor will be needed
as the motor safety switch will get blown
Feb 03, 2014 | Bosch Washing Machines
GE profile top loader, agitator and spin start and stop
Is this a newer model washer? I have one of the newer models and it does the same thing. It is supposed to do that.
May 23, 2017 | GE Profile Prodigy WPSE4200A
Machine fills with water, sits for a couple of minutes, agitates for 15-30 seconds, stops for 3-5 min. agitates for 15-30 secs etc... When rinsing, empties water starts to spin, kicks into high gear for a...
Your motor/clutch combo is on the way out. The motor is overheating and turning off. Cools down and restarts.
You need a new motor/clutch combo or a new washer. I do not recommend another GE.
Jul 07, 2009 | GE Washing Machines
GE Wizard Top-Load Washer - Burning Smell
sounds like an over heated motor. motors tend to do that before finially hitting a brick wall. please e-mail me for any other assistance. good luck :)
Jul 07, 2009 | Washing Machines
G.E. spacemaker washer will not spin
possible faulty motor. Regards Advisor
Aug 22, 2007 | GE WSKS2060WWH Top Load Washer
Open Questions:
Brand new dishwasher will not finish washing, it just beeps and the lights flash red - CANDY CDP 1L39W/K I have a brand new Candy dishwasher model CDP 1L39W/K that won't finish it's wash cycle. When I do P5 for a fast 5minute cycle I hear the dishwasher fill up, it begins to wash, and then after it drains the water, then the dishwasher begins beeping repeatedly and flashing the red light under the P5 setting. When I check the detergent slot it hasn't been used yet. When I select a long wash like P3 the same thing happens after it drains the water, so I think the error occurs after the first rinse cycle? When I push down reset all the lights flash and then blink sequentially just like the dishwasher is waiting for a new cycle input, but the water pump to drain the water never turns off. If I push the power button the unit turns off but the water pump keeps running. Only when I disconnect the power cord from the wall will the pump turn off. If I reconnect the power cord the pump turns back on sometimes. I read online that maybe the flood switch was hit and to tilt the unit and drain water, I took off the kick panel and didn't see any water, and tilted the unit back and forth as instructed. The first time I tried this I think it may have helped the water pump turn off after I reconnected the power cord. But when I ran a cycle again nothing changed. I also waited a few days afterwards because I was busy at work enough time for any water to dry up but this didn't help. I'm in Vietnam and the customer support is Vietnamese so I thought I would try this before I have to see about the warranty and shipping the unit far north for repair. Any help is really appreciated, I can post a video of the beeping, blinking lights, and water pump running after I unplug the unit it'd help. I so badly want this dishwasher to just work, it was a big purchase here and a lot people don't understand why I'd buy it so now that it's not working it's really embarrassing! Thanks again!
Jan 22, 2018 | Candy Dishwashers
Dishwashers Logo
74 people viewed this question
Top Dishwashers Experts
