Question about Polaroid FLM-323B Television
Noise coming from power supply
Whenever the tv is on, it makes a constant buzzing noise and the picture flickers.
When we turn our TV the humming and buzzing begins! We cn mute it and it goes away and then it when we turn the sound back on the sound is back! How can we fix this?
Posted on Oct 14, 2008
    Problem Solver:
  • 5 Answers
I can fix
Posted on Sep 25, 2008
Rca led32b30rq pictures flickers
This is the common problem with this model of RCA TV, the problem is not defective LED strips, but the power supply.
You may purchase a power supply on the net, but you can't guaranty that it is a good one.
This is the trick to make this TV work:
On the power supply, locate the R410 100K resister, solder a 220K/0.125W resistor in parallel with it, this will race up the oscillation frequency of the back light power supply circuit & make the voltage stable.
It is not a proper service procedure, but it works for us.
Jul 06, 2014 | RCA Televison & Video
My kdl52xbr2 blinks to a black screen constantly every 5-10 seconds or so. Screen goes black for about one sec, then back to the picture. It continually does this throughout the time we're watching tv. ...
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
May 01, 2011 | Sony BRAVIA KDL52XBR2 Television
I turn the tv on and there is a constant buzzing sound what is it?
Hello
If the picture is correct in all resepect, and only a buzzing sound only comes from its inside circuit, it will be due to a loose core fittings, on any one or two ferrite cored transformers inside the power supply sytem. There are transformeres of small and large types, both in power supply and other boards. We have to find out which transformer makes this buzz sound during working. For this, you have to open your TV, and power it ON, and listen the the sound carefully, and detect the transformer which makes this noise. After finding the exact one, this loose core contact can be fixed with the help of Super Glue or similar fast acting adhesive. Just put three or four drops of adhesive in between the core will rectify your problem.
If there is no picture at all and a buzzing sound like this is heard from your TV, the inside circuit has some short in it and has to be detected and rectified. OK>
May 01, 2011 | Polaroid FLM-323B Television
Sony LCD TV Model #KLV-23HR2 The timer LED blinks red constantly after having turned on the TV. THe power light stays steady green for about 5-10 seconds then the red light keeps blinking constantly.
This is a common problem an a failry easy DIY fix.
Apr 27, 2011 | Sony WEGA KLV-23HR2 23 in. LCD HDTV
Buzzing noise coming from Vizio HD TV speakers
It ur Vizio tv,The power supply board is the problems.The transformers in the power supply board have gaps in the transformers.The high voltage curents flow that make that buzzing noise.
Apr 07, 2010 | Vizio VW32L 32 in. LCD HDTV
TV is making a buzzing noise coming from the back interior. We tried checking the cables and testing speakers, neither of which are the problem. Any thoughts?
This noise is coming from the Lamp ballast. The back light of your TV (to make your LCD picture light up) is a Florecent Light Array. It is powered by a lamp ballast. You can have a shop change this power supply out for you.
Jan 06, 2010 | Westinghouse W4207 42 in. HD-Ready LCD TV
Loud buzzing noise on vizio tv
It sound like you may have sound processor problem which is part of the main board, I would also look at the 12vdc from power supply to make sure it is clean DC.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=l37hdtv10a
http://en.wikipedia.org/wiki/Capacitor_plague
Dec 22, 2009 | Vizio L37 Television
KV-32XBR37
Could be a failing power supply
Oct 16, 2017 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Buzzing sound
You haven't specified where the buzzing sound is coming from, if it is coming from speakers, changing capacitors in the audio section will fix the problem, especially the filters. Now if it sounds like a hissing sound from back of the tv, the CRT base socket is the culprit. It is an easy thing to fix, and the base is cheap, but make sure you purchase the exact same type of base or it will harm the CRT. Good luck.
Jan 22, 2008 | Samsung TXN2775HF 27" TV
Buzzing loud noise constantly.
I HAVE A RCA 50 HDTV DLP MODEL #D50LPW134 IT MAKE A BUZZING SOUND AND NO PICTURE i CHANGE THE BULB AND STILL NOT WORKING.
cantrin@hotmail.com
Ken
Dec 12, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Polaroid FLM-323B Television Logo
493 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
