Question about Garmin StreetPilot C330 GPS Receiver
Garmin Streetpilot c330 GPS Unit
I need assistance on this device. The GPS does not turn on at all. I have charged overnight and still no power. I have used other ways of charging and still no power. Please help!
Thank you
Joe
  • BILL_777 Oct 04, 2008
    UNIT WILL NOT POWER UP OR CHARGE.....FUSE IS GOOD.....HELP?
  • jonath20 Oct 05, 2008
    My unit will not power up!
Trying to register garmin c330
Posted on Sep 19, 2008
Will not charge and actually seems to discharge when plugged in to auto charger
Charge the unit overnight with a high power usb charger, 2A or above. If it turns on after that, check your auto charging cable. It should have a red led that illuminates if it has power. If it does not, then it is either the cable or a fuse blown in your car. If the gps still does not turn on after chargning overnight, you have a batter issue. Amazon sells battery kits.
Apr 06, 2015 | Garmin nuvi 2599LMTHD 5" GPS with Built-In...
I have a nuvi 265w garmin. It turns on and then turns off without loading the map
The GPS battery may need to be charged.
Does the GPS turn on when connected to a vehicle power cable?
Running the Garmin WebUpdater to load or reload the latest software will usually fix any bugs.
Contact Garmin Tech Support for assistance.
1-800-800-1020
Mar 23, 2012 | Garmin Nuvi 265W GPS Receiver
Garmin nuvi turns off for no reason
This usually occurs when the battery low on power.
If the battery is fully charged, then updating the software will usually help.
This can be done using the Garmin WebUpdater program.
http://www8.garmin.com/products/webupdater/howtoinstall.jsp
You may also want to contact Garmin Support for assistance.
1-800-800-1020
Jan 29, 2012 | Garmin nuvi 1390T Car GPS Receiver
My garmin 765 T won't turn on- I have charged it overnight
If you are charging your unit with the USB cable STOP - use only a wall plug. The unit will not charge using the USB cable. If you don't have the wall unit - try charging it with the car plug charger for 15 minutes. Just let the car charge it running or not. You will see it work. Once it is charge over half way - the rest will charge up. It is a problem Gamin is working on.
May 05, 2010 | Garmin nuvi 765T GPS Receiver
I've got an LG LN505.I haven't used it for a while.Now it's not switching on.
The battery is probable dead. Charge the unit for a while before turning it on. Preferably overnight. Then do not let it run completely dead before charging again. This way the battery lasts longer.
Apr 18, 2009 | GPS
Won't hold charge
Dear Iblaze1136, Fri 2-20-2009 8:22pm EST (USA)
Batteries must be charged completely when they are new or they will never hold a charge right!
I'm assuming you never fully charged them when new and so they will never hold much of a charge!
The Solution is to replace the battery or batteries and charge properly (overnight or at least 8hrs).
I recommend Radio Shack for this!
jack
b306d28.jpg Let me know if I can be of further assistance!
Feb 19, 2009 | Nextar X3-03 Car GPS Receiver
GARMIN STREET PILOT-330 GPS
Hello KTFORE1,
The Street Pilot 330 comes with both a vehicle power cord and a USB cord for connecting the unit to the computer. If I understand you correctly the GPS isn't getting power from the vehicle power cord. Does the GPS charge if connected to a computer using the USB cable? If so the problem is likely the power cord or cigarette lighter socket you are using. If the GPS doesn't charge from USB port on your computer then the problem is likely the GPS itself.
If you determine that the cable is the source of the problem, check and replace the cable's fuse. You will probably also want to check and replace your vehicle fuses as the circuit that powers the cigarette lighter might have a blown fuse. If replacing the fuses doesn't solve the issue then you might need to replace the power cord.
Best Regards.
Ken
"Go Ahead. Use Us."
Jun 30, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin 200w does not hold charge
Hello Jeffery81,
Sounds like either a bad charger or a bad rechargeable battery pack inside of the GPS. If the unit doesn't remain powered up even when it is plugged into the charger, my guess is that the charger is the problem. Do you have an alternate way to charge the GPS? Like a 12 volt vehicle power cord or a USB cable to connect it to your computer? If so, try charging the GPS using that alternate method. If the item charges and functions normally, you will know for sure that the problem lies with the charger. If not, then the problem is either the battery pack inside the GPS or some other part of the unit's charging circuitry. In that case, you should contact Garmin technical support for additional assistance.
Best Regards,
Ken
"Go Ahead. Use Us."
May 19, 2008 | Garmin nuvi 200W GPS
Power
there's no battery in this model it only works pluged in.
Sep 10, 2007 | Magellan RoadMate 300 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
85 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
