Question about Cameras
My Pentax Movie 8 has been in the closet since 1989 and runs the tape but will not play back those old tapes,just "snow" Also when I switch to "camera" it runs for a few seconds then shuts off power. Have the tapes gone bad and where can I get them checked and transcribed to DVD. I am in S. California thanks Richard
  • 308 Answers
SOURCE: Hitachi DV-PF33U DVD Player / VCR Combo
It sounds like the sensor to tell the microcontroller that the tape is moving is not working. If that is so, the VCR would probably do the same thing in FF or Rewind. If you end up taking this unit into a repair shop, have them check the DVD's software version (it should be 1.250) If below that number, have them upgrade that as well. You can check the version yourself by pressing 1,2,3,4 and then "display" on the remote while the unit is on and no disc in DVD. After noting the version, just hit "power" on the remote to exit this mode.
Posted on Jan 01, 2007
jbreth
  • 69 Answers
SOURCE: Pentax Optio W20 digital camera
I found a step by step manual for this operation. I hope it helps you get to transferring movies. http://www.pentaximaging.com/files/manual/OptioW20_pc_web.pdf
Posted on Sep 04, 2007
  • 3 Answers
SOURCE: Digital camera
I had almost similar problems with my A10 from day one. The camera shuts down before the battery is depleted, most of the time while I was operating the zoomlens. I bought a new battery, but that didn't solve it. Later I decided to take it apart as a last option. As my suspicion was the zoomlens I took out two crews of the motor that operates it. Now the motor has a bit more space to move. It seemed to be too tight against the gears so it could cause an overload. After that it worked perfectly. I made pictures for hours without having the same fault again. Be carefull too make notes where all the tiny screws belong of the casing. And maybe it will be enough to just loosen the motorscrews, but leaving them out will not make it fall out of it's place. I hope someone can use this information.
Greetings, Ron Timmermans.
Posted on Jul 25, 2008
welcomejee
  • 10594 Answers
SOURCE: I have an old Sony
Try to use video head cleaning cassette one more time and check. Problem still exist then....
There is a very special cassette used to clean much dirty video heads calls Lapping Tape.
This is provided only to Sony Service Centers.
You need to contact nearest Sony Service Center.
Posted on Oct 06, 2008
  • 4 Answers
SOURCE: VHS tape plays for a few seconds and automatically ejects
My guess would be dirt on the rollers inside the VCR. They sesnse a jam and ejct. Try a VCR cleaner (with cleaning fluid) and see if that helps.
Posted on Feb 21, 2009
Set on Run Forward and after a few seconds it goes to rewind by itself
Hi i need more information about the material you used.
It's a VHS player?? or really old Super 8?
If it's VHS tape the problem is that the tape is too old and is glued by the age and climatic., you to forward all the band manually and after retry in the player. Have a nice day
Nov 10, 2014 | Televison & Video
Playback 8mm camcorder tape fuzzy
8 mm and the newer super 8 mm video tapes are different. You can't use super 8 mm in old player. And old tapes won't play well in new super 8 mm players. Like Sony!
Nov 04, 2013 | Video Cameras
What can we do if the video tapes being played have Snow and try to play the video player with cleaner, we have to turn on and off. It automatically lose control.
Head cleaner tape for vcr just dry scrubs the rotating head for a short time. Remove it to check playback performance, to see if head is clean. If good, then record some program and see if snow is gone. some tape maybe recorded when the head is dirty, lots of snow. Some tape may have improvement if tape is run over knife edge to hone the magnetic surface, US patent granted years ago to reduce computer tape noise.
Aug 19, 2010 | Televison & Video
Tape Wont Play
My advice is that you should by a cleaning cassette. Put this in the camera and run it for 10 to 20 seconds only. running the cleaning cassette for a long time may damage the head.
good luck!
Luwangula
May 10, 2009 | Sony Handycam CCD-TRV58 Camcorder
Sound but only snow for picture
make a deep clean ur video head with a video head cleaner or with a soft cloth with some mild soap.
May 06, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
Sony Hi-8 plays new recorded video buy not playback
Are they PAL or NTSC tapes ? They may not be compatible with your new equipment.
Jun 13, 2017 | Sony Handycam CCD-TRV40 Camcorder
Movie tapes have snow but not home video tapes can i fix it my self
I assume you have had this player a while and I assume that all the programs that work without snow are ones that you recorded using that VCR to do it. Right?
If so, it is a compatibility issue where the last time you had it fixed, the repair guy did not check for VCR to VCR compatibility. I had a shop for 15 years and this is common.
Do you have a Tracking control? try adjusting that. It is either a physical control or part of the menu, depending on that specific model.
Last...last is to open the unit and you must be very very careful. Put in a tape that is from another player that plays snow and identify the shinny rotating head if you can physically see it. It sits at an angle and the RCA is typically in the back middle, about an inch in a half in diameter. While playing press your finger very very lightly in the middle of the shinny exposed video tape for like 4-10 seconds and maybe the snow will go away.
Your video head may be worn or dirty. Do not attempt to clean the heads the are verrrry delicate.
3. Try finding an old VCR cleaning tape. It does the same thing as your finger.
E
Mar 01, 2009 | RCA VR349 VHS VCR
Mode for playback of older 8mm tapes using Sony DCR-TRV730 ?
In 1990s Sony camcorder records movie in analog format so playing in digital camcorder like DCR-TRV730 doesn't mean it will be converted in digital format and you can not import file in PC for editing purpose. You will get analog signal while playing back old cassettes.
Regarding SP, LP speed, its decided at time of recording. Camera sens SP or LP automatically in playback and set itself accordingly.
If you want to convert old cassettes into digital format, connect our camcorder to DVD recorder and burn DVD which is digital format, copy DVD files in to PC and do desired editing.
Nov 24, 2008 | Sony Handycam DCR-TRV730 Digital Camcorder
Video 8mm player
only sony really supported 8mm look for any trv model cam on ebay etc and make sure you tapes were hi 8mm-not digital 8-digital 8 won't play on reg 8mm cam-need to get model that supports both formats then-trv480-look at tapes and if they say digital and/or hi 8 they may have been in digital and get the 480 it will work with both types
Aug 24, 2008 | Video Cameras
Small TV/VCR Combo
Have you tried using a VCR VHS cleaning tape? Looks like a movie tape but its actually a head cleaner. You might have to try that several times.
Apr 27, 2007 | Kenmore 22642 Top Load Washer
Cameras Logo
399 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
