Question about Fisher Paykel EcoSmart GWL15
Gwl 11 My machine stopped with a load with the soap still in. I was not in the house so I don't know if it beeped any. It has no lights on or no sound. I have replugged it into another outlet and nothing. Does it have a reset button for the computer. it is now unplugged and has been for a while
  • 46 Answers
Hi
if the machine is dead if most likely has blown a fuse ,that could be by a number of things but commonly by a faulty pump
cheers grant
Posted on Oct 22, 2008
Fisher and paykel model gwl 11 drains but wont high spin
they have a speed sensor at the bottom on side of motor if faulty it wont let motor spin up. sometimes it can be a computer panel issue .
if machine does the check lights and beep ok likely it is sensor
Feb 25, 2017 | Fisher and Paykel Washing Machines
F&P washer stops spin cycle
You will need to check the out of balance switch under the motor controller board for corrosion and replace if faulty.
May 24, 2013 | Fisher and Paykel Washing Machines
GWL Washer won't spin only beeps; Diagnostic lighs:the third light is lit up green in the bank of lights on the left; the first light on the right is lit up orange and the third is lit up red. Thanks,...
GWL Washer won't spin only beeps; Diagnostic lighs:the third light is lit up green in the bank of lights on the left; the first light on the right is lit up orange and the third is lit up red. Thanks,Hepi
Jul 24, 2011 | Fisher and Paykel GWL11 Top Load Washer
GWL 11 will not pump out after wash cycle.Can hear a light "hum",but no pumping happening. This situation was preceded by an un-balanced load stopping.I pumped water out by hand,redistributed the load,and...
1 check the vacuum hose from the float switch to electronics boards to see if its cracked and has air leaks. you should be getting fault lights if the pump is jammed,blocked or is faulty and not working.
Sep 19, 2010 | Fisher and Paykel GWL11 Top Load Washer
GWL 11 washer. Water does not come in when power
Hi just read your posting.Now what water setting have you selected?Is it warm cold or hot?Does the machine stop and beep with a series of lights that come on?If there are lights that come on when it beeps, they will be in a row of 8 lights.Starting from left to right which ones are lit?Is it the 3rd and 6th or 1st and 7th --etc--?Now if you have an LCD display what error code is it showing?Please reply with additional information and I can help you rectify this fault.
Jun 23, 2010 | Fisher and Paykel GWL11 Top Load Washer
I have a Fisher Paykel Model GWL 11 washing machine. A couple of days ago the machine was operating, but when it came to the spin cycle it would not enter the cycle. It kept trying, but eventually let out...
Yes I can help.Starting from left to right on the line that the lights are lit the fault code values of each are , Starting from the far left they go 1st=128 2nd=64 3rd=32 4th=16 5th=8 6th=4 7th=2 and 8th=1.Add up the lights that are lit on your machine and reply back and I will let you know what part is faulty.
Jun 04, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer won't drain
Could be something in the pump. The pump is on the bottom of the tub.
It has a locking tab which you release and then twist the pump a hair and it will fall out. Warning: Have rags ready! I have the original GWL service manual and the GWL 11 supplimental manual. Let me know if you want them.
Apr 28, 2010 | Fisher and Paykel GWL11 Top Load Washer
During the rinse cycle, our GWL 11 Fisher & Paykel
The problem is in the pump, so it will not pump out, you will need to find another way to empty it, removing the agitator will make the job easier.
When you get the water out the pump can be accessed from underneath, it turns anticlockwise to remove it,.
I would buy a new pump as it is most likely that is all that is wrong with it.
Apr 18, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykal GWL-11 won't advance through cycles. Could this be
maybe blocked drain pump can u hear a buzzing when it tries to drain water
Oct 06, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher and paykel washer gwl 11 us
ok You have a blown Motor controller module. There could also be another fault that caused this to blow up. eg a faulty drain pump, lid lock or Diverter valve, inlet valve. you'd need to use a ohm meter to test all these. cheers
Mar 22, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel EcoSmart GWL15 Logo
115 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
