Question about Gateway Computers & Internet
Gateway GM 5266E
When I turn on the connected UPS the computer turns on
    Sergeant:
  • 300 Answers
Turn off the computer.
It should remain off at that point.
If the computer keeps comming back on , you need to do some more configuration
such as ( do not wake up on USP device ) that may be in your computers bios settings.
also check your settings in windows , ( do not allow this device to wake the computer up from suspend )
You'll figure it out !
Loch Hiam
Az.
Posted on Sep 18, 2008
I have a Gateway Laptop that is 6860fx, and I wish to do a factory reset on it. The reason is that the laptop is infected with many pop-ups.
factory reset removes everything
why not go to settings and just remove pop up setting --turn it off and delete pop-ups
Jan 26, 2017 | Gateway Computers & Internet
When connected to power the green light is not showing and the battery light is is always on
This indicates the battery is worn out and will not provide power in the event of a mains power failure.
To test the battery, connect a computer or some other device to the output on the UPS, and connect the UPS to the mains supply. Turn on the mains power to the UPS and power up the computer, then turn off the main power to the UPS and if the computer switch off in a short time.
This proves the battery is old and needs to be replaced.
Mar 19, 2011 | APC APS BackUPS CS 650VA 400W 230V DB9...
Computer restarts as soon as power goes off, its not an ups . When i manually turn off the power to the UPS, it switches / relay works fine, but if actually if there is a power outage the relay does not...
Your question is slightly confusing. Do you mean that the computer is not powered by a UPS? If the computer is not connected to the UPS, then why have a UPS? If the computer is not connected to the UPS and restarts when you turn the UPS On, your circuit feeding the UPS is overloaded and the voltage dips. If the computer is connected to the UPS, and restarts when there is a power outage, the fault may lie in the reaction of the HP 800. This unit looks to be a line interactive unit and it is not a true on-line UPS. The line interactive and battery backup (no voltage regulation) units both should have a switch to battery power time of 4 msecs, or less. If this unit is faulty and the switchover time is longer, it will not continue to hold up the computer internal power supply. If you are trying to run a laser printer on the HP unit, it won't have enough output capacity.
Feb 20, 2011 | HP Computers & Internet
I want connect UPS to my computer. when i want turn off my computer UPS must turn off too. not turn off by hand. thank you
if i understand you when you turn off the computer turnd off
the purpose of the UPS is to keep your computer on in times of losing the power the ups should be on all the time its has a battary and it should be charged just turn off the computer not the UPS
Aug 17, 2010 | Belkin (F6C800-UNV-PL) UPS System
Power turned computer off. Now all connected again
All ups' have a reset button. Press it and it will get back to normal.
If it doesn;t, your UPS went bad.
Replacement is needed.
Don't forget to rate this answer if it helps
Dec 12, 2009 | Computers & Internet
Gateway FDP1975W Monitor Power Button Not Working
i would advice you to take your monitor to a technician, but if you are not ready, please leave the monitor on and make sure it is connected to ups u can now turn it on and off from the ups, if you continue the menu, Auto fit etc stuff, you might damage or disorganize the settings of your monitor which might cost you more. thanks
Jul 17, 2009 | Gateway FPD1760 17" LCD Monitor
No action after BIOS
is is a desktop or a laptop PC.
if desktop try a different power supply and not battery( UPS) , although the UPS is very important to control increase and decreases in voltage.
Mar 24, 2009 | Gateway Computers & Internet
My monitor ,keyboard,and mouse dosen't work . my computer is a gateway GT 5058
The fact that the monitor, keyboard and mouse don't work points towards a bad motherboard. If you can hear fan's running, see lights on the front of your PC then you are getting power to the motherboard.
Mar 15, 2009 | Gateway GT5058 Desktop PC
Backup unable to communicate with computer
Plz check your computer without ups.If it is runing there.And wattage of ups .It seem over load or shortage of ups.Check power cable.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Mar 06, 2008 | CyberPower 1350VA UPS w AVR & LCD...
Computers & Internet Logo
49 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
