Question about Cameras
Camera took on a slight amount of moisture. Now LCD screen will not illuminate. Camera is functional in all ways. Shining a light into LCD screen shows that a dis play is still present & functioning.
  • roncas7 Sep 18, 2008
    From roncas7:
    Camera is a Canon Powershot A720 IS,4 months old. Have applied heat and air to no avail.
  • 928 Answers
The only option is to take it for service unless you are comfortable with opening up the camera with which you will neeed the service manual and some parts if you may indeed need to replace them
Posted on Sep 18, 2008
    Scholar:
  • 97 Answers
This is a damage comparable to laptops wherein the FL Inverter is busted. The FL Inverter is the bulb that provides the bright white light that helps you see the actual display on the LCD. This could be the problem that you're having on your Camera. I am assuming that this is the damage done by the moisture on your camera since you mentioned that you can see the display in the LCD only it's has no light.
You'll definitely need to take it to a repair center that can fix it.
  • Oliver Allan Lee Sep 18, 2008
    I'm using the term FL Inverter since I'm used to that on laptop LCDs, you can just tell the repair center or if you're buying the parts yourself that you need a backlight bulb.
  • Cameras Master
  • 6,487 Answers
Can you please inform us the brand and model of this camera so we cna help you better..
Panasonic Viera TC-37LZ85 powers on with a solid red light that does not blink, the screen slightly illuminates but no picture. Blown fuse?
T'Con board fault. In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Apr 10, 2015 | Panasonic Viera TC-37LZ85 LCD TV
HOW DO I WORK A DIGITAL CAMERA?
STEP-BY-STEP INSTRUCTIONS FOR OPERATING YOUR FIRST DIGITAL CAMERA
1. READ YOUR CAMERA MANUAL before taking any photographs.
2. Check your batteries. Make sure to either recharge or replace them if you haven't used your camera as yet or for an extended period.
3. Insert your storage media card in the appropriate slot. If you forget to insert your media card, you'll get a "No Card" message.
4. Remove the lens cap.
5. Turn the camera on by either an on-off switch or a sliding lens cover.
6. Turn off the LCD. (See your camera manual for instructions)
7. Make sure your camera is set for automatic mode. Set the image quality to the size image desired-HQ (high quality) or less (to take more pictures on the same card).
8. Bring the camera up to your eye and look through the viewfinder. Positioning the target mark in the center of the viewfinder on your subject will assure that it will be in focus.
9. Push the zoom lever toward W (wide angle) to shoot wide-angle shots or push it toward the T (telephoto) to zoom in.
10. Press the shutter button half way down gently and confirm that the green light next to the viewfinder is illuminated.
11. Press the shutter button all the way down. You'll hear a beep when you take a picture. Wait until the green light stops flashing before taking another one. Remember, digital cameras have a slight delay that traditional cameras don't since it takes a second to save the image to your camera's storage media card.
12. Turn off the camera. Your new photograph should appear on your camera's LCD screen.
TIPS:
1. Use the viewfinder to compose your photograph, not the LCD screen, which will severely drain your battery power. Use your LCD screen only when shooting close-up photographs.
2. Hold your camera steady. Sometimes, the least amount of movement will cause your photo to be slightly blurred. Purchase a very small tripod so that you can provide extra stability for your camera. Also, if there isn't enough light (indoors or outdoors), make sure to use your camera's flash.
3. Experiment with your camera's features and take notes so that you can learn what works for you. Do this before you plan to use it for an important family event or trip.
Dec 15, 2010 | Cameras
Lcd screen is white
wipe off the lens. the same thing happened to me. it probably has moisture in it.
Oct 10, 2009 | Kodak V803 Digital Camera
Black parts of screen looks light light is shining on it
Your LCD TV uses backlights and they can be slightly visible when viewing a letterbox movie.  However, if the light is really bleeding into the black, there could be a problem, but mosty this is common.
Mar 24, 2009 | Samsung LN-T3253H 32 in. LCD Television
Lens repaired then new problem - Illuminated LCD screen
The ribbon cable that connects the lcd screen to the circuit board is not inserted deeply enough. Try again, but push it in until it physically cannot go in any further.
Feb 22, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Very, very dark (almost black) lcd screen, but is functional
The LCD viewer is made up of the LCD screen, and the backlight. Your backlight is burnt out, or the circuit board isn't sending power to it. Backlights can be replaced separately.
Sep 04, 2007 | Logitech ClickSmart 420 Digital Camera
Freezin' up
If it got wet, your best bet is to put it in a nice warm sunny place and let it dry for at least a week. If you're feeling confident, you may want to open it up to assist with the drying process. If you're camera got wet in salt water... well, there's nothing much you can do there. Good luck!
Sep 02, 2007 | Nikon Coolpix L11 Digital Camera
Lens won't open/flashes E18 on screen
i got my camera a couple of mounths, but i have not used it alot. When i turn it on, the start up screen wold come on but e18 would come up on the screen and nothing would happen after. i desperately need your help to fix my camera. thank you.
Sep 24, 2006 | Canon PowerShot A70 Digital Camera
Help please
see if keeping the power button pressed continuously without
releasing keeps the camera on
Jun 15, 2006 | Vivitar ViviCam 5340s Digital Camera
H1 - is this normal ?
I haven't ever noticed anything like that with my camera. There is a slight amount of play on my lens though.
Sep 12, 2005 | Sony Cyber-Shot DSC-H1 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
