Question about EliteGroup NFORCE 570 SLIT-A Motherboard
Bios don't boot at start stays at Black screen
Well I put a new sata hardrive into the computer after i tried starting it, it the monitor stopped clicking on, after a few resets it finally clicked on instead of seeing the bios boot screen I see a black screen, first it just had a white flashing dash after a few more restarts I just see random numbers and symbols I've tried resetting the bios with no luck until I track down a floppy I can't try to flash the bios anyone that can offer some help would be my hero.
  • 1 more comment
  • Moopin607 Sep 18, 2008
    No all I did was put in a sata hardrive before that is was working fine since then I've taken that hardrive out thinking it could be the cause of it but so far same problem
    been playing with it for a few hours forgot to remove the sata cable from the motherboard from the hardrive I removed no more strange black screen with random numbers and symbols now but my monitor doesnt seem to want to click on anymore still, everything else seems to come on though, this has happend once before I took everything out of the pc and left it alone for a few hours came back and everything worked fine again but anything else that could help would be nice.
  • Roberta Smith
    Roberta Smith May 11, 2010
    did you recently update the bios ?
    Robert
    Brigadier General:
  • 5,158 Answers
You need to install the sata driver for the hard drive. watch closely at the beginning of the install and you will see it ask you to hit one of the f keys (i can't recall which one at the moment) to install the driver.
so go to the website of the hard drive manufacturer and download the driver.... put that on a floppy disk and install the driver... you should be good to go after that.
Posted on Sep 18, 2008
Well I dunno what I did but its up and working now all I did was take everything out leave it alone for a bit came back put everything in and it booted up fine dunno how but its finally back up yeehaw
    Master:
  • 763 Answers
I had a same problem too. but i know the real problem is the motherboard. it should be replace with the same model of motherboard.
Asus p5n-e sli will no longer stay on for more then a few seconds
You go to AVIRA dot com and download the boot tool, or go to BITDEFENDER and run an online scan, you don't put in a new HDD just because you had a virus, it sounds like you had a problem and thought it was a virus.
Read you manual, plug in the Sata drive into Sata 1.
Do you mean BIOS post, if you don't even see the BIOS post, check your monitor with another PC.
There is only one correct power switch pin, a , + and - pin, how can you switch, there is no such thing as switching.
Dec 15, 2012 | ASUS P5N-E SLI Motherboard
Ok i have two hard drives and the computer is not finding them
poss windows has fallen over you need an operating system check hdd are master and slave master first one from board go to bios set the cdrom as the default 1st boot device put operating system into cd rom should start to load operating system
Apr 06, 2012 | Dell Inspiron 530 Desktop Computer...
I have a Asus Rampage Formula board w/ 4gig mem, was running a BFG GTX 260 max core nvida card , win XP pro 32 bit sp4. I have had no issues for about 1yr then when the computer would run for a few hrs the...
Mabee the hard drive has failed . try entering bios and see if the hard drive is recognised .If not try turning the computer off unplug it then reconnect the drive data cable and power cable
then re- start the computer and see if it is recognised. some models of older hard drives needed a driver installed during set up -- you usually have to put the driver on a floppy disc and hit the f6 button when prompted by windows set up to install third party drivers . I hope this helps
Apr 08, 2011 | ASUS MB RAMPAGE FORMULA 775 X48 RT...
My computer says: DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER. How do I fix this problem. There is a screen before this, but then it turns straight to that screen and will not allow me to do...
1. Check the hardrive cable connection (data and DC supply).
2. Under the BIOS setting, make sure that the hardrive is detected (set to enhance mode), this will detects either SATA or PATA., Exit and Save new setting
3. If still no detect, your hardrive might defect n need new one
Apr 26, 2010 | HP Pavilion MX70 17" CRT Monitor
Screen goes black with one cursor blinking after windows loads
start your pc press del, go to cmos setting and look for primary and set it up to boot from cdrom
after you install everything
go back to the cmos and put it back in primay hardrive and that is IDE1
Aug 04, 2009 | Dell Dimension 2400 PC Desktop
Cannot get new Motherboard to boot up in Normal Mode
what u may have done is wwhen u were installing the new board, gave a static shock to the system...that will cause only the fans to come on and nothing more...this is a bad problem bc u cannot fix it...if u figure out something else is wrong, and it gets fixed, let me know
Jun 20, 2009 | Gateway Computers & Internet
Monitor stays black until boot up to Desktop
you use a graphics card as your main output?
and you have onboard graphics output too that you dont use?
if so then you will have to plug your monitor lead into the onboard output socket to see bios. i think you need to go into bios and change which device starts from boot.
it sounds like you have the onboard graphics as your boot device and windows using the graphics card.
Feb 26, 2009 | Sceptre X9G-NagaIV 19" LCD Monitor
Screen stays black
Try using a different monitor if you have one available, or disconnect the monitor from the computer and then turn it on. If you see a logo or color bar or message saying no signal, then your monitor is OK and you should take a look at your video card.
If you suspect your video card, there is very little you can do with a no video situation. but one thing you can do is to remove the video card completely and wait for a few minutes. then put it back in and try to start your computer. This is just in case you have corrupted video memory keeping it from functioning. otherwise, replace the card.
In the case that your video is built into you computer, buy a new card and disable the onboard video in the BIOS. That will take some browsing in the BIOS setup, but it shold be fairly easy to find. once it is disabled, the new card will be able to function and you should be ok from there. Otherwise, it's motherboard replacement time.
Jul 11, 2008 | Acer Aspire 1414 Notebook
Black Screen
try hooking up an external video source. Check to see if the computer is actually booting up. if the computer boots up, then the LCD invertor or Backlight of the screen is bad, need to be replaced.
If the computer does not boot up after hooking up an external video source, then most likely your motherboard is bad!
Jun 29, 2008 | Computers & Internet
On Pwr up logo appears then LCD returns to stanby Black screen
I will assume the monitor is staying on during the boot process all the way until Windows loads.
If that is the case, then...
  • Start the computer
  • wait until the initial bios/logo screens for your motherboard go away.
  • Press F8 to get the Windows recovery boot menu
  • If you see the Windows Logo you would normally see then press rest and try again.
  • In the recovery screen, select SAFE MODE
  • Boot into Windows and uninstall your video card.
  • Reboot the computer the normal way through the start menu.
  • When your PC starts back up it should then reinstall the video card, and set itself automatically back to 60khz as default.
Let me know how you go =)
Jan 20, 2008 | BenQ FP71E 17" LCD Monitor
EliteGroup NFORCE 570 SLIT-A Motherboard Logo
183 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
