Question about EliteGroup ECS P4M800-M Socket 478/P4M800/FSB800/A&V&L/M-ATX Motherboard (MOTEC18)
Motherboard does not start i have everything connected
  • erwinroyo
    erwinroyo May 11, 2010
    Your computer does not start. Was light of power led on when to open your computer? or nothing at all?
  • Tim Babcock
    Tim Babcock May 11, 2010
    Make sure your memory cards are seated properly first of all.  You might want to swap memory cards to see if one is defective.
Inspect careful, it doesn't mean that any move there is no responses by the computer. If not checks the memory, the memory is responsible for booting also plus the connection of each components. . . .try it
Posted on Feb 15, 2009
I installed everything the CPU, RAM, and everything else. Connected all switches at the right places and the BIOS is on normal operation. I turn on the computer and its a blank screen nothing shows up....
ok, looking at the specifications All I can recommend is the following. double check the Video card to make sure it is properly seated and that it does not exceed the capabilities of the motherboard. 2 Disconnect everything from the motherboard except the CPU and case wiring/power supply and turn the computer on. If the system completes the post test, you will hear at least 1 beep and should hear several for the video card not being connected, then start installing components 1 at a time till you find the one causing the problem. Start with the Video card and then the ram as these are most likely where your problem is unless you have a faulty power supply which will be the problem if you don't get a completed post with nothing else connected.
Jun 18, 2010 | Abit IS7-V2 Motherboard
Won't boot....fans start, then stop right away
check if your power source is ok. it may be broken and this is why you hear the fans start and then stop right away. they are working about 3-4 seconds, aren't they?
remove and put back the jumper for clear cmos after you test your motherboard with a new ac source
Jan 25, 2010 | Biostar P4M900-M4 Motherboard
I'm connecting everything but the motherboard does want to start
Some power-supplies have a rocker-switch, with a '|' and an 'O' icon, which acts as a "master" power-switch. Be sure that you have pushed down on the '|' side of the rocker. As you do so, look at the motherboard -- it may have a small green lamp on it, to indicate that the motherboard is receiving power from the power-supply. Also, look at the fans -- they may slightly "rock" (twist back and forth) for a moment as you move the switch.
Most of the connections to the front-panel can be ignored while "trouble-shooting" your problem. As long as the two "power" pins on the motherboard are connected to the "power" button on the front panel, pressing the "power" button should work as expected.
Oct 26, 2009 | Asrock AM2NF6G-VSTA Motherboard
My gateway 540 gr start for 5 seconds and turn off, the fan starts to then turn off.
Disconnect everything except for the power to the motherboard. If you turn on the computer and everything still turns off, then try another known working power supply. If the machine stays turned on then connect power to your drives one at a time with the computer off each time to see which drive is the culprit.
If everything still turns off then reseat the CPU and the memory and if it still turns off then that means the motherboard is bad and it would need to be replaced.
Jun 25, 2009 | Gateway 500GR PC Desktop
IDE Connection to HDDs Problem
Check the IDE cable, Jumpers (Master/slave), power connector/cables, this will fix your problem if there's no internal damage on the motherboard. Good luck Thanks for using FixYa.
Jan 20, 2009 | MSI K9VGM-V Motherboard
E-Machine Mother Board Connections
Find the company, and name of the board, and look that up. Computer manufacturers could use any number of different boards. You need the specific manual to that board. The manual should explain where the connections go. Sounds like you have the LED HD and POWER ON LED disconnected.
Sep 28, 2008 | ASUS A7N8X-E Deluxe : ATX Socket A FSB400...
Problem with the LAN Ethernet NVIDIA
right click on taskbar network icon and click disable
Mar 13, 2008 | ASUS P5N-E SLI Motherboard
EliteGroup ECS P4M800-M Socket 478/P4M800/FSB800/A&V&L/M-ATX Motherboard (MOTEC18) Logo
79 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
