Master
- Posted on Sep 25, 2011
Re: Having problem setting distributor on timing
Hello Jc..the timing on the vortec engine is computer controlled. This is called static timing, & is done when the gears are installed. A timing light will not help on this. You can adjust the camshaft sensor, but a scanner needs to be connected to monitor the adjustments. I hope this helps.
