Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
WASHER IS NOT RINSING OR SPINNING
FOR SOME REASON THE WASHER IS NOT RINSING OR SPINNING ON OUR WHIRLPOOL  LSQ9645KQ0
  • 2 more comments
  • wwells Sep 19, 2008
    Thank you ... your suggestion worked. This was the problem
  • cdgp Sep 25, 2008
    the washer works half way through and then stops i.e it washes but no rinsing
  • rpatel15 Sep 26, 2008
    we have a whirpool washer and it is not rinsing or spining and the Model Number is LSQ 9564JQ0 and the serial number is CK2927740
    please help me with your best advice
    thank you
  • jadp Oct 15, 2008
    It washes but stops at the rinsing
    I can hear a small humming sound of the motor.
    When i pu *** back to the wash mode, it starts spinning and when it comes to Rinse it jsut stops
    Checked the water hose and everything looks good
  • 4 Answers
Mine would not drain or spin and it was a sock that was stuck in the pump! we had to unplug the washer then unhook the hoses! the pump is in the front right side! take the hoses off and see if anything is jammed in there! hope this helps!
Posted on Mar 10, 2009
Whirlpool will not drain water
Posted on Sep 21, 2008
    Genius:
  • 1,028 Answers
Probably a bad lid switch ckd the area on right side of lid opening switch mounting screws can break out allowing switch to drop our of postion..switch lever could be broke or just not going far enough down to engage
Posted on Sep 18, 2008
Washer is not spinning
Not a whole lot of info..but, in most cases it the belt or belt tensioner or maybe a spring. It should be a easy fix, depending on model..having enough time and space. Good luck on your repair.
Jan 04, 2012 | Whirlpool Washing Machines
Whirlpool WFS1276AW bangs loudly when rinsing and spinning
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Sep 06, 2010 | Whirlpool LHW0050PQ Front Load Washer
I have a stackable washer and dryer and laundry detergent is leaking into my dryer (which is on top). How do I fix this?
First check your WASHER. IT MAY NOT BE RINSING AND/OR
SPINNING THE CLOTHES DRY ENOUGH.
I would suspect not rinsing more tho.
Leo Ponder
imufo2@sbcglobal.net
Jul 28, 2010 | Whirlpool Dryers
The drum is not spinning during washing or rinsing
Idler pully is the usual problem. The two tub roller will usualy make knocking sounds but can make squeling nosis.
Jun 06, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Spinning cycle
When it is spinning, there is no agitation. Why? there is 1 motor with 2 directions to provide sinning and agitation by 2 different mechanisms. The sound from spinning, and rinsing could be some worn out parts from the mechanism need to be inspected and replaced accordingly such as the pulley, the clutch, the brake and 8 springs from bottom tube hung to the chassis to keep the tube balance under the load. Hope this can help.
Jan 08, 2010 | Whirlpool LSN1000LW Top Load Washer
Whirlpool Washer LSQ9645KQ0
The washer has the sound both times but not all the time. I THINK we found all the pieces but now that you mentioned it, perhaps not. Are you thinking there may be a piece lodged somewhere and making that noise?
di_marie60
Aug 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Machine won't spin and smells like burnt rubber
Find out what part was replaced before. If you have it repaired again, watch everything that they do. If the washer is not spinning but is draining, it may be the belt. You might try tipping the washer over forward and having a look at the belt. It may have slipped off or may have broke.
Jul 28, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer not rinsing or spinning, just washing.
sounds like a lid switch problem. slowly open and close the lid and listen for a clicking sound, if you don't hear one then the lid switch may need to be replaced.
Jun 29, 2008 | Whirlpool Washing Machines
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
261 people viewed this question
Dan Webster
Dan Webster
Sal De
