Question about Nintendo Super NES Console
A broken piece
I un hooked it one day and when i unplugged the power adapter the little grey plastic piece broke off. not on the power cable but where you plug it in on the console. now there just two metal prongs and the power wont turn on! any solutions?
    Sergeant:
  • 241 Answers
Hi you can go here to this Link I use this for my business they have the parts that you may need>>> instock or they can get them too.
shop.bresoftware.com
Thank You
jayson
please rate my help or you can asked me another quaetion if you like
Posted on Sep 18, 2008
In dire need for a lid and power cord for this blender
Power cord is pretty standard for appliances/desktop PCs/printers. I would try the local Goodwill, they all have a wall with cords for every manner of appliance. On any given day, my local Goodwill has them in black and grey. Or any electronics store will have them.
As far as the lid - I'm not sure if you lost/broke the entire thing or just the plastic cap in the center. That Jenn-Air center plastic piece is easily broken. Your local Ace Hardware or True value sells replacement Blender cap inserts. Glass center with aluminum washer/nut that screws on from below. Looks better than original and won't yellow.
Nov 28, 2012 | Jenn-Air JBL800 Work Top Blender
Hi, I have a 1999 Camry LE 4-cylinder automatic. The car is not shifting into gear. I popped the hood up and noticed that the transmission control cable (shifter cable) connection to the neutral saftey...
I think the cable is molded into the little plastic piece. see if you can see the end of the cable. see if it looks like it broke, or was cut. if not, the molding came undone, and the cable pulled from the anchor in the plastic thing.
Aug 15, 2010 | 1999 Toyota Camry
2008 dodge avenger that wont get out of park
shift interlock cable out of adjustment? Solenoid problems at one time with these.
Jul 12, 2010 | Dodge Avenger Cars & Trucks
2008 Avenger: My dodge avenger 2008 is stuck in park we do not h...
A spring come loose inside the shifter assembly. Pull up on the shinny PRND cover to remove, the rest of the covers unsnap (use small screwdriver), pull up on shifter knob (might need to wiggle a little), Look for the pink plastic thing on the left. It should have a spring that pulls back on it when you shift into reverse. If this is missing, unbolt the four nuts that hold the assembly to the floor, look for the old spring. If it's gone you can cut a new one to size and hook it back on. If yours is like mine, the small pink hook is broke and you will need to drill a small hole in it to have something to clip the new spring to. By the way, I had to do all this with the assembly in the compartment as I was unable to remove it completly. Not enough room. I removed the coin tray in front of the shifter, ParkReverseNutralDrive thing, grey cover that surrounds the coin tray, 4 mounting nuts, and the cable that attaches to the pink piece of plastic that Chrsler should have put a little more effort into designing. ARG! Good luck.
May 18, 2010 | 2008 Dodge Avenger
Replacing broken cable on Porter Cable 7800 sander
just have to take off the plastic flexible casing it is screwed to the head. then you can pull the old wire out, if it it broken take out the plastic bellow and the 2 screws that are underneath that. then u can pull the remain of the old[broke shatf wire. To unscrew the casing use a plier and hold the metal piece not the plastic or u will broke it. \ REMENBER THE CASING IS NOT THE VACUUM HOSE IS UNDER IT.
Jul 27, 2009 | Porter Cable 7800 Drywall Sander With Dust...
Power window cable connection point -broken tab on plastic piece
the regulator has broken.you will need a new one.they do repair kits for golfs and beetles but not for passats you have to replace the whole regulator.dont attempt it unless 100% confident they can be tricky.
Apr 27, 2009 | 2001 Volkswagen Passat
Saturn SL1 Shifter to Shiftstick
I had the same problem over a year and a half ago. I went to the closest Saturn dealership to get the replacement plastic piece. Turned out that the ENTIRE shift cable assembly was the smallest part that could be purchased to repair this. The cable assembly was over $200 at that time. I opted to forgo the ridiculous expense for this tiny little plastic part. True story: with a little heavy safety wire and a large washer I jury rigged the washer to hold the end of the shift cable in the fitting at the bottom of the shift stick. The washer acts as a keeper and the wire, wrapped in a basket around the back side keeps everything together. It still shifts reliably, a little looser than when it was new, but I saved $200 in parts (99% of which weren't broken) and probably a couple of hours of labor at least. One end of the cable assembly has to be attached to the transmission by the way and is not easily accessible. Sounds hokey but it really worked, still works!
Mar 08, 2009 | 1998 Saturn SW
2000 bonneville, one rear cable on the left rear power window
On my 2000 bville, all four of my windows came off. All four had the same problem. the upper and lower cables go around the pulleys then connect to a plastic piece connected to the track. This plastic piece breaks and lets the cable free. I fixed them all by removing motor assembly and reconnecting the cable with coat hangar wire. Kind of a redneck fix, I know, but beat paying 160 dollars per window for a new assembly that would probably break again!! Good luck!!
Feb 26, 2009 | 2000 Pontiac Bonneville
Broke the hook off the automatic needle threader
You can get a new (grey) threader inexpensively that pushes on the bottom of the threader shaft from a dealership. Easy to do it yourself or they can do it in 5 or 10 minutes. Try taking the old one off and looking at it. It pulls right off.
Nov 22, 2008 | Bernina Virtuosa 150
Roady 2
Rework a paper clip so it has a little hook on the end and shove it into the connector to hook the plastic piece and remove it.
Mar 30, 2017 | Delphi Roady XT XM Radio Receiver
Nintendo Super NES Console Logo
87 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
