Question about Onkyo Audio Players & Recorders
ONKYO TX-DS555 how to check subwoofer o/p as it doesnt appear to be working. Sub woofer speaker appears to be ok.
4 Suggested Answers
SOURCE: Onkyo 805 sub hook up problem
Looking at the back of the sr805, there is a second subwoofer output, this one is the preout. 4 rca jacks to the right of the non-preout subwooker. Moved it, and all works now.
Posted on May 15, 2008
  • 17 Answers
SOURCE: No sound from Sub Pre-out on Onkyo TX-SR606
Also, it could possibly the preout terminal itself that is not working. One way to prove that is by transferring the subwoofer cable from the preout and temporarily transfer it to the tape out section. If it ouputs sound from there, then that means the speaker and the cables are working fine and it's just the preout terminal itself that is not picking up anything. ^_^
Posted on Dec 16, 2008
lynchms
  • 93 Answers
SOURCE: Powered Or Unpowered Subwoofers For Onkyo TX-8511
Greg- Powered subs are better than non-powered subs (also known as passive subs), anyway I see the TX-8511 has no sub pre-out on the back panel, so you need to decide what sub you will use and run from the receivers left and right speakers output into a subwoofers speaker in from speakers then back out to speakers, look at the back of a subwoofer and you will see like 4 sets of speaker hookups 2 in and 2 out, what this does is takes the low end or bass and drops the signal to the subwoofer then takes the mids and highs out to your left and right speakers, unless your regular left and right stereo speakers have large woofers a sub is the way to go.
Posted on Jan 28, 2009
How can I hook up BIC F12 subwoofer to Onkyo TX-DS838 receiver? Will the receiver power the subwoofer and other speakers?
Get a RCA cable and connect from your amp where it said Sub Woofer in the Pre Out box in the back of the amplifier top left hand side and take it to the "Sub In" located in the back of your Sub woofer bottom right hand (White round connector).
Good Luck!
Aug 06, 2014 | Onkyo TX-DS838 Receiver
How to Connect HT-CN300 Subwoofer to Onkyo TX-SR313?
Hello! You will most likely need a RCA cable with single ends (both being male ends) One end plugs into your subwoofer input....marked subwoofer input on the subwoofer..........The other end will plug into your receiver that is marked subwoofer . When low frequencys from your media.....whether dvd,s /cable or audio cd,s is present the sub woofer will kick in , Make shure to adjust your setting on the rear of the sub if it has any like volume or frequency , most better subs have them as where the home theater in a box combo usually does not!
Jan 01, 2014 | Sharp HT-CN300 System
My receiver is not picking up the subwoofer, there is noise coming from the sub when I'm playing with the conection. The speakers are working and im getting prefect sound from them Please help.....
It would be helpful to know if this is a new problem on working equipment or a new problem on NEW equipment. And if you've flipped through the manual without success.
Of course you KNOW the sub must have its own amp, right?
First, you need to determine if the Onkyo or the unnamed sub is at fault.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Onkyo-TX-SR608-Receivers-manual/id/23653ag916/t/2/
At the Onkyo, check to make sure you have run the speaker setup starting on Page 40. If that doesn't work...
Disconnect the subwoofer pre-out at the Onkyo and move it to the VCR Out, tune an FM station and be ready for some real loud subwoofer output if your sub has no volume control of its own. If you can hear the sub, it works and it's back to the Onkyo. If not, the unnamed sub
Apr 09, 2011 | Onkyo TX-SR608 Receiver
Onkyo tx sr502, sounds coming from all speakers except sub. in test sub works
hi,
Try the following setup to activate the sub
1.Press the [AMP] button on the remote and then press [SETUP] button.
2. Use the Up and Down arrow buttons to select "1. SP Config," and then press the [ENTER] button.
3. use up and down arrow to select subwoofer setting.
3. While the subwoofer setting is selected, use the Left and Right arrow buttons to select Yes .
you will surly get the audio from the subwoofer.
ok
Feb 19, 2011 | Onkyo TX-SR503 Receiver
I have an onkyo reciver and 7.1 speaker system. The powered sub-woofer keeps timing out and when I run the automatic speaker test on the reciever, it does not see the sub-woofer. I checked the reciver...
I assume you mean the subwoofer remains silent during the test. Perhaps the subwoofer is where we should be looking.
If you jack it into one or both of the Tape Out connectors and play some music with substantial low bass, does it make any sound? This would at least prove it is alive.
Dec 13, 2010 | Onkyo TX-SR605 Receiver
Hi My Onkyo TX - SR875 has lost sound from Sub Woofer? not sure if the reciever or the Speaker? Any way to check? Martin
Hook the subwoofer RCA input cable to one of the other Pre-Outs. It won't sound GOOD but it will prove if the sub still works.
Then, if the Sub is alive, reconnect it to the Sub Out.
Get into the SETUP and make sure the Onkyo still knows you have a sub and do all the setup for the speakers.
May 03, 2010 | Audio Players & Recorders
Garbled / feedback sounds from powered subwoofer
The surround processing portion of the unit has a problem. In either stereo or direct mode, the digital procesing is bypassed. This could be just the surround processing IC, but that IC may not be available as a separate part. I would suggest that you bring this unit to an authorized Onkyo service center for an estimate.
Dan
Mar 18, 2009 | Onkyo TX-DS595 Receiver
Jan 28, 2009 | Onkyo TX-8511 Receiver
Onkyo TX-SV525 Receiver subwoofer pre out no sound
Yes turing on the "A" speaker is required for the Onkyo, but that only turns on the 2 front speakers in the "A" speaker jacks.
You may also need to check and see if the Onkyo has a menu selection in the setup menu that will turn on the sub woofer output on the back of the receiver.
I have seen on countless occasions where people just have a hard time finding that sub woofer option on their receiver.
I do not have the manuals for this Onkyo, so I can not tell you the exact way to find it.
I have been repairing surround receivers since they have been on the market and beleive me, you are not alone in this situation.
Sometimes it seems like you need a Phd. in programming or something similar just to firgure out how to set one of these up.
The solution should be in your owners manual, with the problem then being, just where in the manual. Go slowly thru it paying the closest attention to anything about set up procedures.
I have also seen at times where the setup for the sub-woofer is not listed as sub-woofer, but as "LFE" (low frequency effect) . So keep your eyes open for that.
something else, your sub woofer may have an auto turn on. That means it will only turn on if it detects an input signal. Make sure yo uhave the volume up enough on the receiver to trigger that auto turn on if yours has one.
I would like to have been more help, but without the manuals I can only give you general type thngs to look for. These type of receivers are all so different and all so complicated to operate. The days of just turning on a stereo, selecting your source and turning up the volume seem to be over.
Let me know if you need any more assistance from me.
Dave
p.s. Very nice system you have, when you get the Kef working I think you are going to just love this system. and Onkyo has the best quality receivers in their price range.
Jun 27, 2008 | Onkyo TX-SV525 Receiver
85 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
