Question about Cameras
My samsung digimax d53 lens shutter is stuck halfway open no matter if the camera is on or off. wht should i do?
Shutter stuck half way on my samsung camera what should i do
Posted on Dec 05, 2009
Samsung digimax d53 beeps then shuts off with lens stuck out
The camera lens is jammed, caused by dirt or worn out gears. a camera technician would be solution but not cheap, or you can take matters in your own hands and try a risky trick "NOT RECOMMENDED" take the palm of your hand and sharply hit it around the lens housing and applying power as you do so in an effort to get lens to retract, if you are lucky it will work or make things worse.
Mar 10, 2012 | Samsung Digimax D53 Digital Camera
Samsung Digimax D53 will not stay on
This is most likely a lens failure. Try contacting your manufacture if your camera is still under warranty. If not, try contacting your local electronic repair shop to get it fixed. Hope this helps!
Dec 07, 2009 | Samsung Digimax D53 Digital Camera
Shutter wont open
Try to replace the battery with rechargeable ones and if it doesn't work, you may contact Samsung Customer Service 1-800-SAMSUNG and set up your camera for repair.
Jan 10, 2009 | Samsung Digimax D53 Digital Camera
3 beeps
had the same problem with my D53 eneded up buyin a new camera pulled the D53 out the other day was going to toss it then i noticed the lense was just a lil crooked i played with it a freed it up camera works great now
Sep 23, 2008 | Samsung Digimax D53 Digital Camera
Lens stays neither closed nor opened when power off
try to slightly push it in slowly while it is going in manully
Apr 03, 2008 | Samsung Digimax D53 Digital Camera
Samsung Digimax D53 beeps and shuts off
I had the exact same problem. Camera turned on but turned off soon after, with lens still outside. I noticed the lens was crooked as if it was stuck. I pulled it out and I heard it click into place, for a second I thought I had broken it. I then turned it on and everything was working again ! Whew ! Problem Solved :D Good luck!!
Mar 15, 2008 | Samsung Digimax D53 Digital Camera
Samsung Digimax D53 camera
lenses are jammed. send it to a service technician. sorry.
Oct 03, 2007 | Samsung Digimax D53 Digital Camera
I need help...Samsung Digimax D53
Go to the following url and you will find the driver and manual: http://www.samsungcamera.com/customer/download/cus_down_main.asp?page=6&keyfield=&key=
Sep 28, 2007 | Samsung Digimax D53 Digital Camera
Cameras Logo
143 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
