Question about RCA D52W19 52" Rear Projection Television
D52W19 Screen Flicker
I just replaced the flyback transformer on my RCA D52W19 TV. The picture displays, but now I get horizontal scan lines at the top of the screen, and every 5 - 6 seconds the screen "jumps" to the side, or it flickers similar to a CRT when it degausses. As far as I can tell, all connections are solid. Any idea what could be causing this?
I'm not sure if it could be a bad connection on the flyback, or the new part is faulty, or if something else went bad when the original flyback burned up. Any help would be appreciated...I'd like to fix this myself if at all possible.
  • steven72_510 Oct 05, 2008
    I pushed the wire in as far as I can, but one problem is that I was not able to pull the wire out of the old FBT, so I had to cut it. When I pushed it into the new FBT, it is almost too short, so I'm not sure if it can really fit all the way in. It might be best if I could put a new HV wire in (one that is long enough). There seems to be a plastic fitting on the FBT that "grabs" the HV wire when you push it in (which is why I could not pull it out of the old FBT and had to cut it). Is there a way to pull this wire out of the FBT to replace it, or is it in there permanently? Or is it possible to splice a piece of wire in to make the HV wire longer, without causing any interference with other components (due to the high voltage)?
    Thanks for your help!
  • RCA Master
  • 5,138 Answers
Go back to FBT check and make sure your high voltage wirer is in good.
Posted on Sep 24, 2008
  • ladywinn
    ladywinn Oct 09, 2008
    The wirers twist out like a screw ,yes get another heavy duty wire also make sure you splice tip at end of wirer a small part should be pointing out in order to go down into small hole to make good connection.,also if you splice on another wire use heat shrinking tube to cover where you spliced.
How do i fix my crt sharp 21G2-s tv whose screen is total black when switched on?
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Feb 18, 2015 | Sharp 21" Multi System Stereo TV
We replaced the transformer for our RCA F27650. It was sparking and now it is not, but now the screen won't turn on. It is just black. We hookd all the wires up like they were. we can hear sound, but...
Hello
Along with the flyback transofrmer, its horizontal output transistor also must be replaced. I don't know whether you have replaced it or not. If not, replace it too. It can be located very near to the flyback transformer, a three terminal component, black in colour, usually screwed to a metal heatsink. Then switch on the TV and measure the video output voltage at the video output card pluged directly to the picture tube neck. The collector of the video aoutput transistors must come around 145VDC. If it also is there, advance the screen control on the flyback transformer to get a raster. If that voltage is not there, it means that the flyback transformer is not working, and horizontal oscillator stage should be checked for oscillation, check the lined drive transformer for its primary winding open, Check the entire horizontal oscillator section. The collector point of the line drive transistor, the transistor that drives the line drive transformer, a small transformer soldered diretly to the printed circuit board; should be checked with frequency meter. The frequency at that point should come around 15525HZ approx: OK.
Mar 19, 2011 | RCA F27650 27" TV
Three coloured lines appered on the screen - no picture
If there is no picture and 3 vertical lines in the center of the screen, stop. Turn off TV. You have no horizontal deflection happening. Lines will burn into crts and be permanently visible after repair.
No horizontal deflection is caused by Horizontal sweep circuit failure, maybe flyback transformer and associated components. More than a simple do-it-yourself repair.
easyab
Apr 22, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
My RCA console tv has white horizontal lines accross screen, picture is very light and sound is ok, very frustrating. I know its an old tv, but appreciate any response. Thanks
Cold solder joints on the flyback transformer circuit board - probably because RCA used feed-thru steel rivets on their boards. Re-solder the connections using a good solder flux for clean solder joints and this will fix prob. The joints with the dull, pitted finish are the problem joints.
S. Hampton
Jan 26, 2010 | RCA G35773SK 35" TV
I have hdtv rca d52w19 green power lights shows
Hello Chris this problem is coming from your high voltage circuit which consist of the flyback transformer and the horizontal output circuit, the most common problem when it is acting this way would be bad soldering on the flyback transformer or defective transformer but keep in mind it can also be caused by the horizontal circuit or a faulty lamp as well can cause this problem, what i would recommend is to have a tech come out to service your tv set this should not be an expensive repair since most of the time it is just bad soldering on the flyback thank you hope this helps.
Aug 27, 2009 | RCA D52W19 52" Rear Projection Television
RCA F32650 32" White lines with hazy white flickering
Absolutely right about the transistor and also check any adjacent resistors to the transformer and to the line output transistor. Good luck.
Sep 19, 2008 | RCA F32650 32" TV
RCA D52W19 Flyback Transformer
This transformer does not come with the hv lead,if the arch is coming from the side of the transformer,cut the side of the plug were it goes into the transformer and the lead will come out,there is no voltage stored on the hv lead after the set is unpluged for a few min.,the transformer you can get at any rca repair center.
Mar 21, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W19 Flyback Transformer Replacment guide
The picture tube can hold a charge.with a jumper connect one end to the ground wire around the picture tub. attach the other end to a screw driver and push it under the red cap on the picture tub. that will discharge it.. Remove the transformer from the board by disordering all connections. Insert the new fly and solder. from the old transformer follow the two leads on the side to the screen board at the picture tube. one at a time connect the new transformer leads to the socket and board. part number for the FBT 259296 $50.39 from www.the parts store
Mar 21, 2008 | Televison & Video
Horizontal line
It looks like the squeal or high pitch is produced by the flyback part # 257805. Also check the the secondary side of the power supply for around 130VDC if that voltage is found to be lower than 120VDC I would suggest to replace CP80 with a 100 mfd@250 vdc. Part # 218374
Globalsemi.com has these parts, for the flyback transformer just type in search for FLY-391, this one is cheaper than the genuine(257805) fly back.
Good Luck.
Jan 17, 2008 | RCA F36650 36" TV
T.v. not coming on ,turned off by itself with an arc noise
The part is known as a flyback transformer.. it will have to be replaced.. also the horizontal ouput transistor will possible most likely be bad..
Dec 16, 2007 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
123 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
