Question about Hitachi 53UDX10B 53" Rear Projection Television
Red Horizonal Lines
Good picture...after warm up, about 6" red line across near the middle...cut off and cool down, turn on samething happens..
Thanks for the help....KIT #10 upgrade did the trick...
imbigdaddy
Posted on Oct 01, 2008
  • 927 Answers
Good Day;
You may have bad picture tube or convergence problem. Good Luck, big IRIShH.
Phillips plasma. red horizonal lines running thru picture
Nancy and Guest. This is caused by an overload in the Y main and buffers. If you are electronically inclined and want to fix this yourself its not hard, but it is a little pricey. There are actually two problems manifested here, the sparkles are from the y main and the lines are from the buffers trying to compensate. If you're up for the daunting task of fixing this yourself, http://www.fixya.com/support/t1625867-phillips_42
This should get you started. Don't hesitate to emial directly for further help. Cfoley@hawaii.rr.com
May 07, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Red,green and blue lines across screen
I f these lines are slightly diagonal and they all showed up at the same time. you probaly have an open resistor in the ABL circuit. since your set is 13 yrs old, I would not put a penny into it.
You might take the front grill cover off and the panel behind it and find the little black box with 6 little controls 3 are for focus 3 are for screen turn the screen ones ever so slightly counter clock wise. the control in the middle is the green screen adjustment. If the green line goes away try the one labeled r for red and b for blue.
Mar 31, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
System turns to red light standby in the middle of playing
you need to go to your setting and change your automatic shutoff timer. this will cause your system to turn off every 15 minutes no matter what you are doing...
Hope this helps... please rate...thanks
Jan 09, 2009 | Sony Playstation 3 (PS3) Console
Philips tv
You have bad capacitors in the vertical sweep circuit. If you have no electronic repair experience, you will have to take the set into a repair shop as these parts are soldered into a printed circuit board and need to be tested with an ESR cpacitor meter. Good luck
May 26, 2008 | Philips 32PT5441/37 32" TV
Philips 50PFP5332D
I have sound but no picture. At first, there was picture but a lot of red lines running up and down as well as across. There were also two bars in the middle of the screen. I turned it off for a while and let it cool down but when I turned it on there was no sound at all. Do I need to have philips replace it? It's under warranty
May 17, 2008 | Philips Televison & Video
Lines horizonal - seems to be caused by voltage to green CRT
Your green CRT is shorted. To test put your red crt socket on the green and your red on the green. then try turning up red control if the green now works its not your tube. If the same thing happens with the red socket on the green you can be sure its the green CRT if the green works properly with the red socket, then you have a problem in the green drive circuit and not the CRT. hope this helps.
Jan 19, 2008 | Mitsubishi WS-55313 55" Rear Projection...
Long power up time, wavy "static" lines, and red/orange problems
part of it sounds like your coax cable is not connecting properly. pull it out and make sure the pin at both ends of the coax cable is straight if bent replace coax cable.
Dec 28, 2007 | Hitachi 32UDX10S 32" TV
Red line across top half of screen
Inverter board is bad or video cable loose either behind LCD panel or near video adapter.
Dec 02, 2007 | Gateway MX6438 Notebook
My TV has blue lines,flashes then turns off
Bad blue CRT common problem.....................T.
Nov 09, 2007 | Sony KP-51HW40 51" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
