Question about Whirlpool Duet GHW9150P Front Load Washer
Will not start
Each wash mode LED flashes when selected, but the machine will not start when the start button is pressed - control is not locked. I have unplugged unit and waited 5 min - no help
  • 4 more comments
  • glp133 Sep 18, 2008
    There are no error codes. Only the flashing LED for the selected cycle. The estimated time is displayed, as expected.
    When the "Control ON" button is pressed, the LED for the cycle selected flashes (slowly). Doesn't matter which cycle, each flashes when selected. The machine will not start when the "Start" button is pressed. NO error codes are displayed. I have unplugged the machine and waited 5 minutes, the problem remains.
    The model number is GHW9150PW4, a Whirlpool Duet.
    the whirlpool xPerience (sic) offered to suggest a repairman who could diagnose the problem. Not a lot of help. Guess I'll call the local authorized repair center tomorrow. Thanks
    Unplugged for 30 minutes, plugged back in, same ol', same ol'.
    Lee's insight was better than the Whirlpool help line. I appreciate everyone's comments - time for the repairman.
  • 4,472 Answers
Http://www.whirlpool.com/custserv/index.jsp
You can locate the nearest authorized service center at that link. If you have a moment to accept and rate the solution accordingly it would be greatly appreciated. If you need any further assistance let me know.
Thanks,
Lee
Posted on Sep 18, 2008
  • Lee A.
    Lee A. Sep 18, 2008
    Your very welcome glad I could be of some assistance. If you have any more problems locating service let me know, and feel free to post an update as to how it goes with the repair.
    Good luck and have a great day,
    Lee
    Genius:
  • 2,035 Answers
Please unplug the unit for 30 min and then plug it back and check if it woks
    Genius:
  • 1,550 Answers
This is the first sign of a board fault .
Also chance of bad motor so you need to replace the motor.
Have you made call to whirlpool service center ?
If yes ,
what did they say regarding your problem ?
post back to these question
SAM ANDERSON
    Scholar:
  • 97 Answers
Can you please give us the model and brand of the machine that you have?
    Master:
  • 726 Answers
Is there any codes that is flashing
  • chris07551 Sep 18, 2008
    yes might be better to call that guy you said to correctly diagnose the problem less hassle for you i hope it all works out and just letting you no this problem is still visable to us unless some one is rated a fixya so people might still ansew even no your gonna sort it out have a great day i hope all is well and turns out for you by ,,,,,chris
Was does LOC mean
Hi Holly...your control panel maybe in LOCKED mode....
close detergent tray....press OPTIONS and SELECT
buttons at the same time for about 3 seconds to
unlock. I hope this works for you.
Regards,
Dennis
Sep 28, 2014 | Kenmore Elite 45986 Front Load Washer
Why won't my washer start a cycle? Start button LED just flashes. All other lights are steady. Door lock sounds like it engaged, but nothing happens.
There should be a way to enter the washing machine into service mode to view an error code. Check your user manual and then you should have your answer!
Jul 23, 2014 | Washing Machines
What fault code on a Hotpoint BWM129 does Door Lock LED rapidly flashing along with Delay Start LED flashing intermittently represent?
replace the motors brushes check the filters
and clear any bits of bra wire etc
then reset the machine {usually hold power in and apply the mains}
May 25, 2014 | Hotpoint Washing Machines
This machine was spinning with an uneven load and stopped working so I emptied the machine and took it apart. I found the shock absorber on the tub needed to be put back together so I fixed that problem...
The error E68 means the ccu has sensed a stuck button on the console. MANY times this is a false error and means that either the ccu or interface must be replaced, but SOMETIMES, there really is a stuck button. TRy to run a diagnostic using the instructions I have provided below, let me know if you need any help with it.
1. Press and hold Select and Cancel buttons simultaneously for 6 seconds to reset the control. The buzzer will sound
1 time and "rES" will be shown briefly in the display.
2. Immediately after, rotate cycle selector knob 5 turns counter-clockwise to the second position from the bottom.
Press and hold the Options and Cancel buttons simultaneously for 2 seconds. The control will enter test mode,
the buzzer will sound 3 times and all LED's will rapidly flash.
After entering the test mode, the cycle selector knob can now be rotated to select the following tests:
Rotate the cycle selector knob clockwise from the starting position:
0 turns: All LED's will flash.
1 turn: Drive motor runs; heat source is on. Drying LED is lit. "H" and the control thermistor reading will toggle
back and forth in the display.
2 turns: Drive motor runs; heat source is off. Cool Down LED is lit and "AF" (Air Fluff) is displayed.
3 turns: Drive motor runs; heat source is off. Drying and Cool Down LED's are lit and numbers appear in the
display showing moisture sensor readings. Opening the door (press in on door switch plunger) and placing
a finger on the both moisture sense bars at the same time will make the numbers decrease. In controls that
do not have a digit display, the More Dry LED should be ON. Opening the door (press in on door switch
plunger) and placing a finger on the both moisture sense bars at the same time will make the Damp LED
come on.
4 turns: Drive motor runs; heat source is off.
Key test:
a. When the Temperature key is pressed, all the temperature LED's should light.
b. When the Dryness key is pressed, all the dryness level LED's should light.
c. When the Options or Select key is pressed, all the Option LED's should light.
d. When the Start/Pause key is pressed, all the cycle status LED's should light.
e. When the Cancel key is pressed, all the cycle status LED's should light.
5 turns: Drive motor runs; heat source is off. Cool Down LED is lit. Control thermistor reading is displayed.
6 turns: Drive motor runs; heat source is on. Drying LED is lit. Control thermistor reading is displayed.
7-11 turns: All LED's will flash
To EXIT test mode, press and hold the Select and Cancel buttons simultaneously for 6 seconds or disconnect power
from dryer. Dryer will be reset for regular operation.
If you cant even enter this mode at all, your interface will have to be replaced. There is no way to determine whether its the intrface OR ccu, but in my experience, it's usualy the interface that ends up needing replacement. Here is the part to order.
Nov 10, 2012 | Frigidaire Affinity ATF8000FS
My fisher and paykel top loading q washing machine won't start. It beeps and lights 5 and 8 come on. Any ideas what the issue might be?
That is fault code 9 machine not sized
9. (00001000) Size Switch Error
The Display size switch setting does not match that which is stored in memory.
Action GW Machines: Reselect the size of the machine by using the SIZE SETTING
MODE.
To set the size switch, turn the power on at the power point and off at
the console. Press and hold Wash Temperature Setting Up then
press Power. SmartDrive will give 4 short beeps and the pattern of
LEDs will change.
One of the following buttons needs to be pushed to lock the size into
memory.
• Press Wash Temperature Setting Up, the Cold LED is on for 5.5kg
(560mm wide).
• Press Water Level Up, the Low Water LED is on for 6.5kg / 7.0kg
(600mm wide).
517790C
35
• Press Spin Speed Up, the Spin Hold LED is on for 7.5 / 8.0kg
(650mm wide).
• Press Power to confirm the setting and also exit this mode.
Action IW Machines: To access Size Setting Mode, push and hold the Fabric Care button
and then press the Power button to enter Size Setting mode. Select
the correct size on the display by pushing the Adjust button to
highlight the correct size. Size setting is then achieved by pressing
the Power button. Powering off will set the size into the memory.
Note: Fault code 9 will only be logged into the memory of IW machines. GW and MW
machines can display this fault but it will not be recorded.
Aug 13, 2012 | Fisher and Paykel Washing Machines
Hi, I have a duet washer that won't turn on. The "Control On" button is blinking and when I press the "Hold to Start" button, nothing happens. And ideas?
Open and close the door.
The door has to be opened between wash cycles.
Check the door switch/lock unit
using the diagnostics listed below.
If door is locked, Drain the unit.
Check wire harness for connections.
Check the touchpad/LED assembly.
Starting the test mode:
Close the door
Press Control On button
Select the DRAIN/SPIN cycle
Select NO SPIN by pressing the SPIN SELECT button,as needed,
Push Prewash Option button 4 times within 5 secs.
C:00 will show in the display.
To advance to the next step
Push Prewash Option button 2 times.
Here are the codes:
C:00 check door lock system actuator
C:01 Check cold water inlet valve flowmeter
C:02 check dispenser motor
C:03 check hot water dispenser
C:04 check basket rotation MCU,Motor
C:05 check heater sensor
C:06 check Drain pump
C:07 check Motor or motor control unit
C:08 check Motor, MCU control
Dec 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine
press and hold the unlock button for several seconds. that will unlock it. However, mine still won't start in any mode.
Jan 20, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
LOC code flashing on washing machine
Pressing the options and select buttons simultaneously for 5-10 seconds worked. For me it happened this way: on the first attempt, with the indicator lights already "timed-out" and off, pressing and holding the options and select buttons simultaneously for 5-10 seconds caused the lights to come back on and flash the "LOC" code again. But holding the options and select buttons together for 5-10 seconds a second time caused the indicator lights to stop flashing, and allowed me to start the cycle.
Dec 01, 2007 | Frigidaire GLTF2940ES Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
