Question about E-Machines eMachines Desktop PC
Start up issue...
My computer model is t3256. it'll turn on , i can hear the loading process and the fans are working.. but then it completly shuts off!. then i have to turn the switch of.. wait a few minutes and do it again.. and same process. so i bought a new power supply since it came with a 350 i bought a 480 i belive and threw that on... still same issue.... should i start saving up for a new one? what are the suggustions? and should i get new parts? me_srey_chan@yahoo.com
  • channyx904 Sep 19, 2008
    hey azkey.. ok i've tried what you've told me.. after that was done... i started it up.. still the same thing. Am i doing something wrong? well other than just taking the heat sink out and cleaning it. what should i do from here on?
I have the same T3256 emachine. It starts up then quickly shuts down. Sometimes it'll run for a few minutes and then shut down. I too replaced the power supply for 80 bucks with the same result. Then I thought, the switch is not a toggle on/off switch, its a push in, spring loaded type. I opened the front of the machine, removed the switch from the snal clips, open the switch (boy its small) vacuumed all the dust out when i replaced the power supply, and simply claned the internals of he switch. bw careful, there's a small spring that is easy to lose! I just did the cleanup thing again today. the firs cleaning lasted 6 months and it didnt start for nearly 4 years. So dont give up!! All I did was just scrape the contact wih a pointed knife until it was shiny again. Be sure to clean both sides.
Posted on Dec 14, 2009
    Sergeant:
  • 300 Answers
I love eMachines , I have a nice nforce2 FIC board from tower T3395 but lets get to your problem
from what you've described , the computer powers on then shuts down quickly
that means a serious problem , my suggestion there is not to throw in the towel just yet
1. remove the cover and have a looin in there to see if it's all dirty
Dirt and Dust can cake up the CPU fan , and cause a thermal shutdown.
Heat is also an enemy.
2. make sure you blow it all out with a can of air or if you have no can of air
take off the CPU heat sink assemboly and wash it off , then stick it back on
and no you don't have to really worry about the little pad on some of the heat sinks
just scrape that junk off and use some thermal paste.
keep me posted , I wanna know what happens with this
Az.
Posted on Sep 18, 2008
Not rebooting
Okay, each OS has it\'s own problems when it comes to this. In most cases it\'s not rebooting (presumably you\'re clicking the "restart" button in windows or reset function in the Mac OSX "xx"). First check to make sure that no software is stopping the process of rebooting. Most often software updates may order the computer to do something that you\'re not expecting, either stalling or even stopping a proper reboot as the new updates are installing. This is especially true of Mac OSX which will update the computer automatically without telling you and then not completely install them until the computer is restarted from a total shut down. The process may produce a blank screen while the updates are installed.
If this is the case you\'ll hear HDD spin up or see the HDD in use light flash (with both SSDs and HDDs). Don\'t interrupt this process or you\'ll create more headaches. Now if it stalls, restart. You\'ll know it\'s stalled because the HDD light will stall and not flash any longer.
If this isn\'t the issue, run diagnostics on your computer. Install and run CCleaner if you can. If it\'s a window\'s computer start up the computer and hit either Tab, F2, F10, or F11, and on the rare occasion Escape to get into the bios and confirm that the hard drives are recognized, the boot order is correct, and that he correct power and control settings are in place. If you can\'t do even that turn on the computer and check to make sure no media is trying to boot. Remove all peripherals from the computer; like CD/DVD/Blu-Ray disks that may be in the optical drive, USB thumb drives and connected external hard drives, any usb connected phones. If you have a non-OS hard drive connected remove it too. Then try to boot. If it then boots you know that either one of the peripherals were interfering with the boot process or that the computer was trying to read from the wrong hard drive which has be set as primary.
If none of these steps solve the issue, start with hardware; check for correctly seated connections, RAM, cables, etc. Look for damaged ribbon, heat damage on the motherboard. Check the power supply. Flash the bios by removing the CMOS battery for a day and then replacing it and restarting the computer.
Check that the hard drives are working and not damaged or faulty. This can be done by connecting it to other computers.
Attempt to start the computer with another medium, like a live CD or USB of Ubuntu.
If the live CD or USB boots, then you can safely assume it\'s a peripheral or hard drive, and not the power supply, ram, or main board.
Lastly, always check the simplest things first. Make sure that the computer is plugged in. Make sure that the monitor hasn\'t been connected to the wrong video output. Make sure the monitor is plugged in and working and on when you start the computer.
There is the best answer I can give you.
Oct 15, 2013 | Computers & Internet
When I turn on my computer it shuts itself off before windows xp completely loads. I just used it yesterday and it did not do this.
This could be due to overheating. To protect the circuits, the computer will shut down if it gets too hot. Try this, turn on the computer, hit F8 multiple times per second until you get a black and white screen with a number of options. Do not select any of them. Just move the cursor with the arrow key up and down. Does the computer shut down after a few minutes? If so, likely cause is over heating.
Inspect the vents on the sides and bottom of the computer. Are they free of dust and lint? When you use the computer, do you have it on a hard surface or is it on something that would block the air flow?
Can you feel a slight breeze from the vent holes? Use a small piece of tissue paper to help determine if the fan is working. Can you hear the fan? If there is no breeze or fan noise, the fan might be bad and need replaced. Unless you are skilled, I'd then take it to a local computer repair shop to replace the fan.
Oct 05, 2012 | Acer Aspire One PC Notebook
Starts up then shuts down within 3-5 seconds
is this happening everytime you start the machine? What is being displayed on the screen? Do you hear the fans running when you press the power button? Do you hear the disc drive running? Do you hear the cd drive click once and the light on the cd drive door come on for a second or two? Is it posting anything on the screen during the boot process? Is it getting to the actual windows desktop which is where you see your icons? Computers shut down for a reason. Either some piece of hardware is not working such as a fan, or some hardware is faulty (such as the memory, cpu or motherboard), or some software issue or a virus has taken over.
Mar 19, 2012 | eMachines Computers & Internet
My laptop will startup but as soon as it reaches the loading for windows it shuts itself off.
The problem you have can be fan problem.
If the laptop is still under warranty you should take it to assistance.
Mar 01, 2011 | Computers & Internet
My acer computer trys to start up when i press the power button but then shuts down by itself before booting up. is this a hard drive problem or something else? thanks, bret
bret5110,
Your system may be running issues during it's POST (Power-On Self Test). Does the system make any beeps or noises (Sounding somewhat like Morse code) during the startup? If so, record the number and length (Short or long) of the beeps, and check with your computer manufacturer for what the computer is trying to tell you. It could be anything from bad RAM, issues with the HDD (Hard Disk Drive), or even the motherboard itself.
Another issue could be the system is overheating. When you turn the system on, do you hear the fan begin to spin? If not, you may need to replace the fan out.
Hope this helps.
-S
Oct 20, 2010 | Acer Extensa 5420-5687 Notebook
My computer wont boot up the fan and light turn on for a second then goes right off....
With the little bit of information presented, it appears that this is possible a power supply problem. One thing you can try is to unplug the power adapter from the laptop, remove the battery, then plug the power adapter back into the laptop. Then try to turn it on. If everything comes up normally, then the problem points, potentially, to the battery.
Hope this helps!
Feb 18, 2010 | HP Pavilion dv9000z Notebook
Hp Pavilion dv9000 powers on, then shutdowns, and keeps repeating.
Try it without the battery inserted with the AC adapter.
Jan 04, 2010 | HP Computers & Internet
When i turn on computer screen is blank and the hard drive light is a solid amber for a minute then nothing....bad video card? Does same on two different monitors.
Video is on-board the motherboard on this model BUT you can buy (or borrow) a video card pretty cheap. When the computer starts up, do you hear any 'beeps', etc.? Might be something other than the video card...
Nov 21, 2009 | E-Machines T3256 PC Desktop
My lap top worked just fine in the morning and went into sleep mode. The computer was unplugged so there isn't a power surge issue. I've tried shutting it down by holding down the power key, I removed the...
try the following steps.
1.remove the battery pack
2.press and hold the power button for 30 seconds.
3. plug in the ac cord to the wall and to your laptop, (make sure the light indicator on ac adapter is on)
4. press the power button once to turn on
IF this process fails, more likely you have a motherboard issue. South Bridge chipset may need to be resoldering or replaced
hope it helps yuva
Mar 26, 2009 | Computers & Internet
Acer travelmate 2420
Its sure the heating issue in your scenario...try cleaning the thermal grease and putting new......get the heat sink and fan free of dust
Nov 10, 2008 | Acer TravelMate 2300 Notebook
E-Machines eMachines Desktop PC Logo
189 people viewed this question
Top E-Machines Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
