Question about Bosch Dishwashers
The dishwasher blade seems to hit the large plates
Thankyou for your reply, we have solved our problem, simply by moving the top try up!
Regards Jan
Posted on Sep 20, 2008
    President:
  • 1,462 Answers
Check if the top rack is adjustable in height - usually there is a choice of positions
Posted on Sep 18, 2008
HOW TO ADJUST BOTTOM BLADE OF MY GE PROFILE DISHWASER
What do you mean "bottom blade"? Do you mean the lower wash arm? There is no "adjustment" built into the dishwasher, but if it's hitting the heater element (or its supports), you might be able to bend it slightly. If it's hitting the lower rack, make sure your rack has all of its wheels attached, and that it's not bend down.
Sep 25, 2014 | GE 24 in. Profile PDW7800 Built-in...
Blade spins and hits side of bowl
Get in touch with Kitchen Aid, that should not be happening.
Feb 19, 2014 | KitchenAid Food Processors
Ge 2800 dishwasher
Try to start the pump with a kick on blades. If it starts, the start capacitor is broken.
Nov 18, 2017 | Dishwashers
I need a new blade were can I find one
Amazon.com seems to have quite a large selection of "replacement blades" but you will need to look them over to see if one fits your exact needs. Good luck!
Dec 31, 2011 | Air Hogs Spinmaster Air Hogs Havoc...
I have a Babylock 5260 serger and have changed the blades before but this time when I changed them I can't get them to align correctly. the top blade comes down and hits the bottom blade. I cant figure out...
First make sure that both blades have no burrs on the them from hitting pins. Then set the lower blade so that the cutting surface is flush with the surface of the needle plate. Then adjust the upper blade so that when it comes down to it's lowest position on the downward stroke of the cutter arm, that the cutting edge comes down past the lower blade at least 1MM. That will ensure a full cut of the blades.
Apr 26, 2011 | Sewing Machines
My fence is square to the table. How do I set the blade so it is square to the table? There is a 1\8" difference in the distance between the front and back of the blade in relation to the groove the miter...
I'm betting that the table isn't square to the blade. My Cabinet Makers Table Saw does the same thing - the top plate (the big heavy cast iron plate that weighs about 50 pounds) sits on top of the sheet metal box that houses the motor and motor lift. This cast iron plate is held onto the sheet metal box by 3 screws (usually).
Loosen the 3 screws and the cast iron plate can move around on top of the sheet metal box (the holes for the screws are large enough to allow 1/8 inch movement). Looking down from the top, you can rotate the cast iron plate clockwise and it will move the front of the blade closer to the fence and the back of the blade away from the fence. Counter-clockwise does the opposite.
For the best adjustment, use a dial indicator mounted to something that slides in the track of the table top. Position the dial indicator agains the blade and slide it back and forth in the track of the table top. This will accurately set the table top to the blad (so they are parallel within 0.0005 inches).
Then check the accuracy of your fence (sounds like this is good). Don't forget to check the alignment of your riving knife/guard & splitter to the blade (if it's off you can't feed wood because it will hit the splitter).
Oct 07, 2010 | Delta Machinery 3 HP Left Tilt Unisaw with...
The motor makes a weird whirring loud noise but the gears seem to be turning still the arms are still turning and the water is going in fine it seems to be any time the dishwasher is on and in any cycle....
So it turns out that it was the disposer blades right behind the motor that were causing the problem. I took the filter off of the drain and found I had a piece of glass and a plastic army man gun trapped in the filter to the drain that the blades were hitting and stuck on. I took them out made sure the blades spun freely and then replaced the filter. It works as good as new!
Feb 15, 2010 | GE GSC3400G Built-in Dishwasher
Arms don't seem to be spinning
chances are there are either dishes that are too high or utensils dropping down in the way. Adjust the height of the racks to accommodate your large dinner plates.. also spin them by hand and see if the spin easily.. if not could be several problems.. also clean the filters in the bottom of the dishwasher. Remove the arms and check for blocked jets.. I found rice in my jets. Rice should be rinsed off the plates first... many people have rice issues.
Dec 13, 2009 | Maytag Dishwashers
Height of top shelf to low for plates
sorry but that can only be remedied by a different unit
Sep 19, 2009 | Whirlpool 24 in. DU920QWD Built-in...
Dishwashers Logo
121 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
