Question about Kenmore 3.8 cu. ft. HE3t Front Load Washer
Should the washer be hot after the rinse cycle?
My wife and I just purchased a Kenmore HE3t washer and dryer for our new house, and we're not sure if the washer is working properly. Originally, the hot and cold water lines were switched (due to the previous homeowner installing everything backwards). We realized this after the first load came out steaming.
I followed the pipes from the water heater and switched the lines to ensure that the hoses were hooked up properly. I know that they are, because the cold hose is cool to the touch, and the hot hose is warm to the touch. However, the next load still came out steaming hot.
Both loads were done on the same cycle (normal), with a cold wash selected. But regardless of the wash temperature, a cold rinse is supposed to be used. So why are the clothes coming out hot?
  • meblackwood Feb 03, 2009
    I have hot wet clothes after a cold water delicate rinse.
  • 706 Answers
Try cycling a cold/cold wash and see how that comes out.. if it comes out hot then your water inlet valve is letting hot water in when it shouldn't.. conversely, try cycling a hot/hot wash and see that it does indeed come out hot... ( quick tests to verify performance)..hope this helps.
Posted on Sep 18, 2008
Kenmore washer will not go into the Rinse cycle. I just purchased the washer, and whenever it is ready to begin the rinse cycle, it stops. I even let it go, thinking that it may need a few minute to...
Is this washer new or did you by it used? If you bought it used, then the problem is likely with the lid switch. If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Feb 15, 2011 | Kenmore Washing Machines
Kenmore 110 model purchased in 1987
really? that's unusual...sounds like the mixing of the hot/cold water is not working. could be control panel, or the actual valves.
you particularly handy, or do you usually have someone do this sort of thing.
Apr 25, 2008 | Kenmore 93702 Top Load Stacked Washer /...
HE3t Washer Problem -
Clean out the drain pump, if this doesn't resolve it then replace the drain pump,this will resolve you issue.f09 means slow drain or no drain.
Oct 30, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore he3t door locked cant reset or open
Kenmore HE3t sanitary cycle setting has changed. Water temp selection only allows Hot/Cold selection but should offer the Extra Hot selection. All other settings test out properly. Is there a way to reset factory settings for cycles?
Jul 08, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore top load water temp switch problems and hot water rinse
Hi, Switch the hoses around going to the mixer/inlet valve. I am sure this will take care of the problem.
If not, please let me know so I can assist you further.
Vic
Jul 01, 2009 | Washing Machines
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
What causes the HE3t washer to stop in spin and rinse cycle?
Sometimes the unplugging helps, or hitting "Cancel" several times.  Guaranteed to work though is to remove top, reach down the top to the door lock.  (Tight squeeze and need to be a little tall to reach) Once your hand is down there, on bottom of lock mechanism is a small handle that must be pulled straight down and manually unlock the door.  This can also be accomplished by removing lower front panel and reaching up to do the same.   BTW, while in the top, make sure all the electrical connections are tight.  I found some loose before, probably from the spinning action.
Dec 06, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore elite washer problem
sounds as if you have a drain issue, most common cause of fault is theres something stuck in the pump housing. remove the lower acess panel(3 screws along the bottom of the forn of unit) youll gain acess to the pump housing, remove the large cover to the "button trap" by uncscrewimg the cover, it will be righthin front of you in the center of machine when cover removed, im sure youll find your blockage within there
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
HELP my clothes and sheets are being held hostage !!!!
first unplug the power cord and plug it back.
select drain/spin with no spin after the cycle completed the door will open.
Jul 29, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
No rinse
Make sure that you have both, hot and cold water connected and turned on. Some models will not advance through rinse if one of the hot or cold is off. See if this solves the problem, Catriver.
Jul 21, 2006 | Kenmore 80754 Top Load Stacked Washer /...
Washing Machines Logo
229 people viewed this question
Ron Lankford
Archaeology
Archaeology
reliableservice
