Question about ASUS A7V400-MX Motherboard
No response to my microphone
I plug my microphone to the microphone jack. I test the mic and it does not appear to respond. my microphone is new. Is the jack perhaps not connected to the motherboard
adsarangani@hotmail.com
  • 37 Answers
1st try to check if the driver of your sound card is properly  installed in your operating system, if youre using windows it will be on the device manager 2nd if it is installed or its not showing then 90% would be a hardware problem on your sound card or the jack itself
Posted on Sep 18, 2008
Motorola BPR 40 will transmit,but not receive through the microphone. Works fine as a handheld
You may have one of three problems: Your audio accessory jack is bad, you are using the wrong mic for the radio, or your mic is bad. Try the mic on a known good BPR40 and if it test good, if so, your BPR40 with the problem needs a new audio accessory jack. (Repair is available for this model.) We have found the BPR40 will only work properly with the remote speaker mic designed for it, despite some other Motorola mics appearing to fit the jack. Construction grade mic PMMN4013 is a good option, as is the lightweight PMMN4077.
Jul 08, 2015 | Motorola Radio Communications
Can i work this mic with my computer?
Yes. You should be able to plug it in it your microphone jack. First, find the mic jack. it should be located right next to the headphone jack. Open your sound dialog. You can find it by right-clicking the volume control and selecting recording devices. Look for your microphone in the dialog. It should have a green tick on it. If it doesn't, select it and click "Set Default". (note: your microphone may not show as a separate entity. if not, select your default microphone and test it by speaking into the MV29. The level should change)somervta.jpg
Jan 20, 2011 | JVC MV29 Dynamic Microphone (MV 29, MV-29)...
I plug in my logitech microphone it is the usb microphone used for guitar hero world tour. It has worked fine in the past but now it doesnt. What do i do!?
Plug in your mic
Check your audio settings
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
If the mic fails to respond - Interrogate your Device Manager for 'information triangles' indicating driver problems
Jun 19, 2010 | Mri WebCam
How to connect a microphone to Logictech z-340 ?
Hi there and happy new Year , Your Microphone has to be connect to your PC in the Red or Orange Color COded Jack Input , it cannot connect too your Speaker System ...
Hope this helped bud
Dec 26, 2009 | Logitech Z-340 Computer Speakers
Turtle Beach X3 Microphone issue
It sounds like the plug and the jack are incompatible.
Check to see that both are what's called TRS connections, i.e., Tip/Ring/Sleeve.
TRS plugs & jacks provide two separate circuits (in this case, one for mic, one for phones).
TRS jacks/plugs are also called "stereo jacks".
Charlie
Aug 14, 2009 | Voyetra Turtle Beach Ear Force X1 Headset
Computer Does Not Detect Headset Microphone
Sound and Recording jacks stop working on the DV6000 series due to the ribbon cable running under the power button. when the power button is pushed it bends the flex cable and over time it breaks the connection rendering the front jacks useless you can buy a new upper button panel for about 20 dollars on ebay
Aug 02, 2009 | HP Pavilion dv6000z Notebook
Broken **** jack casing
Go to specialist.It may be possible to repleace only the mic jack.
Apr 01, 2009 | Dell Inspiron 1525 Notebook
HEADPHONE MIC
The headphones need to be plugged into the green jack on the computer, your microphone needs to be plugged into the pink(red) jack on the computer.
Mar 25, 2009 | Acer Power 1000 PC Desktop
I can not use my computer microphone for live talk my computer acer aspire 5570z, other person to whom I talk can not hear my voice
Make sure the microphone jack plugged into the right jack socket
and that the microphone is plugged into the socket at the front of the pc.
In WinXP go to Control Panel\Sounds and Audio\Voice\Test hardware, this will test your mic by recording from it and playing it back.
If you are using a sound card go through the software setting.
Jan 01, 2009 | Computers & Internet
Line Recording with H5500
i think that audio jack is for headphone-microphone combined (those cable plugs have a three black lines , top for left audio, center for right audio, last line for microphone) so you can use a headphones with mic directly with this 5500. the mic is i said before is the last line. what you need is a monophone plug. (mono mic) i dont think stereo mic will work.
Sep 12, 2005 | HP iPAQ H5555 Pocket PC
ASUS A7V400-MX Motherboard Logo
82 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
