Question about Dometic Rooftop RV Air Conditioner
Freezing up,stops working
I have a new Monte Vista 5th wheel,one month old. The ac frooze up, it was in the low 90 and moderate humitity. How can you prevent this from happening.We travel with our dogs and I'm afraid to leave them in the unit.
  • 1,420 Answers
It will need to be looked at, sounds like low on charge.
Posted on Sep 19, 2008
I have a 2011 cedar creek by forest river 5th wheel and the dometic roof top ac thermostat is giving me an error mesg E4. what does that mean?
somehow somebody activated zone 4 cannot see zone 4 make sure all dipswitches correct if new or if old reset thermostat
Jul 25, 2017 | Dometic Heating & Cooling
My air conditioner is not working on my 2005 Nissan quest se. what may be the problem? it was working fine yesterday. there is plenty of antifreeze
anti freeze has nothing to do with air conditioning
shaking at speed is , tires, wheel alignment, suspension parts or balance and again is not related to air conditioning
working one day and not the next suggest a leak in the ac system and now the low pressure switch is not allowing the compressor to work
So to cover your problems
take the car to an accredited auto ac specialist shop and have it checked for leaks and gas
then take it to an accredited suspension for a thorough check of the front end , then have a wheel alignment done
Oct 04, 2016 | 2005 Nissan Quest 3.5 SE
Lost speed.5th gear stoped working
old car. 5th gear? is this M/T? 1987 ?
A/T? is 4speed
what does stopped working mean .
1: shifter fails to select 5 gear H pattern slot.
2: grinds?
3: cant force it to 5th with clutch depressed.? is free play at spec?
4: raise front wheels off ground, can you get in to 5th now? keyout and running?
5: can you get into 5th parked engine off, and select 5th and then start car in 5th with clutch depresses first step. then slowly very slowly attempt to move car starting in 5th, but dont finish, just feel the gear, feel that its there and not neutral.
not working ,says nothing at all.
Sep 13, 2013 | 1987 Honda Prelude
We have an amana ac. It recently started making a loud noice from the furnace closet which is upstairs. 2 different ac repair companies came out but could not find anything wrong. The line to the outside...
Hello, if the line is freezing there is either a airflow problem or low refrigerant charge. If there is a loud noise most likey the bearings on the motor or the blower wheel is bad and causing a lower amount of air passing over the evaporator coil and thus the freezing of the suction line.
Jul 15, 2012 | Heating & Cooling
I have a Dometic P/N Duo-Therm Model #59516-531 that started running more and more to cool my RV 5th wheel. I checked filter, drain, and noticed the unit was icing up. I turned off AC and let fan run to...
It is probably low on refrigerant. You can only check this if you have a set of gauges. Otherwise, take it to an air cond company and they will check it for you.
Jul 21, 2011 | Dometic Rooftop RV Air Conditioner
2002-v-6,sonata,72,000miles,was told the ac clutch frooze
the ac clutch will quit working if the refrigerant pressure drops too low ... or if the pressure sending switch is bad or if the wire to the clcutch is broken .. the word "frozen" usually means it cant be turned (not that it just doesnt turn) ... if you cant turn the unengaged clutch then thats a compressor failure ... that may in turn damage the clutch as it slips trying to turn the frozen compressor .. if the compressor can be turned freely by hand then thats not the problem .. if the clutch is simply not being turned on then usually thats just low refregerant or a blown fuse, bad relay or bad low pressure switdh . once in a while there might be an open winding on the clutch or a broken wire going to it .. they cant check refrigerant pressure without first getting the clutch to work ... so its possible to jump power directly to the clutch .. it will usually operate and gauges applied to the air conditioner might show the pressure to drop very low .. that would normally turn off the clutch ... just checking for leaks and recharging often is all that is needed ..
Jun 30, 2010 | Hyundai Motor 2002 Sonata
No Power to Duo-Term Thermastat
Can you give me model #'s of thermostat & AC unit, as well as upper unit? Number of or at least a description of thermostat, and numbers for ceiling assy should be visible when filter taken off, as well as # for upper unit should be tagged on bottom of unit on roof.
Jul 17, 2009 | Heating & Cooling
After approx 40 min of highway driving the AC stops blowing cold
The frosting of the line is normal. Did you use a gauge set when charging the unit? AND, most important, Did you evacuate the system before putting in the freon? Very important.What was your final low side reading and your final high side reading?
Jun 02, 2009 | 2003 Hyundai Santa Fe
Coils on Side by Side Refrigerator keeps freezing
sounds like you need to replace your defrost timer it is in the front underneath the fridge if you pull off the front kickplate you will see it in there
May 01, 2009 | Refrigerators
Air conditioner is flooding the house
have a tech properly charge the unit.The water is prolly from an ice buildup.there will be a drain coming out of the evap coil....it may be plugged also.
Aug 25, 2008 | Goodman CLQ36AR49 Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
121 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
