Question about Coleman Powermate Premium Plus 6250W Portable Generator
Generator plugs doesn't match cord
My 5kw Coleman Powermate generator has two 110v receptacles and two 220v receptacles. Both of the 220v receptacles are the 3-prong blade type. My six circuit Reliance ProTran transfer switch has the 4 prong female twist lock. Both ends of my 30amp 4-wire cord are twist lock. The end for the transfer switch is no problem. My Coleman manual states if I am going to use the 220v receptacle to power up any 110 circuits, I have to use the transfer switch, which I intend on doing. It also says I have to have an adapter plug inserted into one of the 110v receptacles. Something I didn't understand about floating and bonded grounds. It says the ground and neutral terminal on the adapter plug has to have a jumper wire connecting the two together.
I was going to buy a three blade male plug that fits the configuration of the 220v receptacle on the generator. I thought I could cut off the male end of the 30amp twist lock power cord and hook the wires up to the new plug. My plan was to just connect the white neutral wire and the ground together on the new plug. Will this be the same thing as making an adapter plug and pluging into one of the 110v circuits? Will it work? Any other alternatives? Thanks, Steve
    Problem Solver:
  • 8 Answers
That is a bad idea use the transfer switch even if you have to hire someone to hook it up right. the cost of messing up is way more. and hard wiring is illegal and can get someone killed. around here pull a seal on a meter and they will fine you big time.
Posted on Oct 15, 2008
    Problem Solver:
  • 13 Answers
Hey steve. do you really need 240 volts for 120 v. circuits. the reason you have to have an adaptor plug is because on your 220 volt plug in , 2 of tthose prongs are hot and 1 is ground. for safety you need to get a plug adapter ( a regular 120 volt plug end ) run a ground from adapter to ground on 220 adapter. same with nuetral. you also need to ground your generator. there is usaully a ground lug on the bottom of the gen. Another way. if you dont really need 220 v. is to use both 120v. recepticals on gen. Run 2 chords to tranf. switch. and hard wire it in to switch. another way i did mine . when i lost power in this hurricane. i ran two # 10 chords from my 2 120v. recept on my gen to my breaker panel. when you do this you have to pull the service meter, if you dont when power comes back on it would backfeed through your gen.then i turn all my 220v. breakers i was able to run lights ,ciling fans, freezer, ice box,washing machine and gas dryer , tv's computors etc. . but to do this, you probably need someone that knows what they are doin.
Posted on Sep 19, 2008
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers · I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
No 120v/240 output @twistlock recptacle
The big box home supply centers carry these. match up the current rating and voltage rating on the generator, then buy the receptacle to match.
Jul 27, 2014 | Coleman Powermate Powermate 5000W...
Can you get a 110v generator to run 220v tools
It won't work you have too low a voltage to run 220 bolt
Mar 14, 2013 | Coleman Powermate Premium Plus 6250W...
On our 6250 Generator, the breaker pops continually. This happens when running only lights on our RV, or when using it to run a water pump. It will run just fine and then the sound changes and the...
You will have more available power (and use a different larger breaker already on your generator) if you use the 220 plug instead of the 115v plugs. Have an electrician make you an breakout box separating the 220v plug into two 115v outlets. Or your can replace the push button breakers with better quality 25 amp. Problem is that the 115v receptacles are probably 15 amp. Other solution is to try a 220v pump instead of 115v (more efficient draws less amps). Good luck
Sep 02, 2011 | Coleman Powermate Premium Plus 6250W...
I have a coleman powermate 6250 generator with a 4prong 220v female plug on the power panel. My travel trailer has a 3 prong male plug. How can I convert my generator or is there an adapter that I can...
You do not want to convert anything to a 220 v connection !!!! Your RV is 12 volt DC and 120 volt AC.
Use a 30amp female to 15 amp male adapter to plug in to regular household receptacle on generator. Available at hardware store and RV stores.
Apr 27, 2011 | Coleman Powermate Premium Plus 6250W...
Replacing engine on Powermate 5000W Generator
I would say, yes (given everything bolts up okay), but I wouldn't connect a full 5000-watt load to it.
May 30, 2009 | Coleman Powermate Portable Generator...
How many gal tank is the Powermate 6250 10 KW
Nearly all of the Powermates have the same 5 gallon fuel tank.
I'm a little confused, the Powermate 6250s are all 5Kw generators with 6250 watt surge ratings. Is yours really a 10Kw or did I misunderstand which generator you have?
Carl
Dec 12, 2008 | Coleman Powermate Premium Plus 6250W...
Powermate 5000
20kw means 20 KILOwatts (kilo=1000), so 20kw=20,000 watts
So the Powermate 5000 refers to wattage. 5000=5kw
Sep 04, 2008 | Coleman Powermate Powermate 5000W...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
1,569 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
