Question about Canon PIXMA MP130 All-In-One InkJet Printer
Ink Absorber Hi I have a Pixma 110 - A message that the ink absorber is almost full and to check the manual keeps coming up. I have checked the manual but can't find any reference to 'ink absorber'. Can you help please? Thanks Mel
    Problem Solver:
  • 18 Answers
Service mode operation procedures
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power LED is lit, press the StoplReset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop 1 Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the LED lights in green, press the StoplReset button the specified number of time(s) according to the function listed in the table below.(Each time the StoplReset button is pressed', the LED lights alternately in orange and green, starting with orange.
4 times
Green
Waste ink counter reset
See waste ink counter reset
procedures helaw.
Posted on Sep 18, 2008
Why is my canon ip1800 printer still not printing after cleaning the ink absorber, I still get the message ink absorber is full
Shelly, Did you reset printer after cleaning absorber.
Press and hold the "Power" button and reconnect the power cord. When the printer comes on, release the button. Wait five seconds and push the "Power" button again. This resets the printer's internal memory and overrides the "ink absorber full" error code.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
The ink absorber is full Canon Pixma IP1980 IP1880
How to Clean Canon Ink Absorber
iP1800 ink absorber
Apr 07, 2016 | Canon Office Equipment & Supplies
I keep getting this error message come up, 'The waste ink absorber is almost full - see manual'.what do I need to do as the manual doesnt give details.
According to the user's manual, "Ink used to clean the print head is absorbed by the waste ink tank. When this message is displayed, the waste ink tank needs to be replaced, or the machine requires maintenance". There is no information about how to replace or empty the waste ink tank.
In any case, you can try the following to clear upo the error, but eventually you'll need the waste tank to be emptied or replaced.
Turn on your MP130.
1) After that press: Menu - Scan - Copy - Scan or Menu-Copy-Scan-Copy-Copy in some models, it depends on the date it was produced)
2) Select TEST MODE.
3) Enter NVRAM ACCESS
4) Select SET ABS-M LEVEL TO 0
5) Select OK
6) Keep selecting OK untill you leave the TEST MODE
Then turn it OFF and again ON. Check if the error message is still there
The following is taken from the Canon website, regarding this specific error:
"Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk."
As I mentioned before, I have not found any way or procedure to replace the waste ink absorber nor the necesary replacement part
Mar 22, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Message" waste ink absorber"
There is an absorbent sponge in the bottom of your waste ink container to help contain the waste ink your printer generates when it cleans the print head nozzles. That sponge is probably full and has triggered a "most informative" error message!
Check your user's manual about the procedure for changing the absorber and where to buy new ones.
Dec 01, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Ink absorber
A special service software program is needed to reset the internal counter for the ink absorber.
Check here:
http://www.pdfoo.com/result-service-tool-software-resetter-for-canon-pixma-ix-5000.html
Sep 01, 2009 | Canon Office Equipment & Supplies
Cannon printer, model PIXMA MP130/110, waste ink absorber is full
cannon printer pixma mp130/110 waste ink absorber is almost full how do i fix it
Jul 05, 2009 | Cannon Office Equipment & Supplies
Cartridge jammed / Waste Ink absorber almost full
Waste ink pad or pads are full and need changing.
Under your ink carraige cradle it is,
It will be full, bit of a dirty job.
Hope this helps
Ric.
Apr 17, 2009 | Office Equipment & Supplies
What does ink absorber full mean on Canon Pixma 1700?
my Canon pixma keeps coming up ink absorber full cannot print
Oct 30, 2008 | Canon PIXMA iP1600 Printer
Waste ink absorber on canon iP 1600
u have to clean it mannualy by opening it. if u r not expert give the printer to qualified proffesional
Apr 01, 2008 | Office Equipment & Supplies
Waste tank absorber is almost full ~ message
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible. Press the <OK> button to cancel the error. You will still be able to print for a short period. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Personally, I wouldn't do it myself, I'd inquire w/ Canon about how much it would cost to have it done first...
Maggie B
Feb 10, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA MP130 All-In-One InkJet Printer Logo
42 people viewed this question
old marine
old marine
