Question about YouTube Videos
Just getting started
Is there instructions as to how to start 'you tubing'?
I don't have any idea as to how to start my own you tube.
Help
  • 3 Answers
Its pretty easy to set up, any questions you have are probably here:
http://help.youtube.com/support/youtube/bin/topic.py?topic=10508
if not, ask again :)
Posted on Sep 18, 2008
Vizio M650VSE. works but intermittantly loses picture and sound. sometimes a few seconds sometimes maybe 15 seconds. just started a couple of weeks ago but is getting worse. any ideas where to start?
Had the same problem with mine. Had to replace the main board. Bought on ebay. Not hard to replace. Go to you tube for detailed instructions.
Dec 14, 2017 | Vizio Televison & Video
I need To Replace My Heater Core And I,m Lost. It A 91 3.8 3800 fuel Port Injection. I Don,t Know Were To Start. HELP
What make , model vehicle ? In most cases you have to pull the dash out . Go on you tube an watch a few videos heater core removable , to get an idea what all is involved .
Feb 19, 2016 | Cars & Trucks
I want to go bowling but have no idea how to throw the ball. Any suggestions?
Bowlingballs can be really heavy and you can injure yourself if you don't hold itright. Watch this short YouTube video for some tips before you get started
Aug 01, 2012 | Sport & Outdoor - Others
My DeLonghi dehumidifier is collecting water but not into the bucket. Rather it leaks it all on the floor. I have cleaned the filter and even the coils to no avail. Please help.
The drain tube that drains the water into the bucket is clogged and needs to be cleared.
To do this, you will need at least an 18" long plastic Zip Tie or something similar. (But, NO wire coat hangers) that will fit into the drain tube or hole. Carefully work the Zip Tie into the hole or tube and gently push it forward. You will reach a bend in the tubing, but you will have to gingerly work past this bend. Once the Zip Tie bottoms out or you run out of Zip Tie. slowly pull it back out while rotating it. This will help breakup the clog. Once you start reaching the end of the inserted Zip Tie, be prepared for some water to follow.
The above procedure should solve the problem. Please let me know. Thanks.
May 25, 2011 | DeLonghi DE500P Dehumidifier
I have a Craftsman electric Blower/Vac with no operatorers/instruction manual. I would have liked to use the vac option but have no idea how to couple the pipes together and attach the bag for this...
For maybe getting a manual, go to:
http://www.manualsonline.com/
You will find that you open the bottom vent, put a large suction tube in the recess and remove the blower tube and attatch a collection bag on the housing that held the blower tube. That's all there is to it.
Aug 13, 2010 | Craftsman 4 Cycle Blower/Vac
Instructions?
The little tube is the FINDER scope which you line up with the main tube and use to POINT the telescope.
You have a simple refractor. Read these:
http://www.texasastro.org/telescope.php
http://www.meade.com/manuals/TelescopeManuals/Refractors/Meade-RB60.pdf Instructions for a simple refractor
May 22, 2010 | Sears 127474 Telescope
How can I get the bead to sit in the wheel rim ridge more easily, as it keeps slippng out and into the middle. Thanks
ok, first take tube and tire off rime completely....Place the tube inside the tire with just enough pressure in the tube to hold it in place (first this will eliminate any possibility of pinching the tube and will allow it to seat properly and second it will add counter pressure to help get the tire seated. Start by sliding one side of the tire onto the rim. lining up the valve stem with the hole in the rim. Then either use rim tools (best idea and they are cheap) or your hands (never use metel tools) start working the other side on starting both hands in one spot and moving each hand away from each other until they meet up again at the other side. But my best advise it to get 2 rim tools, $3.00 a piece as you can use them to lip up under the tire and pull it up and over the rim. Make the job much easier. and you can literally put a tire on in under 2 minutes.
Matt- Certified Diamond Back Bicycle Mechanic
Oct 10, 2009 | Maxxis Cycling
I got a fs 66 weedeater hat wont start the carb has been rebuilt now there is too much gas in cylider which is flooding the plug and is blowing out the exaust any ideas
First check to make sure the primer tube and fuel pickup tube are'nt reversed. Primer tube is smaller.. If they are correct then when the carb was rebuilt either the gasket was installed after the fuel pump diapragm or the inlet needle wasn't adjusted correctly. Go to www.Zamacarb.com or www.walbro.com depending on your carb for correct instruction.
Sep 16, 2009 | Garden
I have a 4 tube 4ft flo. light fixture that won't start. I replaced the tubes still won't start. If i play with the switch(turn on & off) i sometimes can get it to light.It is on a 2 switch system...
Hello there. I can definitely help you. Before we get our hands dirty however, let me begin by saying that replacing the fixture is often cheaper than repairing it. That said here is all you need to know to repair it:
http://www.naturalhandyman.com/iip/infelectrical/inffluor.html
Aug 15, 2009 | Electrical Supplies
I have a Ryobi Lawn Hornet MK2 which belongs to my brother and I offered to try and fix it. Two of three fuel tubes broke and he is uncertain where they go (as am I). There is a primer pump with two tubes...
IVe worked out that the tube from the filtered tube ( the lowest part of the tank) goes to the bottom entryof the carb and the other goes to the primer bulb. the other side of the primer bulb goes to the top entry of the carb.So the barb has two entry points,the top being to prime for start and the bottom for ordinary running.I found this works for me.
Mar 09, 2009 | Garden
YouTube Videos Logo
71 people viewed this question
Top YouTube Computers & Internet Experts
Rizwan Hanif
Level 1 Expert
Michael Terence...
Michael Terence...
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
