Question about Jensen JR500 Remote Control
Dont know which buttons are for what
Need to set the codes for my tv but i cant tell which buttons are for what,the letters are wore offon the 5 buttons on the bottom
Need to code my jensen remote control into daewoo vcr.
Posted on Oct 09, 2008
    Problem Solver:
  • 9 Answers
Keys look like this , so I will list them in such -
TV
CABLE/SATELLITE/ANT, AUD(IO) , VCR
DVD
http://mine.remotecentral.com/cgi-bin/files/dl.cgi?file=others/jensen/jr300-400-500-manual.zip&area=other
Posted on Sep 18, 2008
Samsung washer front letters dissapear
Just use a marker to put a dot next to the start button and another mark to indicate different settings. You can look up the settings online
Oct 14, 2013 | Samsung WF337AA Front Load Washer
Hi my tv is the ws-55315 and i turn the tv on the light comes on for a second(the power light) and the tv shuts off is that the bulb i dont know?and how do i fix it
WHEN the power light goes off on front of set, press and hold both the menu and input (device) buttons at the same time for at least 5 seconds and then release both buttons.
Power light will blink an error code: most common is 2 blinks, 2 blinks, a pause and it will repeat code several times.
This is self check and will narrow down what is wrong with your set.
Let me know what code you find and I will tell you what it means.
SD TECH
Nov 06, 2010 | Mitsubishi WS-55315 55" Rear Projection...
I have and old floor modal tv in good condition I have a Rca universal remote that I dont have the program codes and cant seem to fine them online
As we dont know the TV make you can use code search method.
It basically searchs the codes automatically.
follow the below steps to set remote without codes
Code Search:
1. Turn on the device you wish to control.
2. Press and hold "CODE SEARCH".
3. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
4. Release "CODE SEARCH".
5. Press ON/OFF repeatedly until the device turns off.
6. When the device shuts off press and release ENTER.
7. Try using the remote. If it does not function repeat steps 1 through 6
To Get The Code Please Go To Below Website:
http://www.rcaaccessories.com/remotefinder/
You need to select the following information from the drop down list
1.Model of the remote
2.Type of device to which you want to program(TV/DVD/VCR)
If you can find the codes for your /tv please follow the below steps
Direct Code Entry:
Find the code your device.
1. Press and hold "CODE SEARCH".
2. Press and release the TV, VCR or Cable button. If programming an AUX position, press and release AUX first and then press the device type to be programmed.
3. Enter the 3-digit code number.
5. With the device on, press another button to test (volume control/power button).If it does not work, repeat steps 1 to 5 with other codes which you have.
Thank you
Aug 07, 2010 | RCA 6-Device Universal Remote
My tv green light comes on but then turns back off cant watch tv why is that
when you turn it on and then the green power light goes off:
On the front of the set press and hold both the Menu and Input buttons at the same time for at least 5 seconds and then release both.
The green power light should blink a error code at least 5 times: most common is 2 blinks, pause and 2 blinks----
Let me know what error code you find and I will tell you what it means--2,2 is the most easy to fix and common.
SD TECH
Aug 03, 2010 | Mitsubishi WS-55513 55" Rear Projection...
Need factory code for Sentry Safe Model 1610 - know its 5 digits but cant remember - never changed it from factory code but cant find the darn owners manual!
If you need your lost combination, you must send a notarized letter stating you are the owner of the safe. The link below will tell you everything that you will need to get your combination back:
http://www.sentrysafeshop.com/Lost-Combination-Sentry-Safe-Combination-p/lost%20combination.htm
Jun 13, 2010 | Sentry Fireproof Safe
I have a 32 inch Haier TV and my comcast cable remote wont work with it. I need to know how to get my tv to sync with my cable remote.
there is an auto search method....some remotes you can hold the tv button down and then the select button simultanteously for a few seconds to make the light turn red and then proceed with codes, when you get the right code you press the select button again, the light blinks and you are done..... well with out a code its the luck of the draw..... the auto search method is similar to programming the code in....hold the tv button and the select button for a couple seconds until the tv button lights up, but instead of a code.....press the channel up button(that represents the first autosearch code), continue until the tv turns itself off and then press the select button to lock it into the remote...........if you go past the trigger point you can channel down to backtrack.... otherwise drop it in the toilet until it wont work, call the cable company and have them send out a tech with anew remote. they cant charge you for their equipment not working correctly.
trust me, i am a supervisor at a major cable company.
Jan 17, 2010 | Haier HTF20R21 20" TV
Cant change to any channel
Unknown password--chassis ITC008 with TV off press and hold volume down on the front of the tv and clear on the remote for 5 seconds
need RCA remote with clear button
Jan 01, 2010 | RCA 27R410T 27" TV
Eurovox codes we don't know how to input them
Hi, I dont have this box, but found this on another site, hope it helps, and its what you are after, if it is, and you need keys, let me know, good luck.
GOTO MENU PRESS OK ON CHANNEL SETTINGS THEN KEY 1968 TWICE
THEN ENTER YOUR RIGHT KEY TILL YOU GET NAGRAVISION
CHOOSE YOUR PROVIDER PRESS OK
GO DOWN TO YOUR 00 KEY
USE YOUR RIGHT LEFT KEY TO ENTER THE RIGHT ONE
THEN PRESS OK TO GOTO THE NEX ONE
SAVE ON EACH KEY (00 AND 01)
OR
PRESS MENU - THEN PRESS THE YELLOW TEXT BUTTON (BOTTOM RIGHT).
PLEASE TAKE NOTE OF THE BELOW:
TO ENTER LETTER A = PRESS TV
TO ENTER LETTER B = PRESS RADIO
TO ENTER LETTER C = PRESS P-
TO ENTER LETTER D = PRESS P+
TO ENTER LETTER E = PRESS INFO
TO ENTER LETTER F = PRESS RECALL
TO ENTER 1, 2, 3, 4, 5, 6, 7, 8, 9, 0 = PRESS THE NUMBER BUTTONS ON THE REMOTE CONTROL.
ENTER THE PROVIDER & KEYS FOR YOUR AREA & PRESS THE OK BUTTON ( press 4 secs ) TO SAVE. THIS WILL BRING THE CHANNELS BACK TEMPORARILY WHILST A NEW SOFTWARE IS BEING RELEASED.
IF YOU ARE UNSURE WHAT AREA YOU ARE IN, JUST ENTER ALL 3 SETS OF KEYS ONE BY ONE.
E.G. ENTER CW KEYS THEN PRESS OK TO SAVE, THEN ENTER THE NTL KEYS THEN PRESS OK( press 4 secs ) TO SAVE & FINALLY ENTER TW KEYS THEN PRESS OK TO SAVE.
AFTER THIS HAS BEEN DONE, YOU SIMPLY EXIT OUT OF THE MENU & ALL THE CHANNELS WILL START WORKING AGAIN.
Feb 01, 2009 | StarTech.com StarView SV211K 2-port KVM...
Tv protection
Hi.
The set is expecting a pin number to be inserted.
If you dont know or cant remember pin do this.
USE REMOTE CONTROL AND BRING T.V OUT OF STANDBY,
SCREEN REQUESTS PIN CODE,
PRESS STANDBY, PRESS NO. 7 BUTTON FOR 6 SECONDS, THEN IMMEDIATELY PRESS STANDBY (THERE MUST BE NO DELAY BETWEEN LAST ACTIONS).
Do this to the letter it should sort out your problem.
http://dysonmanuals.llc.nu/
Jul 15, 2008 | Televison & Video
Jensen JR500 Remote Control Logo
Top Jensen Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Jensen Televison and Video Expert? Answer questions, earn points and help others
