Question about HP Pavilion zd8000 Notebook
Zd8000 repair My friend says she needs a part to repair her computer. The part is the board beneath the speaker volume button. It is a small board with "JI-HAW AWME11" and "ZYE PAY R-15-8" printed on it. Where can I get that board? "owlvee@yahoo.com" is my email address.... thank you, owlvee
  • 186 Answers
The part you are looking for is with the Part Number 378771-01 in HP Part Store and the price is not available since this part is not available with HP.
Description of this part is : PC board assembly - Indicator LEDs, volume control buttons and mute switch.
However, I found that this part is available for sale through the links provided below :
http://www.sparepartswarehouse.com/HP,Laptop,Part,378771001.aspx
http://www.notebookparts.com/products/description.php?II=11440
I found that most of the websites are showing that this part is out of stock.
Hope this is helpful...
Posted on Oct 06, 2008
What button on remote switches signals from component to AV
Should be a small round button marked 'INPUT' almost dead center of your remote (assuming you are using the original one) between the '-' signs on the volume and channel buttons and just beneath 'MUTE'. Just keep pressing it until AV is displayed. Here is a link to download your manual my friend: http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man Good luck with that :)
Jun 19, 2013 | Element Electronics FLX-2210 22 in. LCD...
Samsung tv LN40B530p7fxza sound Volume stuck on Max.
As a repair man I always hated that--had to disconnect the speakers and use a scope.
Most likely reason is the volume up control---a micro switch beneath the manual button on the set is bad.
These are momentary switches--only supposed to work when touched/pushed---they will feel good but have failed and are making contact all the time instead of just when pushed.
Only way to prove or disprove this is get at the keyboard and in your case locate (they can with set off be checked for resistance--should be no reading) is locate that volume up switch and unsolder it.
If problem is gone (your ears feel better) you have two choices : live with the switch removed and operate for that function with the remote.
Usually they only sell the complete circuit board with all the buttons for a set.
I would if could control volume just live with it gone.
Let me know if questions.
Apr 03, 2012 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Ilgk@gmail.comHad purchased Dell Desk top 580S C13 W7HB from Vijay Sales on 6th June 2010. Got it installed by a friend as I am a senior citizen needing advice on operations also. Generally OK but sound...
The speakers inside desktop computers (if it has one) are very small and do not produce a reasonable volume.
I suggest you purchase a powered stereo speakers and connect it to the audio out connector on the desktop computer. Powered speakers have better sound quality and adjustable volume controls as well as bass and treble controls.
Dec 15, 2010 | Computers & Internet
Only one small speaker is working, it works from left or right outlet, bass isn't working and the other small speaker isn't working. What could be wrong
Your main board located inside the sub woofer that controls and separates the sound
has lost it's ability to switch the sound. You will either have to buy a new speaker system or call the manufacturer to see where a service center for you speaker unit is near you for repair.
This also can be a bad volume control knob either way it will need to be serviced.
Oct 08, 2010 | Logitech Z-2300 Computer Speakers
I am using a creative speaker. bass speaker is working well except for the small ones. is it shortwired or grounded? volume adjustment is also not working. only 1 small speaker is working but still...
navigate to control panel, select sound and audio devices. select advanced the volume control appears then set the balance to be at the center the on the other advanced option, select desktop stereo speakers. thanks.
Jun 22, 2010 | Creative Labs Creative Black SBS350 2.1...
My volume control was working perfectly fine and i could hear the sound perfectly then the green light on my "logitech" volume control turned off so sudden.I checked the cable's seems like everythings in...
inside the sub theres a small computer chip board. unfortunately with jbl this board shorts out very frequently. short of a disassibly process and seeing a burnt spot on the board, the only other chance may be the power pack wich can be replaced with a 20.00 one from walmart
Jul 12, 2009 | JBL CREATUREIIWHITE Computer Speakers
Disassembling the speakers - Compaq Jbl Pro (401508-001)
pry the speaker cover slowly using small screw driver on the side,,it has four locks giong thru..its position two at the top and two at the bottom..it is line w/ the volume control and headset..be careful not to break the speaker cover.then remove the four screws inside the hole where the speaker cover is position.remove also the rubber protector beneath the speaker or under the speaker..it has a lock beneath the rubber covering it..push the lock slowly, be careful not to break it.but even if you break it,it will do nothing..now insert finger in the hole and pull the face or pry w/ small screw driver and lift...
Apr 15, 2009 | HP Compaq JBL Pro (401508-001) Computer...
I HAVE KINYO SPEAKERS AND NO SOUND IS COMING OUT OF THEM IT WAS BEFORE BUT NOW IT QUIT
hi im josh in cebu phils. friend if it enable before and now not and it quits. most of this problem is the audio card or audio socket. these maybe a software or hardware problem. all you have to do first is to check the control buttons be suret was not chek to mute or adjust ir to higher volume if it s low. you can see the button near the time bar right side of the screen or re install your audio driver from the cd. and try to hear it again, if not try to cher\ck your connections like the small wire cable at the back of the speaker check if it wasnt cut. or check the audio socket colored green at the back of the pc. if it still doesnt work replace your audio card if you are using audio card if it is built on pc main board try to buy a audio card and install it.good luck hope i helped you.
Feb 18, 2009 | Kinyo PS-205 Computer Speakers
How can i raise the volume on my dell inspiron 1525
Here's how I fixed mine with Win-VISTA:
1. Click START
2. Click CONTROL PANEL
3. (Switch to CLASSIC VIEW)
a. Click on SOUND
b. Click on PLAYBACK Tab
c. Click on SPEAKERS/HEADPHONES
d. Click on PROPERTIES
e. Click on CUSTOM Tab
i. Make sure PC SPK MUTE is NOT checked
f. Click on LEVELS Tab
i. Slide PC SPEAKER to 100%
ii. Don’t worry about the SPEAKER slider, it’s controlled by the keyboard buttons
g. Click on ENHANCEMENTS Tab
i. Make sure LOUDNESS EQUALIZATION is checked
h. Click OK
i. Click OK
4. Close CONTROL PANEL
Dec 20, 2008 | Dell Inspiron 1525 Notebook
Get Moniter Speakers Working
Hello First of all you need a sound card on your computer with a Spk. (Speaker) or Phones (headphones) Out Jack it might be a symbol of a small speaker or headphones. You have to be sure you are getting a actual sound output signal from this sound card too. If the sound card is not working your moniter speakers would not have a signal to drive it. You also need a 1/8" Stereo 2 male stereo plugs on both ends, one end plugs in back of moniter other plugs in back of computer like I mentiond above. Make sure your Mute button is not selected on your computers volume button usally at bottom right of screen. Make sure the volume buttons are up to aprox 3/4 up also. Then for last on the moniter look in the menu i think you might have to keep pressing the menu button but i kind of forget now but its a Spk setting and volume setting in this speaker setup within the moniter as well make sure this is turned on and set at a higher volume level as well. Thats about all I can say without taking the moniter apart and checking the jack and wires and speakers. I would suggest you take it to a electronics or a tv repair or computer repair person to go any further then this. Hope you take time to read all of this I tried to put every step in here to help anyone out with this problem. Thanks for reading. Ken T
Nov 08, 2006 | Liquid Video A170E101 Monitor
HP Pavilion zd8000 Notebook Logo
410 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
