Question about Roper RGX4634KQ Gas Dryer
Dryer wont heat
The dryer starts but the glow plug does not come on
    Genius:
  • 1,028 Answers
Ck whiten thermal fuse on blkower housing of dryer may be behind back panel..if fuse of ck the flame sensor with volt ohm meter should show a complete circuit..or just jump it out in any case should be 110volts fed to connector going to valve ..also may be bad ignitor (glow plug)may show burnt spot
Posted on Sep 18, 2008
My gas dryer isn't getting hot, I was told it was probably the ignitor, I took a continuity test and got a reading of 80 ohms on my glow plug, I don?t know what a normal reading is for a glow plug....
if the ignitor is lighting or glowing its fine,, what you need to check are the thermostats in the rear of the machine, look here for what they look like and ways to test them
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Jun 14, 2011 | Dryers
I have a gas dryer. the glow plug works but wont stay on
You are likely in need of new coils to make your dryer heat again. If the ignitor glows, the thermal fuses and thermostats are good. The coils sit directly on top of the gas valve, are easily replaced and inexpensive. CLICK HERE for the coil kit to get your dryer heating again. Using coupon code 1050 will save you some money!
Jan 12, 2011 | Whirlpool LGB6300 Gas Dryer
The dryer will not heat. The glow plug glows but the gas does not turn on all of the time, I got it to turn on one time when on the permapress setting.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 19, 2010 | Maytag MLG15PD Gas Commercial Dryer
Rewplaced igniter now dryer wont heat up
The dryer has electic 'eyes' to keep the burner from coming on if the pilot is not lit or the glow plug fails to come on. Be sure the windows to these 'eyes' are clean and in line with the light source (glow plug or pilot flame) that they are intended to sense.
After you replaced the glow plug, does it come on at the start of the cycle?
Aug 21, 2009 | Dryers
Kenmore 80 series gas dryer has not heat
most of these dryers have a little plastic plug on the front, left side. pop that plug out and look inside after turning it on. you should see a red glow. if not, then your ignitor has broken. if you see a glow, then the problem is probably one of the two little coils on the gas valve. these coils will sense if there is something to light the gas [the red glow] and open the valve - if the coils are bad, they won't open the valve
Aug 17, 2009 | Kenmore Dryers
Dryer won't heat.
Check the glow ignitor and make sure it is glowing, if it is not glowing then replace it, if it is glowing then check the gas valve.. But sounds like the glow ignitor is bad and needs replaced, if it is cracked it wont work either so look really carefully, maye even pull it out.
Feb 09, 2009 | Kenmore 63942 Dryer
My kenmore dryer does heat up all the time.
After the glow plug starts glowing a sensor detects this bright glow and turns on the gas which will be ignited by the glow plug and you have flames.
So, it could be this sensor or in the gas valve solenoids. You will need an OHM meter to check this.
Dec 21, 2008 | Kenmore Elite HE4 Electric Dryer
No heat
Check the glow plug.
Take off the bottom front panel, push the start button and look for a red glow. This glow plug is about the size of your little finger and is hard to see when it's off but you will see a red glow if it's working. No glow, replace the glow plug.
If it glows for a few seconds then goes out then the solenoids on the gas valve should be checked with an OHM meter.
Dec 16, 2008 | Dryers
Gas dryer tumbles no heat.
I would change out the igniter, When they start failing hey will glow but not draw enough amps to open the gas switch / valve.
May 02, 2008 | Dryers
Gas burner doesnt ignite somtimes
time to replace your gas coils. those are the two round things on the gas valve. chances are the dryer ignites when first started but as the dryer heats up the coils fail and as it cools again the coils work again. make sure you replace both coils
Sep 19, 2007 | Maytag Neptune MDG5500AW Gas Dryer
Roper RGX4634KQ Gas Dryer Logo
61 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
