Question about Panasonic PT-47WX49 47" Rear Projection Television
Question for Guru slinteriors: about Panasonic PT-47WX49 shut-down problem.
It shuts down itself with a power-swtich click sound. It happens after a few seconds or a minute after turning it on. No LED light blink.
Before it's off, I noticed that the blue image shifted shakily to the right. Is TK392 bad?, so it shuts the power down? Other than this, are there any other parts causing that problem, as well? Where could I buy reliable/trustable parts from, any recommendations on comaptible upgrade chips?
Thanks a lot.
Bill
  • 5 more comments
  • BillTV Sep 18, 2008
    Thanks, Slinteriors.
    I know your name from many posts about the same or samilar problem. Appreciated your posts/answers.
    For my case, does with or without blinks in power LCD after shut-down make any difference? I guess there is no pin difference in STK392-150 and STK392-110, right?
    Looked around the internet about STK392-150 vs STK392-110. Do I need to replace 6 resistors as well (two with each color) as Hitachi does?
    vbmenu_register("postmenu_361502", true);
    Any advice on using STK392-150 vs STK392-180, to replace STK392-110?
    Slinteriors, you are the man.
    Slinteriors, You are the man.
  • BillTV Sep 30, 2008
    Hi Slinteriors,
    Following your recommendation, I replaced the two IC' with STK392-150. The shutdown problem is resolved, thank you for that.
    But now, the color looks wired. The blue appears Blue-green, just like the color of the 4 diamonds' in the rating scale on this FixYa page.
    Any idea?
    hi Slinteriors,
    maybe I need to do some adjustment on Serviceman Adjustments Modes for CLOCK ADJUSTMENT ?
    very appreciated, if you can email me Serviceman manual.
    Thanks.
  • Panasonic Master
  • 8,617 Answers
The stk392-110 ICs may possibly be bad. I would recomend replaceing the stok 392-110 ics with two STK392-150. You can get replacements at the following link, and they provide free installation instructions
http://servicemanuals.vstore.ca/
Posted on Sep 18, 2008
  • 2 more comments
  • Sonny Berry
    Sonny Berry Sep 18, 2008
    the STK392-150 ICs run cooler than the stock STK392-110 ics do. Often if the ICs are real bad they will throw a 3 blink error code, but I have seen other times you wont get the error just a distortion of the alignment then straight into shutdown.
  • Sonny Berry
    if the led were to be blinking 3 blinks then I would suggest replacing all 6 2.2 ohm 2watt resistors, but when it doesnt blink your usually safe with just the two ICs
  • Sonny Berry
    I have seen the STK392-180 ICs not do well in most panasonic models as an upgrade, The 150 seems the better upgrade for most panasonic models.
  • Sonny Berry
    Sonny Berry Sep 30, 2008
    dont have the manual, but you can get one at the following link emailed to you.
Hi, my Panasonic PT47WX49E rear projection tv suddenly shut itself off. It won't turn back on at all unless I unplug it and plug it back in. However, when I do that, the power light comes on but nothing...
Either give me a yahoo or note if light on front of set blinks--count the blinks if it does.
most common is 3 blinks, pause 3 or 5 blinks etc.
Let me know if I can assist you.
SD TECH
Sep 14, 2010 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-51G50CU
HEY !!
ITS A CIRCUIT BOARD PROBLEM ... IC MAY HAVE BLOWN OFF ...
Jan 01, 2008 | Panasonic PT-47WX49 47" Rear Projection...
My Panasonic PT - 47WX49 rear projection wont turn on - it would go on for a second and shut down - then 3 red blinks - so i changed out the IC's now it powers on but immediately shuts down and only 1...
Thats the 140 Volt error. Usually caused by the bridge connectors that connect the two circuit boards or the red HV cable from the flyback not being connected properly
Dec 29, 2009 | Panasonic PT-47WX49 47" Rear Projection...
My picture shut off. Power lite clicks, blinks,no picture
how many times is the power light blinking as thats a error code. 3 blinks is the most famous which means convergence circuit failure.
Oct 26, 2009 | Panasonic PT-47WX49 47" Rear Projection...
TV powers up for literally a second then shuts down (PT-47WX49)
check R517 on the power supply board if burnt replace with 5% 1/4 watt 10K carbon resistor.
Dec 12, 2008 | Panasonic PT-47WX49 47" Rear Projection...
No sound, no picture, power light blinks
i have a model #pt-53wx42f when you first turn the t.v. on it gets shakey and distorted then it shuts down and the power button light starts flashing
Sep 06, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Tv powers off after 1sec being on?
does the led flash when you try to press power after it shuts down, or when it shuts down? If so how many times does it flash?
Jul 18, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic projection tv (shuts down)
Does the power indicator blink? Let me know and I will try to help you out. Just keep responding to this same psot so previous info will still be available.
Jun 30, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Nothing comming on but red light flashing
unit is is shut down ,hsa a fault and to protec furthe damage shuts down,until error is corrected.needs service tech.
Apr 13, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Help please
called h.v. shut down call tv repair shop
Sep 18, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
181 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
