Question about Dryers
Dryer heats but takes a long time to dry
Admiral model ade7000ayw
with the top open, the elements turn on for 15 seconds and shut off for 35 seconds...the vent and vent hose are not obstructed...the fan seems to rotate ok...please help...thank you...jeff
  • titan1175 Sep 18, 2008
    Thanks Rick,
    The lady at the repair shop said that it is normal for the coils to switch off if the top is open becasue of the air circulation. I thought the cooler air would keep the coils on longer.....Thank you very much..The front panel removes easily, but the back and sides are one piece...there is a sensor or switch on top of the elements. I guess that is a thermostat.
  • 706 Answers
Hello Jeff,
You may have a bad overtemp switch that is disabling the dryer heating element ( normally as a safety mechanism to keep it from over-heating and/or causing a fire) from staying on. Many ( but not all) are of the auto reset type and open the circuit if they are sensing high temperatures. When they sense this over temp condition , they open and disable the heater element from being energized. Once the temp drops to less than their limit, they reset and allow the heater to switch on. That would be one consideration to investigate. If you can gain acess to te back of the dryer, you can bypass these switches by shortng the wire leads together.. Do this as a diagnostic only.. and DO NOT leave them that way.. you risk having a fire if you do.. also.. make sure you remove or disable power to your dryer when you are checking this out. If the dryer heater remains on after you short the temp switch leads together, then you wil have proven that the temp switch is the problem and it shoul dbe replaced..Hope this helps you...
Posted on Sep 18, 2008
My Electrolux EDV 605clothes dryer is turning but not heating, heating element is ok possible faulty thermistor, dryer heats up when thermistor is unplugged but has an error code of 5 beeps
I think you're absolutely right exhaust sensor is faulty.
The buzzer will give 5 beeps, all program LEDs will flash for 5 seconds and the dryer will continue with the cycle. The warning beeps and flashing LEDs will occur every 30 seconds.
On Timer Drying programs it will run for the time remaining and in Sensor Drying programs it will run for 90 minutes. As the exhaust air temperature can not be sensed the element will be cycled on and off at a preset amount. The cycling time of the element will vary depending on the amount of time remaining.
NOTE: When this fault exists the dryer can still be used but regardless of the Sensor Drying program selected the dryer will use the 90 minute Timer Drying program, Timer Drying programs will use the selected program, and with both types of programs the element will cycle as above. The buzzer will also still be sounding.
If an exhaust sensor fault is detected the buzzer will beep and the Reminder Clean the Filter LED will flash. The LED flashes at different rates depending what is wrong with the sensor -
Fast (4 per second) = open circuit senor, broken wiring or multi pin plug not correctly fitted to the control board.
Slow (2 per second) = Short circuit in sensor or wiring.
The sensor resistance at different temperatures is as shown below.
Temperature (Celsius) Resistence (Ohms)
55 2960
50 3570
45 4330
40 5280
35 6490
30 8030
25 10000
20 12555
15 15880
10 20260
5 26080
0 33870
As you can see this is NTC thermistor with Negative Temperature Coefficient , means if temperature increasing the resistance decreasing.
Dado
Jul 06, 2015 | Electrolux Dryers
Does the heating element stay on continuously throughout a drying cycle?
No. The element is controlled by the operating thermostat located on blower housing .if its on all the time the hi limit near top of element should open and turn element off that part is nonresetable
Jun 17, 2015 | Admiral Dryers
Admiral Dryer Model #AGD4475TQ No Heat
This is very rare on a gas dryer but I have seen it. If you have already replaced all that other stuff I would say it has to be inside the timer. On one I worked on once I could remove that orange wire and the dryer would function ok so I ordered a new timer, they sent me a bad timer. Same problem. I finally got a working timer after going through a bunch of mess. That fixed it. So if all the other components are working it very well could be the timer.
Dec 02, 2013 | Admiral Dryers
Where is the heating element on an Admiral Dryer, Model ADE 7005AYW?
pop open the top and take off the screw on each side of the front panel on the inside and your element is on the back left corner.
Can't miss it
Apr 16, 2013 | Admiral Admrial ADE7005AYW, ADG7005AWW...
Where is the heating element located in an admiral model no. ADE7005AYW
Take a look at this video to show you how to open the cabinet. The element is on the lower right side.
Nov 05, 2012 | Admiral Admrial ADE7005AYW, ADG7005AWW...
Admiral dyer model ade7000ayw wont make heat
You will need to replace the heating element and the thermostat. They come in a kit and is a simple job to replace them. Here is a link to the kit.
Oct 14, 2012 | Admiral Dryers
My Maytag Model DE410, Series 01, Serial 197938 - won't dry I think the heating element is out. The clothes aren't dry at all - it is on normal dry, but the clothes come out like it's on air dry - not...
Heating element is bad! I have the same exact problem. I Just finished pulling the heater out 20 minutes ago. I ohmed it before I pulled it(showed to be bad) and after I pulled it I found the break in the heating element.
Directions for a DIY!
Turn Off Breaker and Unplug Dryer! Pull two screws near bottom in front. Pull bottom of panel out and the top will pop out. 5x16 inch diameter tube inside on the bottom right is the heater assembley pull the three screws in front and one in back that hold the assembley inside dryer. Unwire two wires feeding assembley. Your done! Only takes about 15 Minutes, Tops!
Lowes Warehouse carrys it. 1-800-476-8160 Part# Y313538 Price $51.71 Ship $7.99 Open 8am to Midnight
Hope you can do this yourself and save yourself some money! Good Luck!
Industrial Maint. Man
Sep 01, 2009 | Maytag Dryers
Heating element only turns red when dryer door is open
You are correct you do have a dead short on the element.You need to replace the element.Hope i fixya :)
May 20, 2009 | Maytag Neptune MDE5500AY Electric Dryer
How to access heating element and thermostat on Admiral ade7000ayw dryer
The top has a hinge bracket in the back. pop the front up with a flat screw driver. you should see the heating element there and be able to access it from that point.
May 21, 2008 | Dryers
Dryers Logo
144 people viewed this question
Top Dryers Experts
Richard Roth
Richard Roth
