Question about Lexmark Office Equipment & Supplies
My printer wont print its hooked up and everything i been trying to fix it for 3 days...i dont know what else to do.
  • 50 Answers
Try printing test page from the computer. using the printer icon in the control panel.
Posted on Sep 18, 2008
It keeps on printing things i dont ask for the next day. And when i want it at the time it wont work
If you're using Windows, it could be a problem with your Print Spooler and your print jobs are getting stuck. Please follow the steps below to fix the issue:
1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
4. Double click the printer icon in the lower-right corner of your taskbar to examine your print job queue and browse to View -> Refresh.
Try to print again to verify that the problem is fixed. If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Oct 11, 2011 | Lexmark X2650 All-In-One InkJet Printer
My HP LaserJet p2050dn suddenly started printing all by itself until the paper tray is empty, time after time. I deleted and reinstalled all drivers on the 3 computer network (one direct/ethernet, 2...
Hi Good day!!! i will try to help you. 1st try to pull out the usb cable that connects your printer and the computer, turn on the printer and check if the unit still printing of it's own. if not the problem is on the printer software. please reply i will try to help.
Dec 02, 2010 | HP Office Equipment & Supplies
My printer wont print but work fine before it's
Does it flash eight times?
If so you might have a full waste tank:
http://www.fixyourownprinter.com/forums/inkjet/23041
It could also be that cartridges have run out.
Aug 28, 2009 | Canon S520 InkJet Photo Printer
Thinking of cleaning the print head? ?
Try this one, Turn on the printer, Take out the inks, remove the printhead, put back the printhead make sure it will snap and you hear a click, put the inks back, wait for the printer to initialize, Press the Menu button, look for Calibrate printer, then print calibration page, then scan it after. Load a regular paper. Then try to print a demo page by pressing Photo and Copy at the same for 5 seconds then let it go. If same problem persist call this no for further assistance 1800 421 6699
Thanks
Aug 27, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
My wGPS606 wont print on my Windows Vista laptop!
I just found a way to enable the HP P1006 with a different print server (Liveprint on Orange Livebox router). Perhaps this might work with the WGPS606 wireless print server?
I set up the P1006 via the print server as instructed (I'm using Vista 32 Home Premium) but no test page would print.
BUT!! (with thanks to another another forum):
I selected printers, then right-clicked on the wireless printer I'd just installed and selected 'properties'.
Under the 'Ports' tab I deselected 'Enable bidirectional support'.
Problem solved.
Hope this helps.
let me inform you that this printer is not compatible with any wireless print server. The drawback is that it is not possible to network such printers. A printer needs a steady flow of data, which is easily accomplished when it is connected directly to a PC, but cannot be guaranteed when the printer is connected via a LAN. Also, these technologies require intensive handshaking between the driver and the printer.
The host-based software uses the computer's resources to process print commands and rasterizing data, taking advantage of the computer's memory and processing power."
Sorry I can't be more upbeat - but its probably useful to know that someone at HP thinks the job's imposible - unless someone out there has a fix?
May 11, 2009 | NetGear WGPS606 (WGPS606NAR) Print Server
TEC 472 Error message- SG: 139, 0010, 064
This is syntax error, the coorect is SG;0139,0010,064....
May 09, 2009 | Toshiba TEC B-472 Thermal Label Printer
I bought a printer from Btother MFC3360C. The paper didn't feed. I attempted many times to get it to work by trying to print some things. I finally fixed the paper problem and the damn thing starts pr
those buttons dont stop whats in the queue. You need to go to your printer icon, right click and select the first tab on the list, from there, you will see all the files being dumped to the printer, right click file and select delete, this will erase everything in the buffer.
thanks adi
Apr 24, 2009 | Office Equipment & Supplies
My WGPS606 wont print on my Windows Vista laptop, its prints with all normall xp windows laptops and desktops, but I recently bought a new laptop and it does not print, the print says error, can somebody...
there is a proceedure for manually adding the printer ports instead of using the wizard on the software disk. Look on the disk and go to the guide .pdf file, the instrucitons are there. i tried it and it worked fine.
Apr 01, 2009 | NetGear WGPS606 (WGPS606NAR) Print Server
Epson 6400
My printer wont print balck.......it prints the other 3 colors. What can I do to fix it.........I have cleaned the heads and done everything I know t do. HELP!!!!
Oct 09, 2008 | Epson Stylus CX6400 All-In-One InkJet...
Printer wont print
Are you using Genuine Epson Inks??, if you get 3 years out of a printer these days you've done well!,
Dec 08, 2007 | Epson Stylus CX4600 All-In-One InkJet...
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
