Question about GE 24 in. GLD5560LSS Stainless Steel Built-in Dishwasher
Drying light keeps flashing
Draying light keeps falshing and beeping. dishwasher will not start. turned off circuit breaker and turned back on same thing happened again
  • 750 Answers
You said,
Drying light keeps flashing and beeping. dishwasher will not start. turned off circuit breaker and turned back on same thing happened again.
It seems you have an electrical fault in the dishwasher and it will not permit the start of the motor,
as a safety guard.
You must have the electrical system checked for shorts .
Otherwise the motor is dead!
huuum,happy to assist you!
How old is the appliance?
If the appliance is 10 years old or more you may not be advisable to put good money into bad! New appliances are so much more efficient today that they can save you a lot of money in energy.
Therefore they pay for them selves in only a few years.
You can buy New and save today.
Find the small privately owned and operated appliance store and you will get better service and good treatment! They also will be the best informed!
Bless You, let me know how it goes.
huuum
Please give me a good rating for my fine advice before you sign off.
Thank You
Posted on Sep 18, 2008
My GE Quiet Power 1 is constantly beeping when you press Normal wash, and then just flashing when you press Start/Reset.
Try cutting power to it at breaker box and see if electronics will reset. If not, sounds like a control board problem
Nov 11, 2017 | GE Dishwashers
L65X Dishwasher problem
has there been a soultion mine is doing the same?
Jan 10, 2012 | Dishwashers
The Drying light flashes and the unit beeps about once per second. At the same time the unit acts like it is washing (sounds of water washing insiide. The bottom is oompletely full of water.
so its beeping and flashing once per second correct this beeping and flashing is an error code that your unit is giving blinking lights or beeping sounds may indicate a problem with the dishwasher caused by power surges. To correct the problem, try pressing the "Start/Reset" pad to reset the dishwasher. If the problem persists, reset (reboot) the control by turning off the circuit breaker supplying the dishwasher for 30 seconds. Turn the circuit breaker back on and the dishwasher should function normally if you still have the flashing and beeping message me back Im going through the error code book as I type this if it still persists after you turned off the power then back on message me back with the number of beeps within 60 seconds as well as the number of flashing lights for instance if it does it every second or once every 5 seconds also if you have any further questions message me back them as well and please remember when our chat has fully concluded to rank how this opinion has helped it allows me to help others in similar situaitons Thanks Rick
Feb 04, 2011 | GE 24 in. Profile PDW9880JSS Built-in...
How do you reset the whirlpool gu2400 xtp83 dishwasher. the clean light is flashing. The unit will not start
Can be caused by detection of a heater circuit problem. You can reset by running the diagnostic cycle. To turn of the diagnostic cycle, press: HEATED DRY button, then NORMAL button, HEATED DRY button again, then NORMAL button. The cycle runsfor ~22 mins. When it completes, the blinking light should go out. You can then try running the dishwasher again. If the problem comes back, the heater element or Thermister may need to be replaced
Jul 29, 2009 | Whirlpool GU2455XTS Built-in Dishwasher
GE Profile PDW7880G00SS Dishwasher will not Start
Re: My dishwasher start light flashes and the timer display is blank.
That is a fault condition, if the display is blank it is probably a faulty control board.
Unplug the appliace from main, or trip circuit braker to cut power for ten minutes.
If display is still blank on startup, then replace the timer control assembly.
Mar 13, 2009 | GE 24 in. Profile PDW7880G Built-in...
Dose not finnish washing and starts bleeping and start light keep flahing. water is hot by have not dryed
Neighbor had a similar problem with a GE dishwasher except it wouldn't start and kept beeping when door was closed. So the door was left closed, and while it was beeping, turned off the circuit breaker that fed power to it. Waited about 30 seconds, turned circuit breaker back on, bleeping had stopped, dishwasher was reset. Normal and heated dry were already selected, (since I had tried pressing those two before all this to force a reset), then pressed start and it ran again. Hope this might help you.
Jul 25, 2008 | Whirlpool Dishwashers
Air Dry Button just flashes
that is the fault code indicating the button is stuck. the touchpad must be replaced. the lock light indicated two or more buttons activated at same time
Feb 15, 2008 | Whirlpool 24 in. DU920QWD Built-in...
Diswasher won't start
Try holding the reset button in for about ten seconds.
Nov 26, 2007 | KitchenAid 24 in. KUDP01IL - Multiple...
F1 light flashing with a picture of a wrench
See http://fixitnow.com/2004/10/appliance-repair-revelation-fisher.htm, or http://www.fixya.com/support/t103415-fisher_paykel_dd_603_dish_drawer
Aug 24, 2007 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwasher will not start
turn unit off at the breaker and leave off for 10 mins before turning back on,  if this does not reset the unit, then your control board is probably bad or the heating element could be going bad.  call a repair man for service
Apr 22, 2007 | Kenmore 16602 / 16604 / 16609 Built-in...
GE 24 in. GLD5560LSS Stainless Steel Built-in Dishwasher Logo
233 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
