I have an hppavilion entertainment PC laptop...when I power it on all the lights come on and I can hear it running but nothing happens with the screen
    Sergeant:
  • 300 Answers
There is a button on all laptops that looks like ( resembols ) a little monitor screen
It's there as a function key to allow you to select an external VGA monitor instead of the laptops display.
This button could have gotten pressed by mistake and has turned your laptop dispay off.
D is the FN function key , and you may need to hold it down while you press A row or B row
On the A row or B row you will find the one that looks like a little monitor.
Thank you for using FixYa!
Az.
Posted on Sep 18, 2008
The system will not boot up
try removing the battery and power cord and then reinsert them and try starting it up again
Oct 11, 2012 | Sony Computers & Internet
HP Pavilion Entertainment PC Laptop DV2000
when you say some times it keeps going does this mean the unit turns off ??,,,,this model has the gpu problem,,,dry solder joint of the graphics card, of which you can have the board repaired or replace the board
Oct 06, 2012 | HP Pavilion Computers & Internet
HpPavilion DV 1000 stuck in hibernation mode
It will eventually come out of hibernation mode, when that happens go into power setting and select hibernation, next uncheck box on the left and click apply, this will disable this feature and should have no futher trouble.
May 29, 2012 | HP Computers & Internet
Power light comes on but nothing happens
What type of laptop? What operating system?
Laptops don't boot for the following reasons: 1) Bad Power Cord. 2) Bad DC Power Jack where the power cord plugs into the laptop. 3) Static Charge Buildup. 4) Bad Motherboard.
The above 4 reasons are when you press the power button and absolutely nothing happens. You hear no fans running, no disk drive running, no one time clicking sound on the CD Drive and No light for a second or two when the CD drives click. In the case of a motherboard issue sometimes you will hear beep sounds or see blinking lights. Those beep sounds and blinking lights tells the technician what is going on with your motherboard and why it will not boot. If you see the blinking lights or hear beeps count them.
So you have a power light which means your power cord and dc power jack is good. So lets see if you have a static charge buildup.
Remove the Power Cord and the Battery from the laptop, then Press and Hold the Power Button for 30 seconds. After 30 seconds put the power cord back into the laptop, but leave the battery out. Press the power button to see if it boots. If it does you had a Static Charge Buildup and it's ok to put your battery back in. If it does not you more than likely have an issue with your motherboard.
Mar 22, 2012 | Computers & Internet
My hppavilion dv6700 does not turn on. I try to start it, all the lights go on for about 2 seconds and it shuts off at once. This happens anytime i try to turn on the notebook. what colud be the problem?
Your battery is at too low a charge.
here is a game plan:
Unplug the computer from power
take the battery out of your laptop,disconnect the battery
connect the power to your laptop see if it comes up
If it does come up, your battery has one or two bad cells in it
You can prove it is the battery by using a battery from a known good computer that uses a similar battery.
you can stop wasting time by ording a new battery on E-Bay. Your computer will work fine untill you have the money to by a new battery
Nov 24, 2010 | HP Pavilion dv7-1132nr Notebook PC
My HP Pavilion Entertainment PC will not turn on!
CHECK IF U ARE RUNNING ONLY ON BATTERY SO TRY TO REMOVE THE BATTERY AND INSTALL IT AGAIN AND CONNECT THE CHARGER
Jun 07, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
Screen black computer laptop not starting ,hp pavillion entertainment pc,power lights on but screen black screen black computer laptop not starting ,hp pavillion entertainment pc,power lights on but screen...
hi,
if nothing(even hp logo ) is not coming on the display then please try this.
1.remove the battery and then press the power button for 30 sec.Again refix it and check.
2.If windows sound is there then this mught be the issue with display.
3.If there is no windows sound might be the issue with RAM so please get it checked.
May 29, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
Dv6225 us
1 >REMOVE BATTERY AND CHECK WITH ONLY ADOPTER
2> RESTART PRESS F2 IF DISPLAY IS COMMING THEN RESTART AGAING AND PRESS F8 PLAY IN SAFE MODE
Jun 21, 2008 | HP Pavilion dv6225us Entertainment -...
Computers & Internet Logo
David Payne
David Payne
