Hello Direct Code Entry To program your universal remote to control your components using the Direct Code Entry Method, follow the steps below. 1. Manually turn on the component you want the remote to control. 2. Locate the enclosed Code Lists. Find the list for the component you wish to program. Find your component's brand. You will see a listing of four-digit codes for each brand. If your brand isn't listed, use one of the Code Search methods to program the remote control. (Refer to pages 3 3. Press and hold the component key (TV, VCR•DVD, SAT•CBL) you wish to program. The illuminated ON•OFF key turns on and remains on. If you release the component key at any time during the Direct Code Entry procedure, the illuminated ON•OFF key blinks four 4. While holding down the component key, consult the Code Lists for the four-digit code that corresponds to your component's brand and use the number keys (0-9) on the keypad to enter it. While you are pressing the numbers, the illuminated ON•OFF key turns off. 5. After the fourth number is entered, the illuminated ON•OFF key turns on. At this time, release the component key. If the illuminated ON•OFF key turns off, you have entered a valid code and have followed the correct procedure for Direct If you enter a code number that is not in the Code Lists or you do not follow all of the steps for Direct Code Entry, the illuminated ON•OFF key blinks four times when the component key is released. This is an indication that a programming error has occurred. In that case, repeat the Direct Code Entry process from step 3. Tip: Throughout the programming of each key, be sure to keep the remote pointed at the IR sensor of the component you are currently programming the remote to control. 6. To confirm that the component key is programmed with the correct code for maximum functionality, test the component. Attempt to control a variety of the component's functions with the remote. If some of the features of your components do not work, try programming the remote with a different code in the list until you find the code that allows the remote to control the majority of your component's functions. Different codes can provide different levels of
If you know the codes for your tV with this RCA RCR312W remote control; the proceedings to enter the code follows:
and 4 for Manual and Auto Code Search methods.)
times, and the process is exited.
Code Entry.
functionality.
OK.
[1] Turn on a desired device (e.g.,VCR or
DVD player) and, if applicable, insert
media (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely
before proceeding.Highlight or write down the
codes and device you wish to program before
starting step 2.
[2] On the remote control,press a device key
once (i.e., TV,PVR,DVD, CBL/SAT,AUD,or VCR).
NOTE: To program control of a cable box or
satellite receiver, press CBL/SAT once.
NOTE: To program control of a CD player or
audio receiver, press AUD once.
NOTE: To program control of a TV/VCR Combo,
press VCR once.After programming, you will be
able to control channel selection, volume, and
VCR functions.
NOTE: To program control of a TV/DVD Player
Combo, press DVD once.After programming,
you will be able to control channel selection,
volume, and DVD functions.
[3] Press and hold SET until the LED (red light)
blinks twice, then release SET.
[4] Use the Manufacturer's Codes to locate the type of device and
brand name and then enter the first fourdigit
code for your device. If performed
correctly, the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps
2 through 4 and enter the same code again.
[5] Aim the remote control at the device and
press POWER once.The device should turn
off. If it does not, repeat steps 2 through 5,
trying each code for your brand until you
find one that works.
NOTE: If the device does not have a POWER
key, press the (Play) key.
[6] Repeat steps 1 through 5 for each device you want to control.
OK.
The One For All 6-Device PVR Universal Remote Control
is preprogrammed at the factory to operate an RCA TV,
VCR, and satellite receiver, a Philips Tivo PVR, a Toshiba
DVD player, and a Pioneer audio receiver/amplifier.To
control devices other than the default brands,perform
the following steps; otherwise skip this section:
[*] Turn on a desired device (e.g.,VCR or
starting step 2.
[**] On the remote control,press a device key
VCR functions.
[***] Press and hold SET until the LED (red light)
[****] Use the Manufacturer's Codes of device and
[*****]Aim the remote control at the device and
[******]Repeat steps 1 through 5 for each device you want to control.
OK.
