Question about Whirlpool GD2SHGX Refrigerator
Leaking on floor
Water dripping from filter housing, only leaks when filter in
  • 750 Answers
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, Water is dripping from filter housing, only leaks when filter in!You have two choices.
1. You can have service repair or replace the filter seal in the filter seat.
2. Or you can operate it with out a filter with no ill effect! that's okay to operate it without!
Please remember to leave a rating before you go!
Thank you
Posted on Sep 29, 2008
I have a Carrier furnace and noticed water on the floor. I saw it was coming from the filter housing. I pulled out the filter which was wet only on the bottom And noticed the pan/track it sits in had water...
Hello, there might be a crack in the condesate pan. Usually if the leak is concentrated in one area that is the cause. If the water would be leaking all around then a blockage in the drain line would be a problem. Have the drain pan inspected.
Jun 18, 2012 | Heating & Cooling
I think your unit is clogged somewhere, the water should drain into a pan under the freezer and down a tube to a pan under the fridge which is located just behind the front kick plate. here it should evaporate NOW if the tube gets clogged the water has to to go someplace. meaning the leaking water may not exactly be coming from where you are thinking, it could be somewhere up stream. you could apply some silcon on the poits you suspect and see.
Jul 01, 2010 | Refrigerators
Leaking water
mcdevito75 here, The portion of the a/c unit that goes outside the window is the evaporator and suppose to leak water, check the drain hole in the unit floor on the outside portion of the unit, reach this drain hole thru another window or have your local a/c repair shop look at it, they come to the house.
Jun 21, 2010 | Samsung AW0893L Air Conditioner
2002 suburban has leak in driver side rear floor. Cannot see where water would be coming from?
We had same--water on driver side rear floor (soaked!). Driver side front floor seemed dry until feeling UNDER rug, was slightly damp. We found the location of TWO leaks causing this.
Leak #1 was through the parking brake line/cable seal; Recaulked with silicone. Removed plastic trim on floor between floor and door to reveal metal channel filled with water.
Leak #2 was where the door meets the car, near the hinge. It was the accordian-looking tube housing the wiring for the door. The big, rubber, circular plug connecting it to the main part of the car had come loose and water ran down through that, into the SAME metal channel filled with water from leak #1; will seal with silicone.
Note: We found that the channel filled extensively near the front door, BUT the carpet edge from the floor near the rear seat was dipping into it, wicking it up to the rear floor. Also, upon acceleration, the water in the channel gushed toward the back, thus soaking the rear carpet.
These leaks were found by removing all plastic trim (covering edges of carpet by doors), then one of us pouring water into specific areas of the exterior of the vehicle, and the other one watching closely with a flashlight for any signs of dripping.
Feb 18, 2010 | 2002 Chevrolet Suburban
There is evidence that my refrigerator has leaked a significant amount of water . Currently there is no water dripping anywhere. The floor is dry. When water fills the ice maker there is no leak. When...
leaks like this are often during the defrost cycle . the amount of water is about a cup or 2 . .. ck the tube to the pan and ck the pan for cracks... you can add water to ck it . they do crack as this is a hot area . . hope this helped **** .
Jan 05, 2010 | Refrigerators
RS25AWXEW01 side x side refrigerator has leak at ice maker water drips into frozen ice chute and leaks onto floor and also in freezer compartment
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Aug 13, 2009 | Roper RS25AEXLQ Side by Side Refrigerator
I opened up the housing and saw that when I removed the water filter that the water didn't leak out . I also turned the ice macine and water dispenser off.
Feb 11, 2009 | Estate TS25AFXK Side by Side Refrigerator
Water leaking at filter
If this is a Pure source 2 filter in the upper right hand side of fridge, Purchase an Electrolux filter bypass, P/N 241944302. This is a empty cartridge that lets water flow without water drip when filter is clogged. Fridgidaire/Electrolux made no bypass in these filters, so when clogged they leak. Plus they NEVER last more than about 30/60 days. If you use the bypass, you will need a separate filter elsewhere such as in water line under sink or behind fridge. Call me at 816-560-8545 if you need more info.
Feb 26, 2008 | Refrigerators
Leak off pump housing
Sidewinder, sounds like it's leaking from the pump gasket or the water seal assy on the impeller. Check the locking ring to the pump housing and see if you can increse the pressure to the tub. Also check the tightness of the motor fan assy. to the impeller assy. tighten if necessary. Pump gasket part number is 912529. Impeller seal part number is 903494. back.
Oct 23, 2006 | Jenn-Air 24 in. DW731 Built-in Dishwasher
Whirlpool GD2SHGX Refrigerator Logo
152 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
