Question about Kenmore Oasis HE 27082 Top Load Washer
F 1 i have an f1 code every thing works fine
    Genius:
  • 1,028 Answers
Control failure remove 3 screws along rear of control panel lift panel to acess control
Posted on Oct 01, 2008
No sata present but it boots
try working on your dual core processor i have a dell inspiron 531in have to do the F1 thing also to boot up in thin it work fine.
Jan 04, 2013 | Dell OptiPlex 380 PC Desktop
F1 Error Code : Kenmore Self-Clean Electric Range. Oven wont shut off. I can silence the F1 alert but it keeps coming right back on every 30 to 60 seconds or so. Range top burners work fine, but oven
An F1 error code usually means that the temperature probe isn't sending the correct signal back to the control board. Try disconnecting power to the range for at least a minute. If F1 displays after you cycle power you may need to replace the EOC (Electronic Oven Control).
Dec 05, 2012 | Ovens
Receiving the F1 code
Hi, ok so there was a recall on the control boards it's fine don't be scared all you have to do is call 1800-659-7026 give them your info and model and ser.# they will then send someone out to replace the control board it takes about ten min for all of it and it is all free no matter when you bought it. But in mean time quick fix for all of you is to unplug the washer then hit power then stop over and over tell there is no power left in it then plug it back in and it will work fine for awhile you may have to repeat if it does it again. But after they come out it will work fine. yes this has happened to me it sucks it took two years to find out what was wrong they didn't even tell us I had to ask alot of parts guys and look it all up. So for everyone that this is happening to I'm sorry I just hope this gets out to all of you because I work very hard to know my product and take care of my customers ask any of them and it's not easy working STRAIGHT commission and people don't want to come back for these kind of things. But remember the reason why you came there in the first place we will give you the lowest prices in town and we know what we are talking about, well most do if not they ask me:) so I really hope this helps someone out there.
Take care
Jun 15, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
DD603 Does Seal need replacement? F1 Error Code
F1 error code appears because moisture has been detected by the flood switch on the base of the housing under the drawer.
If you think the door seal was not fitting properly then that too can cause moisture leak into base of the unit where the flood switch is located. Steam condensation would also lead to moisture.
Best option might be to replace the door seal for the top drawer. This is not a trivial thing as the unit has motor actuated door seal which can be tricky to fit back in.
Also avoid foaming in the detergent by using the correct powder and not tablets.
Please rate this solution if you are satisfied otherwise post a comment.
May 22, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 CODE ON FRIGIDAIRE STOVE
I have a F1 code on my Frigidaire convection oven and a really cool beeping sound to go with it. I turned the breaker off and turned back on---doing the same thing...????????
Aug 15, 2009 | Frigidaire FEB24S2AS / FEB24S2AB Electric...
F1 beeping tested switches on lock motor seem to be fine is the only other thing to look at the control panel?
yes your Electronic oven control has gone bad which is why you have the f1 error code, this will need to be replaced.
Hope this helps. If I can be of any further assistance please feel free to leave another comment.
Good Luck!
Jun 23, 2009 | Frigidaire Gallery 30" Self-Cleaning...
Error code f1 on vulcan basic deluxe
Ck and ensure there is a pilot light.No pilot light, no gas.
May 26, 2009 | Heating & Cooling
Sharp sf 2540 code F1
The F1 error code -- lost communication with the sorter. Are there secondary numbers after the F1?
Check connector cables on sorter and machine, check power to sorter. If those are fine then you are looking at a board problem. Also make sure that all covers are close properly. *** check cover between the sorter and machine*** ( you may have to pull sorter away from machine).
Jan 24, 2009 | Toshiba e-Studio65 Copier
F1 Error Code
According to the GE website, F1 usually means a problem with the keypad. You might try my solution for the F7 problem which is similar in nature. Go to the following link:
http://www.fixya.com/howto/h155060-dreaded_f7_error
I have shared my solution with more than 1900 folks and most report success.
Please let me know if it works for you at:
hutchipop@yahoo.com
Good Luck,
Powerman
Jul 16, 2008 | Ovens
E1 and F1 flash, with beeps at 15 sec. intervals, & oven not working
crys, the tech sheet for your model states that you need to replace the electronic control (clock) when this error is flashing. Catriver..post back.
Oct 12, 2006 | Roper FGP300 Gas Kitchen Range
Kenmore Oasis HE 27082 Top Load Washer Logo
21 people viewed this question
Fordexpert
Archaeology
Archaeology
2mikecurtis
