Question about Proscan PSVR74 VHS VCR
Stuck tape Tape stuck in machine with message "lock" displayed. Cannot turn power on, either. Can't find my manual to do troubleshooting on my own. Appreciate any help.
  • fccucc Oct 20, 2008
    Thank you for the advice. I ended up taking the machine to a repairman and it turns out that there was a defective gear. It has been replaced, and now, $60. later, it's working fine.
If I remember correctly, press and hold the power button for ten seconds or a little more. If its not the power button try any button but I am pretty sure you will not be discouraged.
Posted on Oct 19, 2008
Stuck tape -- Zenith model VR4176
Remove the top cover to see the tape and get at it. Remove it there using plastic tools, not metal.
Dec 15, 2013 | Zenith Televison & Video
As machine window flashing 88 and clicking
Disconnect power cable and remove battery, it should reset
Jul 18, 2008 | AT&T 5840 5.8GHz...
Problem detected with this unit on the display won't function
Did it "seem" unbalanced, or "sound" unbalanced. Can you turn the unit on and then get the fault message, or is system locked in fault? You can download the manual at:
http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SpecPage&Sku=WPGT9360EPL
Look through the troubleshooting section and see if it can answer your questions. Also, warranty information is located in the manual as well ;-)
Apr 02, 2013 | Washing Machines
Vhs tape is stuck and message reads "tape
Unplug the TV/VCR/DVD Combo from the main power for a couple of minutes, the unit may eject the tape at the power ON.
You can also try openening the unit, reset the loading posts and eject the tape by manually turning gears, motors etc..You have to know what you're doing otherwise, you will do more damage or get injured and don't forget HIGH VOLTAGE CAN KILL.
Best of lock
www.aaatvservice.com
Jul 15, 2011 | Polaroid TBX-2000AF 20 in. TV/VCR/DVD...
I have a FO-2080 fax machine and it is displaying a message system error (E1-00) and will not work at all.
Page 69 on operation manual suite Source: http://files.sharpusa.com/Downloads/ForBusiness/DocumentSystems/FaxMachines/Manuals/fax_man_FO2080_suite.pdf
Error indicator is lit or blinking.
SYSTEM ERROR [XX - XX] REFER TO USER GUIDE
When [L1-00] appears, the scan head locking switch is locked. Turn off the power, release the scan head locking switch, and turn the power back on page 13 on the manual
The machine will not function. Turn the power switch off, wait about 10 seconds, and then turn on the switch again. If this does not clear the error, remove the power cord from the outlet, and contact your SHARP service center.
Mar 08, 2011 | Computers & Internet
Kodak All-in-one Printer has Paper Jam problem
Go to kodak.com/go/itg and follow the step by step troubleshooting. If you still get the same error,Time to contact Kodak at 1800 421 6699 and Your printer will be replaced free of cost.
Sep 15, 2009 | Kodak ESP 5 Printer
Sony Handi-Cam TR57. After being stored for a couple of weeks,the tape door, with tape in place has become stuck in the up position, and the tape cannot be either removed or pushed back down. The tape...
Follow this procedure to troubleshoot if the cassette compartment will not open or the tape is stuck and will not eject.
IMPORTANT: If your camcorder model has a RESET button, first try pressing this button. If there is no RESET button, or pressing the button does not resolve the issue, continue with the troubleshooting steps below.
  1. Turn off the camcorder.
  2. Remove the battery from the camera.
  3. Remove the AC power supply from the camera.
  4. Slide the power switch on the camera to the VTR , VCR or CAMERA mode for 15 seconds.
  5. Slide the power switch back to the OFF position.
  6. Connect the AC power supply to the camera.
  7. Attempt to open the cassette compartment.
NOTE: If the issue is still unresolved after completing all of the troubleshooting steps, service may be required .
Jul 31, 2009 | Sony Video Cameras
Stuck tape
The tape won't come out when resetting the drive. Error 6 is serious.
To get out the tape you must open the drive. But IBM has a discription online (and in the user manual) how you can do this.
Jan 06, 2009 | IBM TotalStorage 3580 L33 (3580L33)...
Error E3 on Mitsubishi HS-U795
Try this :
If your VCR malfunctions, try the following steps prior to contacting your Mitsubishi Dealer:
1 Check the Trouble Checks below to see if there is a solution to the current problem that you are
experiencing.
2 If the problem is not addressed on the Trouble Checks, the safety circuits in the VCR may be in
operation, thus please try the following: (the clock setting and the timer recording will be deleted.)
1 If possible, press EJECT on the front panel and remove the tape.
2 Press TIMER RESET on the rear panel with a pencil or a ball point pen.
3 If a tape is not loaded, press POWER to turn the power on. If a tape is loaded, wait about 1 minute
until the tape protecting function is completed, then press POWER.
3 You may also try the following procedure if the above steps did not resolve the problem (All settings will
be reset to the default settings.).
1 Press POWER on the front panel continuously for about 8 seconds until the current time display on
the front panel shows "- : - -."
2 If a tape is not loaded, press POWER to turn the power on. If a tape is loaded, the tape protecting
function will work and "99" will appear on the front panel display to begin count down. Wait about 1
minute until it reaches "00" to show the tape protecting function is completed, then press POWER.
If the problem with your VCR persists, contact your Mitsubishi dealer for assistance.
Im looking for error codes.
Mar 10, 2008 | Televison & Video
VCR Tape Stuck
Unplug the VCR, take the cover off, find the motor (probably on the right side of the mechanism) and turn its shaft with your fingers until you have run the tape back out. Now plug it back in and try it again with a scarificial tape. If it continues to fail, replace all the rubber belts in the mechanism.
Hope ya fix it!
Jan 05, 2008 | Panasonic AG-1330 VHS VCR
Televison & Video Logo
119 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
