Question about KitchenAid KSRG25FK Side by Side Refrigerator
Ice Maker Infrared light doesn't light
No problems with ice maker until service replaced the refrigerator starter because the old one was smoking. After the refrigerator was turned back on, the ice maker made one batch of ice and then the water froze in the mold and would not eject. I removed the ice maker and let the ice thaw. Replaced the IM and could not get anything to happen. Water would not fill the mold. (Water dispenser works fine. The water tube is not frozen.) After talking to KitchenAid tech support, I filled the mold with 6oz of warm water and waited two hours. Got one batch of ice and same problem-water in mold is frozen and will not eject. The infrared sensor light does not light or blink. Is this the problem; and, if so, what does it mean?
Thanks for any help.
  • 706 Answers
Each mold tray has a heating element that is turned on to free the ice cubes from the mold tray and allow them to fall into the ice bucket when the tray is rotated into harvest position. Sounds like that is not being turned on... or is defective..
Posted on Sep 18, 2008
I have a problem with the ice maker on my fridge and I'm pulling my hair out trying to figure out why it wont continue to produce ice.
If the ice maker continues to have ice in the slots and will not empty into the ice container it's more likely a problem with the ice maker and it needs replaced now I see you did not post your model number so I am assuming that you do not have infrared light showing that the ice maker has the container full. If your refrigerator has an infrared light beam then that could be a problem what is the model number of your refrigerator? Appliance 911 Sea Breeze
Dec 16, 2015 | Refrigerators
Have installed a new ice maker, it still will not work.
Soulds like the your model has a electronic eye that monitors the ice level has failed. Page 6 in the Click Here=> GD5SHAXKQ00 Parts List Location number 38 is the 2198585 Ice Level Control Board
Whirlpool Ice Maker Infrared Electronic Eye Technical Information I am here should you have questions, Thanks Sea Breeze
Apr 15, 2013 | Whirlpool GD5SHAX Side by Side...
Igloo ICE102 FULL sensor is stuck on
Hello If the ice maker light is stuck on full, most likely the Infrared sensor may have shorted out due to water seeping into either the infrared emitter or receiver or both. It is an easy fix. It is best to replace both the infrared emitter and receiver diodes. You can find 2 terminal/lead infrared emitter and receiver diodes on ebay or your local electronics store for cheap. Please ask the guys at the store that they are spectrally matched to each other. You just need to remove the old ones inside the ice maker and replace them with the new ones from ebay by soldering them on. If you cannot do this then best to take it to a local electrical store to get them to replace these for you.
Feb 01, 2013 | Refrigerators
Door alarm doesn't work
The sensor is got faulty,which triggers the alarm or its wiring is got loose.Also see if the freezer or fridge component got over freezed with ice modules.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
Both refrigerator and freezer not cooling properly in refrigerator?
The ice maker not working: ---
Compressor not running on refrigerator?
Water dispenser not working on refrigerator?
Ice maker stopped making ice?
Water Overflows in Ice maker and freezes inside?
How to replace Ice maker assembly?
These will help.
Dec 22, 2012 | Whirlpool WRF560SFYM 19.6 cu. ft. French...
Ice maker is slow to make ice. It dumps sometimes. it builds a large mountain of forzen ice that mounds up under the tray. even though we remove it it always comes back. ice is also runnig down the...
Ice maker problems are almost always a problem. Sometimes I will locate an issue and fix it and then it will work for a short period and then break again. So, now I just replace the ice maker as a general rule. This is much more likely for success. However, the replacement ice maker is often not an exact match. And again, the this and the that sometimes causes problems. I will never accept a new customer on the grounds that I am going to fix their home ice maker. Make sure the ice machine is getter water like it is supposed to. Check the filter and the tubes. If the problem persists, get a new ice maker. If that ice maker angers you, get some ice cube trays.
Jun 11, 2011 | LG LSC26905TT Side by Side Refrigerator
Ice maker has stopped making ice. Infa-red light on inside doesn't seem to be working
One of the causes of ice maker not producing ice is a bad solenoid valve allowing water to pass by and causing the water line to freeze inside the freezer. In other words, if the valve is not holding very well, it will allow water to pass in the line that supplies water to the ice maker. A small drip will ensue and slowly freeze in the line and eventually turn into an ice plug that will prevent water from filling the ice tray. Thawing out the freezer will not solve the problem, you will have to replace the solenoid valve.
P.S.Test the solenoid valve coil and disconnect the line from the valve to verify that it is not allowing water to pass when not energized. Test the infra red module according the manufacturer's instructions if you have them at hand. If the solenoid valve is good and the infrared sensor system is bad , replace it (Infrared system) . The ice maker should be the last part to consider for replacement at this time.
May 06, 2011 | Refrigerators
Kennmore refrigerator is not making ice,but water
The control light flashes to indicate the infrared beam is being blocked. The flap on the opposite side blocks the beam when the door is open to prevent ice from being dropped on the floor rather than in the ice bin. If you pushe the flap in so it's flush with the liner (use care not to block the hole) the light should go from flashing to on in a steady state. If not, your electronics are bad and would need to be replaced. If the light does glow steady, then the problem is with your ice maker, water valve or ice maker fill tube.
Dec 23, 2009 | Refrigerators
Ice Maker on Whirlpool Side by Sidek stopped making ice
Go to, select "Parts Direct", enter model number and wait for unit to be displayed, find ice maker part number and price.
Oct 01, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
KitchenAid Superba refrigerator, no ice.
this fridge uses a infrared controlled ice maker on the freezer top right side you will find a white lid whit three screws the ice maker control board replace it and if don?t solve your problem emplace the ice maker to.
Jun 07, 2009 | KitchenAid KSRK25IL Side by Side...
Whirlpool Side by Side Ice Maker Not Making Ice
sometimes if you use the water filer too long and don't change, can cause this problem.
Jul 10, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
KitchenAid KSRG25FK Side by Side Refrigerator Logo
279 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
