Question about RCA D52W19 52" Rear Projection Television
Picture(Color Convergence) Last night I turned my tv on it was working fine. I came back about 10 minutes later the picture was like 2-d I could see double like the picture color was out of alignment. It also looks like it is bowed inward or something. I tried unplugging it and messing with the menu picture setup options. There is no auto convergence option available. When I turned it back on I saw three lines (red,green,blue)at the top of the screen slightly arched. Please help!!!!!!!
  • 3 more comments
  • bigdaddyn200 Sep 19, 2008
    I have the same problem help!!!!
  • mosleyj Sep 24, 2008
    What do you do once you open the fuse? Where can I find a detail of the parts I have no idea what a Flyback transformer or deflection board looks like
  • Mariano
    Mariano Sep 25, 2008
    what does open fuse located next to Flyback Transfomer on deflection board do. I have convergance on the main menu but it doesn't work. It did one other time but it does't work manually or auto now.
  • mosleyj Sep 25, 2008
    Thank you so much for the detail info. I will try this today.
  • Anonymous Nov 27, 2008
    picture has three colored lines on it and there isn't an auto convergence on the menu
  • RCA Master
  • 5,138 Answers
Go to menu look for convergence on menu if it is not on menu then you have a open fuse located next to Flyback Transfomer on deflection board.
Posted on Sep 24, 2008
  • ladywinn
    ladywinn Sep 25, 2008
    You have two boards on bottom one is Deflection with Flyback on it, Flyback has 2 wirers coming from it red/ black Red goes to trippler and black goes to the screen and focus controls to picture tubes ok next to the Fly fuses look like small square brown caps there is 3 of them in a roll FL231 is the location number middle fuse is the one that opens causing no convergence.The other board is the SSB board it has your tuner and AUX jacks on it.
  • ladywinn
    ladywinn Sep 26, 2008
    This is for those who would like to order new Deflection board for TV cost 77.99 plus shipping call union electronics 1-800-648-6657 and you must return old board for credit.
My Mitsu rear-projection WS-B55 was purchased in '03 or so. Now the screen is sometimes turning red. I can do a system reset, and the color goes back to normal. Then it eventually (maybe days later)...
No,pictures go all red?Pictures have colors shaded shadows or 3D pictures look alike?Yes,than the tv it is developing a problem known as a convergence problems it dying.The tv convergence board have problems,must be resoldering those 2 or replaced 2 STK covergence ICS and some or all of it resistors too.To fixed the tv convergence board,to solved the convergence picture problems.The shop,will cost u like $300-350 for diagnose the problems and do all the resoldering work or replaces those parts on the tv convergence board.
Apr 08, 2011 | Mitsubishi WS-55809 55" Rear Projection...
Not sure if its a picture tube problem or convergence problem. TV was working fine, put a DVD on pause, came back 10 minutes later and poof! Distorded picture almost 3D like. Shut it off and when it came...
Check the micro fuses that power the convergence board, one or two maybe open, While doing this also resolder the flyback transfomer and area around it. Check for cold solder joints in this area as well.
Replace any open fuse with 5amp same type. If fuse are good then convergence power board is faulty and needs serviceing or replaced.
Dec 21, 2009 | RCA HD52W58 52" TV
3-D picture with color lines
Seems TV has dry/ cold solder joints (loos connections) in convergence out section.
Please check cold/ dry solder joints in convergence out section in TV, specially on pins of convergence out ICs. resolder these solder joints and all would be fine.
Sep 28, 2009 | Sony KP-57HW40 57" Rear Projection...
TV wont turn on, makes buzzing noise and shuts off
I have two RCA HD52W59 TV's. I have had one for 3 years and one 4 years. The one I have had for 4 years is giving me the problem. Last week the tv turned off while watching it. It wouldnt come right back on. 10 minutes later we tried and it worked fine. the other night the kids were watching and it turned off and smelled like something burning. I tried turning it right back on and got no power at all. I tried to turn it on two days later and it made a buzzing noise and the green light went out. Never did get a picture, no powering up on the screen. Any ideas? Don't want to spend alot of money. Really loved the TV hope it isnt junk now. Better yet I hope the same thing doesnt happen to the other one I have.
Jan 22, 2009 | RCA HD52W59 HDTV Projection Television
Zenith r57w46
replace convergence i.c.s. and safety resistros around block
Jul 07, 2008 | Zenith R57W46 57" Rear Projection...
I think it what is called convergence
Maybe loose connection on the convergence board around the IC's or amps
Mar 22, 2008 | Mitsubishi WS-65809 65" Rear Projection...
RCA D52W19 52" Rear Projection Television Logo
220 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
