Question about Maytag Neptune MAH9700 Front Load Washer
MAH9700 - Stacking?
Hi. I have just aquired the Neptune 9700 series washer & dryer. So far everything is ok (I spent a lot of time here first!) however I do have few questions. Are these units stackable and if so any idea on how?
Thanks,
Dave
zeusfaber
  • 247 Answers
SOURCE: Maytag Neptune Stackable washer continues to fill with water when unit is off
If the machine continues to fill even after the power has been switched off, this sounds like a stuck inlet valve. To identify the valve, look at your model in the "parts store" section of Maytag's website. The valve is item 21 on the "Control Panel, Top & Lid" drawing. From the drawing, the valve looks like a fairly standard item; I suspect you might get something suitable a bit cheaper elsewhere. A
Posted on Feb 06, 2007
Lumpy816
  • 246 Answers
SOURCE: Maytag front lead stackable
That is correct. Take the screws out of the console up top. look for a burn mark on your circuit board. If it's on R11, replaced your door lock wax motor as well at the board.
Posted on Jun 13, 2008
SOURCE: Neptune stackable washer...
I went to Sears today and asked!  They said use high efficiency detergent (marked HE on the label) and put it directly in the washer with the clothes.  Mystery solved!
Posted on Aug 03, 2008
You put the detergent directly on top of the clothes.
Posted on Aug 04, 2008
SOURCE: mle2000ayw Stackable washer/dryer not washing, spinning
If the door lock light is on then is might be the "door lock enable spin switch" the plunger at the opposite end from the wax motor is not fully depressing the switch. In the stackable it is just behing the door lock. Remove the two middle covers (2 white phillips screws and one hex head screw on the middle of lower cover by the wires)to test place a few layers of masking tape on the end of the plunger and cycle the machine. Might also be a weak Wax motor (dark brown in color) to be safe replace both for about $12 each. Fix in 10 - 15 min.
Posted on Jun 11, 2009
How do you replace door lock on matag MAH 9700
From the top. Lid off reach down to the unit two bolts and a wiring block.
Aug 01, 2014 | Maytag Neptune MAH9700 Front Load Washer
Door will not unlock neptune washer model MAH9700
you will have a flap on the bottom right hand side flip it down and get your self a towel and a bowl and a saucer put the saucer just under the pump you will need to start to unscrew the pump screw slowly and close it so you can keep emptying the saucer in to the bowl ok onece all water is out of the pump you can open the door ok please make sure the machine is swicth off be for doing any thing ok
Oct 19, 2012 | Maytag Neptune MAH9700 Front Load Washer
Maytag Neptune MAH9700 washer wont drain. Did service test and everything checks ok except NO power to the drain pump. Is it the relay? If so, where would I find it?
Hello, jim
I am trying to help you out here. Maybe this will help some? I am know on Fixya as the cleanup expert pro. Which means I spend my own personal time to seek out customers that maybe have not had there problem yet solved by the other fantastic great experts. I do this on my own for free. Think of me as a Specialized Trouble Shooter.
I have found out that it appears that lots of customers appreciate my efforts and help. So, I thought I would take some of my own personal time
to see if I can help you. Even though this Informational site may not have your exact model or brand, But this site will help you a lot. Here is the site link about everything you want to know about washing machines and possibly yours, from repair to trouble shooting it.
http://home.howstuffworks.com/how-to-repair-a-washing-machine.htm
Please if this helped you at all, if you can find the time and in your heart to rate my help and some kind words written would be appreciated for my free help, I would appreciate it. Like I said I just try to help, If anything this is good information for future problems. If you felt that my free help was a waist of time for you, I'm sorry. I do not get paid to help people on the site, I do it cause I like to help and maybe make a smile on someones face.
Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive, Appliance, and Electronics. Drop In anytime for my help.
http://beta.fixya.com/users/mc1bean
Thanks Mike
Nov 09, 2011 | Maytag Neptune MAH9700 Front Load Washer
My MAH9700 Front Loader washer is shaking a lot and making a loud banging noise when spinning.
unscrew the 4 screws inside the detergent dispenser and lift the top and see if the counterweight on the tub is loose,otherwise it may be the drum bearings going bad on the inner drum
Apr 01, 2010 | Maytag Neptune MAH9700 Front Load Washer
My maytag neptune has no power any suggestions
Check for ~220 volts AC across the two slanted contacts on the dryer power socket. If nothing, check the house electrical panel for tripped dryer circuit breakers(pair)--push the breakers OFF, then ON to reset. Recheck for 220 volts at dryer socket--if ok now, try the dryer. You need to use a voltmeter for this checking. If it starts, then quits, you likely have an internal short (heating element) inside the dryer case that trips the circuit breakers.
Jul 23, 2009 | Maytag Neptune MAH9700 Front Load Washer
Maytag Neptune 9700 series
IT SOUNDS LIKE THE OUTER BAND TO HOLD ON THE DOOR BOOT/SEAL. WHAT I HAVE SEEN IS THAT AN ARTICLE OF CLOTHES WAS NOT ALL THE WAY INTO THE WASHER AND IT WAS STARTED, PULLING THE DOOR BOOT INTO THE WASHER. THE ONLY OTHER THING I HAVE NOTICED WITH THIS NEW BREED OF SUPER CAPACITY WASHERS IS THAT THEY LIKE BIGGER LOADS TO HELP BALANCE THEMSELVES. IT MAY BE POSSIBLE THAT IT WAS SO SEVERLY OUT OF BALANCE THAT IT PULLED THE BOOT INTO THE TUB AS THE MAYTAGS OF THAT MODEL LINE WERE KNOWN TO NOT BE THE MOST SENSITIVE TO OUT OF BALANCE CONDITIONS. THERE IS A CONTROL BOARD KIT THAT COMES WITH A MOTION SENSOR NOW FOR THEM AS AN UPGRADE.
Jan 27, 2009 | Maytag Neptune MAH9700 Front Load Washer
Stacking Frigidaire dryer on washer using stacking kit 5303937141
i have the two brackets but have no idea how they attach. does the top come off the washer?
Mar 23, 2008 | Bosch Axxis WFL 2060 Front Load Washer
My Neptune washer MAH9700
I have a Maytag Neptune MAH 9700. It died one day and the door remained locked. I am guessing the circuit board is fried so it's a good thing I purchased a five year extended warranty. The problem though, is that my 2 year olds BLANKY was in there and she won't go to bed without it. Can't wait 2 weeks for the repair guy. I was able to remove the top and (after I unplugged it of course) get my hand to the bottom of the switch housing. Seems there is a small opening at the bottom. I pressed up with my finger and was able to get the door opened. Whew!!! Hope this helps. ; )
Jan 10, 2008 | Maytag Neptune MAH9700 Front Load Washer
You have to take the top off the washer a put it aside. You no longer need the top. Then you put the two angle brackets on the front top of the washer. this is where the front of the dryer will attach. The back of the washer either has or needs the brackets put on the top (been a long time since I did this). Remove the leveling legs from the dryer. Then lift the dryer and slide it on top of the washer with the back touching the top of the washer and the front about 2 inches higher than the washer top. The back of the dryer slides into the back brackets which are on the top back of the washer. Then lower the front of the dryer and the two "L" brackets on the front top of the washer slide through cracks into the dryer. Pop off the two plastic plugs on the dryer bottom front and place a screw in each one to hold the unit in place. Replace the plastic caps and you are done.
Dec 29, 2007 | Frigidaire FEQ332E Electric Dryer
Maytag front load 9700
First things first... please follow this link to see if your machine is part of Maytag's recall... http://www.washerrecall.com/ or this site for details on the recall... http://www.cpsc.gov/cpscpub/prerel/prhtml07/07135.html
Aug 19, 2007 | Maytag Neptune MAH9700 Front Load Washer
Maytag Neptune MAH9700 Front Load Washer Logo
37 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
