Question about Lexmark S305 IMPACT LEXS All-In-One InkJet Printer
My color inks are out of ink but still in the printer...i just replaced the black ink. when i try to print, it will not allow me and says to replace the color inks first. i followed the instructions to go to the advanced button on toolbar and check for black ink only, but it still does not work. why will it still not print, and how do i print only using black ink?
  • Official Brand Answer
  • 3,344 Answers
The Lexmark Impact S305 printer requires all the cartridges to have ink in them to continue printing - even if you're printing using black ink only. To print true black, you actually use some of the color ink.
Note: Leaving the color cartridge empty or dry isn't good for the printer. It can lead to poor print quality if you want to print color in the future.
Posted on Sep 23, 2011
    New Friend:
  • 29 Answers
There's a button right on the front panel for color or black and white.
Posted on Dec 25, 2012
SOURCE:
The printer won't print. It says replace the color ink cartridge. All I want to do is print black and white.
You can only use the black ink cartridge without the color ink. But no need to replace them in your printer.
When you print just choose black and white for the printed text must be black not colored. But if you still received such notification...just try to replace the color ink cartridge to continue printing
Note: As per my experience. printer with exclusive black ink alone will damage the printer easily due to unbalance printing of ink
Sep 20, 2011 | HP OfficeJet 6210 All-In-One InkJet...
The printer's black ink cartridge won't print without the Tri-color print cartridge
Most of the HP printers are designed to allow printing onlywhen all cartridges are installed and
have ink.
Install a new tri-color ink cartridge and printing will continue as usual.
My printer, which is HP, does the same thing as yours, until I replace the empty cartridge,
printing stops.
Feb 22, 2011 | HP DeskJet 3745 Printer
How do you print a document using color ink? I am out of black ink.
Ink is a lubricant for the print heads. Some color ink is used even if you only print in black or vice-versa. If you printed with black ink missing, you could destroy that print head from the friction of running without ink to lubricate it. That's why most printers won't allow you to print with black ink missing even if you aren't using it. That's the case with your Canon printer.
If you allow a color to go empty, the residual ink in the head could clog and become permanently blocked. You would never be able to print that color again. So always replace ink cartridges as soon as they are empty.
Jan 05, 2011 | Canon PIXMA MP160 All-In-One InkJet...
I don't have black ink is there a way to print with just using yellow, cyan, and magenta
Ink is a lubricant for the print heads. Some color ink is used even if you only print in black or vice-versa. If you printed with a color missing, you could destroy that print head from the friction of running without ink to lubricate it. That's why your Brother printer won't allow you to print with a color missing even if you aren't using it.
Jan 05, 2011 | Brother MFC255CW All-in-One InkJet Printer
One colour cartdridge is empty can i print black only
To print with black ink only, you have to go Print, on the window that shows up click on Preferences then select the Color tab and tick the check-box for Print in Greyscale.
But bear in mind that ink is a lubricant for the print heads. Some color ink is used even if you only print in black or vice-versa. If you print with a color missing, you could destroy that print head from the friction of running without ink to lubricate it. That's why most printers won't allow you to print with a color missing even if you aren't using it.
Dec 23, 2010 | HP Photosmart D7160 InkJet Printer
Can i print using black ink when im out of color ink it wont let me even though ive changed the settings to print colors as black and white
That's the way Kodak works
It won't allow yu to do anything if any of the lights are flashing or there is a error message
NO RESOLUTION
Get your color ink cartridge replaced by Kodak.
Just say its a new color ink cartridge and printer is saying its empty!!
Hurraay you'll get a free color ink cartridge
Jan 25, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Check color ink always blinks and does not allow to do any job.
Make sure that you installed the correct ink. It is not enough for it to fit, the numbers on the cartridge have to match those on the cartridges you replaced. You may also have problems with off brand ink that claims to work. Use Kodak ink. Also, many of the Kodak have the ink jet nozzle on the printer, not the cartridge.You can try cleaning in and around the cartridge casing, especially on the copper areas, with an alcohol swab. Then run the cleaning utility on the printer 2 or 3 times.
Nov 09, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
New black cartridge installed. Won't print. HELP please.
Try
Resetting the Ink Counter When an ink tank is replaced, the ink counter must be reset. The low ink warning is only displayed properly if the ink counter is reset.
Message Prompting Confirmation of Ink Tank Replacement
If an ink tank is removed, the printer will output a message prompting you to confirm replacement of the ink tank at the start of the next print job.
When an ink tank has been replaced, follow the procedure below to reset the ink counter. The low ink warning is only displayed properly if the ink counter is reset.
Important
If infrared communication is performed in Windows XP or Windows 2000, the printer will not output the message asking for confirmation of ink tank replacement.
Reset the ink counter from the printer driver when you replace the ink tank.
1 Check the message, and click Yes.
Note
Mistakenly clicking No instead, will prevent the low ink warning from functioning properly. If this happens, be sure to open the driver's Properties dialog box and manually reset the ink tank counter in the Maintenance tab.
2 Select the replaced ink tank, and click OK.
The dialog box allows you to select the replaced ink tank.
When both black and color ink tanks have been replaced, select both Black and Color.
If you have not replaced the ink tank with a new one, click Cancel.
Resetting the Ink Counter in Printer Properties dialog box
1 Open the Printer Properties dialog box and click the Maintenance tab.
2 Click Ink Counter Reset.
3 Select the newly installed ink tank, then click OK
Sep 30, 2009 | Canon PIXMA iP90 Mobile Printer
Hp psc 1210xi- the black ink cartridge appears to be out- i have a good color cartridge-how do I get the error off of my printer and print with my color cartridge?
  1. Take out the black cartridge once you've determined that you are completely out of black ink. You'll have to rely on the dark hues from the color cartridge to print in black.
  2. Adjust the printer software settings. Once you take out the black cartridge, your printer's software will typically warn you that you are missing a cartridge. Follow the instructions for your printer to allow the printer to print without the black cartridge. Then set the printer to print in black and white, not color. This overrides the black cartridge and allows the printer to access the dark hues of the color cartridge.
  3. Print a test page to ensure that your printer now prints black using the color cartridge.
  4. Print your documents. Bear in mind that your documents may not appear as black as normal. Still, they should be dark enough to pass for black, depending on how much color ink you have and the strength grade of the ink.
Sep 29, 2009 | HP Office Equipment & Supplies
Can't Print with black ink because all color ink are empty.
yes you need to install all cartridge before printing any page ...I have also this model...but u need to install all 4 cartdge. before printing any page wheather color or blacknwhite..
Jan 08, 2009 | Office Equipment & Supplies
Lexmark S305 IMPACT  LEXS All-In-One InkJet Printer Logo
1,012 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
