Question about Intel Motherboard
Laptop Lap top will not charge, even with a new battery, the laptop is a 'Systemax' model CY25, I had it 2 years
  • 4,472 Answers
One thing you may need is a new AC power cord. It could be the cord itself that is bad. If you can find someone elses to try that may help. The other thing that it could be is the internal recharging circuitry. It is one or the other. First I would try a different power cable. If that doesn't help you will need to get your laptop serviced. If you have a moment to accept and rate this and the original solution appropriately it would be greatly appreciated.
Thanks,
Lee
Posted on Sep 18, 2008
Where do i buy a battery for my lap top
I suggest you Google the Internet for a replacement battery for your model laptop. You will get various suppliers and prices.
Mar 05, 2013 | HP Computers & Internet
Acer aspire 7551 Battery will not charge.
I had a similar problem with a laptop years ago...Where the battery terminals connect to the motherboard, and Im not sure about yours because the models are obviously way different, but in some, they use "battery boards" that connect to the motherboard and are seperate from the system. Those "battery boards" have lots of micro capacitors and resistors on them and are responsible for charging the battery and completing the power circuit to "start" the computer. If I took the battery board out of the laptop I had, the whole thing wouldn't work. Since your laptop is starting while plugged in, but the battery is not charging...I would look into this area first. I am going to rummage around to see if I can find a schematic of your laptop and maybe some parts info.
Jun 20, 2012 | Acer Aspire 7551-7422-22085
Sony laptop not getting charge
Check inside your Bios or System Setup for settings that control the battery. Turn your laptop off, then turn it on and watch the screen for which key it says to hit to get into the Bios or System Setup. Hit that key when you see the message or it will not work and you will have to reboot and try again. Once you are in the Bios or System Setup, search thru it for some settings that control the battery.
May 29, 2012 | Sony VAIO EB Series Brown Notebook...
Hp pavilion Dv 7 won't power on even when the lap top is charged.
Pull the battery and plug it in to the wall (in other words rule out the battery). If it still refuses to come on, check out this troubleshooting link:
http://www.techspot.com/vb/topic55208.html
Jan 15, 2012 | HP Pavilion dv7-1130us laptop
My battery states that it is fully charged but when I switch on the laptop it says that I need a new battery. My laptop also gets very hot.
In my experience, you should trust your laptop, not your battery.
Concerning hot - can your computer breathe? You shouldn't actually sit your lap top on your lap ... it should sit on a hard surface so air can be drawn into the vents by the fan.
Aug 17, 2010 | Dell Inspiron 1521 Notebook
Lap top no power
If you were given a laptop with a brand new battery, it does need to charge for a while and depends on the manufacturers suggested charge time.
You should be able to power the laptop on without the battery attached. If you can't, you probably have a power supply issue on your hands or a bad component on the mother board. It may be less expensive to just get a new laptop.
Apr 06, 2010 | HP Compaq nc6000 Notebook
My acer aspire 5735Z wiil not stay charged for more than 1 hour when not one the charger and just shuts off even if battery indicator shows atleast 50% charge, is just a bad battery?
Batteries wear out with use and can be replaced easily with a new one.
If you laptop is more than one year old then most probably the battery is weak and cannot hold the charge. When a battery becomes weak its capacity to hold charge reduces considerably until you have to remove it to start the laptop (with charger only).
You can continue using it until the battery time drops to about 10 minutes. After that, simply replace it with a new one.
If the laptop is new and under warranty, you should contact warranty support asap.
To increase battery life place the laptop on a solid table where there is ample air flow beneath. Heat will destroy a battery faster such as when used on bed or your lap often.
Regarding you question about shutting down even when battery is 50% it could be due to following reasons:
  1. Power Settings within the control panel.
  2. The battery charge drops quickly so that it discharges very quickly when it is showing half. Remember that the indicator is an estimate and does not account for battery degradation over time.
  3. Other issues like over heating etc but please check first two points first.
Feb 20, 2010 | Acer Aspire 5735 Notebook
How do I chaarge the battery on my lap top
1. connect the ac adapter from a known good power source.
2. plugin the battery to the laptop.
3. check bios if batt is recognize or performing normally (to do this turn on laptop keep tapping f2 to boot to the bios options)
4. just leave the laptop with the ac adapter connected and it will charge laptop automatically, just leave it for about 4 hours.
Oct 13, 2009 | Dell Latitude D600 Notebook
Battery
Get a new battery. The life span of a laptop battery is typically only 1-2 years. Check to see if it's still under warranty.
Jan 03, 2009 | Computers & Internet
Charging lap top battery
As soon as the AC is plugged in, the battery will start to charge. The battery light located somewhere on the laptop should indicate you that it is charging. It does not matter if the laptop is turned on or off.
What you explain here about the first battery is very common for a 4-5 y.o. laptop. The longevity of the battery mainly depends on the number of charging/discharging cycles it encountered. If the second battery you want to try spent more time in a carrying case than in the laptop, it may still be usable. But do not expect to go over 1 hour of autonomy with it.
May 28, 2008 | Computers & Internet
Intel Motherboard Logo
43 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
