Question about Motorola Mobility RAZR V3m Cellular Phone
Insert new sim card
I am attempting to insert my Mother's sim card into my old phone, motorola fatter first RXR, not super slim RXR, the pink one that every one has, cannot open section to sim card, have removed the battery, now what?
    Problem Solver:
  • 19 Answers
You may need to use a knife or small screw driver and slowly but easily lift until it opens. Careful you may break insert!
Posted on Sep 20, 2008
Move numbers to my new phone without reentering the numbers
Not a problem. Follow the following process to do it.
1. Copy all your contacts/numbers from your old phone memory into the sim card memory.
2. Turn off the phone and take the sim card out.
3. Insert the sim card into your new phone and copy the contacts/numbers from sim card to phone memory.
Hope it helps for you.
Please let me know if you need further assistance.
Thanks !!
Nov 09, 2010 | Motorola Mobility i880 Cellular Phone
We insert sim card in cellphone, even though the cell phone dispaly "please insert sim card"
It seems that your cell phone is having trouble reading the SIM card. You have two options. First you can attempt to clean the SIM contacts on your device. To do this simply apply a small amount of alcohol to a Q-tip and gently rub over the gold contacts where the sim card normally goes, this will help to remove any dirt build up and provide a better connection. Second, contact your service provider and request a new SIM card. Sometimes SIM cards can go bad similar to a memory card failing. A new SIM card maybe all you need.
Nov 24, 2009 | Motorola Mobility L6I Cellular Phone
Got a motorola razr v3 on ebay. Not reading SIM card.
It may be caused that when you take out sim from old phome it has damaged, try for old one is it still working? if not then your sim is dead, also old phones made SIM-s to be bend and such SIM-s have difficlt electrical connection with new phones.
Also find if "this sim only" is activated in your phone.
It must give you signal, Insert sim card, or insert proper sim. If insert sim card warning card is damaged or have not enough good connection, if another, then this sim only is activated you first you must unlock it to work .
Aug 20, 2009 | Motorola Mobility RAZR V3
Sim card not working with my ic 902 phone.
try to reformat the sim before inserting it in phone. also make shure to not exceed sim memory size or speed.
May 04, 2009 | Motorola Mobility ic902 Cellular Phone
Were is the slim card
Do you mean where is a SIM card?
If you have a Motorola V3 razr you will remove the battery door, There you will find the battery and just beneath it off centered to the right, you will find the SIM card. The battery needs to be removed in order to safely remove or insert the SIM card.
Jan 14, 2009 | Motorola Mobility RAZR V3
Sim
take it to motorola's service center they will help u for that and can not give u any idea before seeing ur phone but they will solve ur problem
Jun 06, 2008 | Motorola Mobility L6 Cellular Phone
Bought motorola v235 cell phone from e bay, put sims card in and turned it on it say insert sims card and there is a yellow circle with an exclamination point and also a blue dot on the top right side.e...
I cut out a piece of plastic about the same thickness as the sim card and cut out a duplicate of the sims card and inserted it in the phone and it worked,evidentaly the new sims card cellular one sent us was a little bit thinner than the old one .and was making contact. problem resolved, cellular one let us hang without helping us ,they wanted us to join at&t on a new plan,not as good as the old plan we can keep now, since at&t does not support old cellular one phones.and this v235 phone works just perfect.
Apr 17, 2008 | Cell Phones
Phone doesn't recognize the SIM card
The sim card holder has a tiny slide mechanism. After inserting the sim card and pressing it against the body of the phone, place your finger over the card and slide it gently forward. The tiny plastic part that holds the card will snap it into place. Hard to explain, but it will work.
Dec 17, 2007 | Motorola Mobility V66 Cellular Phone
NET WORK PIN
We have the exact same problem and our SIM card starts with 8931. Do you think it will work for us??
Dec 14, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3m Cellular Phone Logo
82 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
