Question about Dryers
Maytag Dryer #MDE4000AYW
Set timer push start nothing happens,
Have power,lightworks
  • Jerry Kerns Sep 18, 2008
    Thank You!!
  • gr8_sk8r Apr 11, 2009
    Dryer motor does not engage
    Neptune Intellidry dryer.
    There are two lights that turn on when the
    start button is pushed. They come on for some of the dial settings. But even
    when they do, the motor does not engage and the lights do not stay on. Where do
    I start looking. I am electrical literate.
    Was working just fine and
    after last load, nothing.
    I just went back in and tried to restart it and it kicked on. Is there a thermal circuit built into the machine?
  • Dryers Master
  • 19,396 Answers
Try first unplugging power cord from the appliance, this will drain power from circuits and reset it.
Check the door latch sensor, if that is stuck the door sensor will not let the machine start.
Keep pressed start button for 10 seconds or so, on some dryer this reset the machine.
If it still does not work then there is an internal fault , probably the timer assembly must be replaced.
If you need to call a technician you can use the number listed on the owner manual.
If you want to do it yourself, test the timer control, then if it is faulty replace it.
You find replacement here.
Posted on Sep 18, 2008
Dryer has power to timer, but won't start...I have an Amana electric dryer that allows me to set the timer and I can hear it running, but when I push in the the timer knob to start the dryer (drum
The fuse is mounted on the heater element. When it blows nothing in the heater or motor circuit works but the power to the timer is not interrupted therefore you can hear. Service manual
Feb 11, 2013 | Amana Dryers
The dryer model # PYE3300AYW The dryer has power but will not turn on when the timer/start knob is pushed. You can hear the timer ticking, but nothing else happens. What are the possible causes for this?...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Apr 20, 2011 | Maytag Dryers
Maytag mde4000ayw won't start. moisture monitor
This is either your start switch or your motor that is bad. I would suggest you begin with the start switch. We love Maytag appliances and we also love the moisture monitor on this model of dryer.
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service and we will get the correct switch out to you asap.
We look forward to working with you and hope to get you back to drying right away.
Happy Holidays to you!
Ella
Nov 12, 2009 | Maytag Neptune MDE4000 Electric Dryer
You need to do a continuity check on the dryer cord. Also manually reset the breakers and make sure you have power (both legs). After this and you still have trouble, do a continuity test on the door switch. The door switch will keep a dryer from operating. After that, you will need to check that your motor is being called to come on. Also check the capacitor and that it is reading the correct microfarad's with in 5%.
Apr 11, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Mar 25, 2009 | Dryers
Batch complete sounds when start button is pushed
door switch or timmer or the knob on the timer may not be turning the timer
Nov 27, 2008 | Maytag PYE2300AY Electric Dryer
Dryer won't start
does it have drum light ?if so is it working ?if not and bulb is good raise top by pressing clips at each corner on back is heating element.. on element case is thermal fuse with 2 white wires it could be open part# la-1053 ( i think)..if light is on but still no operation possible timer or door switch
Sep 18, 2008 | Dryers
Maytag Dryer
are you sure the door is completely close?
if the door is not closing the door switch, nothing will happen when you press the start button.
drcool
Sep 17, 2008 | Dryers
Dryers Logo
384 people viewed this question
Top Dryers Experts
