Question about Coleman Powermate Premium Plus 6250W Portable Generator
Coleman powermate 6250 mod# PM0525303
Moter runs fine but no electricity
  • Anonymous Sep 19, 2008
    SAME PROBLEM AS CJANDGWEN'S
  • Anonymous Mar 25, 2014
    how to check the stator coil
I had the same problem on my Powermate 525500 (5500 watt) and finally manage to get in contact w/Powermate (PRAMAC) tech support. He told me that if the gen is setup for a while, the exciter loses it's magnatism. To reenergize ( jumpstart) as he called it, follow the prcedure below. Probably not for amatures.
1. start up the generator.
2. Pull off the brush cover on the end of the gen.
3. Get a 6-12 volt battery and setup w/color coated cables.
4. place the negative lead on the left side brush terminal and tap the right side brush terminal w/ the positive lead.
5. Wala....you sould have power.
One would think that this important info would be on the manual or a blog somewhere.
Good luck and have a wonderful day.
The Texajun
Posted on Sep 20, 2008
    Problem Solver:
  • 18 Answers
The most common problem is the capacitors blowing. This is the round (usually white in colour) barrell shaped device usually found in the end cap of the alternator. It will have two wires attatched to two of four pins. I would advise that you check the voltage at the end of the alternator first to eliminate a wiring problem. The capacitor can only be tested with the correct equipment but changing it should solve your problem- 75% sure.
Posted on Sep 18, 2008
I purchased my Coleman 7500W generator about ten years ago as an emergency power source. Went to use it after our mini-hurricane here in Cincy took out the power. Finally got the engine running after replacing the dead battery, but it still wouldn't generate electricity. Thanks for the posted solutions! The one about the capacitor pointed me in the right direction. On mine, it's on the bottom of the unit. Removing the four long bolts that hold together the housing for the motor windings, brushes, bearings, etc, I found the capacitor (about an inch diameter and two inches long). One of the wires had come into contact with the rotating shaft, which wore through it and opened the circuit. Reconnected it, put it back together, started it up, plugged in an electrical device, and the thing worked!!! . . . Did the happy dance and went inside for a Miller! Too bad all this occurred AFTER only after lotsa spoiled food, due to almost a week of no power, during which I could find no one to work on the generator in the Cincy area. Well, it's fixed now! Bring on the wind now. I'm ready.
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers · I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
Power mate 6250. Starts and runs fine until I take the choke off, then why does it die?
Coleman engine starts runs short time quits Power ... - Fixya
www.fixya.com > ... > Power Generators
Coleman Powermate 6250 only runs with choke closed/air restricted ...starts and runswith full choke, but dies with choke off. ... some gas in the cilinder through the plug hole)and start the engine until it runs constantly. bestregards ... Ad ... I use a fuel stabilizer ... ...engine runs fine but produces no power at all to the breaker.
Coleman car starts but will not stay running Power ... - Fixya
Question about Powermate Premium Plus 6250W Portable Generator ... squirt a little gas in the carb it will run until gas is gone doesnt seem to get gas from . ... ...starts and runs fine for about a minute, then dies as though starved for fuel. ... load up on fullchoke and stay running around 3/4 choke HI, Turn off the gas and take ...
Generator runs then shuts off - YouTube
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Remove all; Disconnect .... My ...
Jan 13, 2016 | Coleman Electrical Supplies
How do i excite my 6250 powermate and where can i buy parts. Runs great but no power at all. Thanks John
One quick way to "excite" the field is to plug an electric drill into the outlet of the running generator. Engage the trigger on your drill and spin the chuck backwards. DO NOT HAVE YOUR FINGERS WRAPPED AROUND THE CHUCK WHEN DOING THIS. IF IT WORKS (not 100%) THE DRILL WILL START UP!!! Coleman was bought out by Pramac, you can find there webpage here.
Hope this helps.
Feb 22, 2011 | Coleman Powermate Premium Plus 6250W...
My coleman powermate 6250 generator just stopped producing electricity. It was running all day. Motor still runs just no juice.
check the reset-- if power to reset line, switch bad if no power -check feed out from generator if no out put then possible internal problem --winding or short
Mar 02, 2010 | Coleman Powermate Premium Plus 6250W...
Coleman 6250 ,no power generated
check your AVR card...if the brushes are fine...
Aug 16, 2009 | Coleman Powermate Premium Plus 6250W...
Misplaced User Manual for Coleman Powermate 6250
I would run a search on line for your model number. I will look and let you know.
Feb 02, 2009 | Coleman Powermate Premium Plus 6250W...
Need to know about this generator. Coleman Powermate 6250 Gen power 305 5000 running watts Model PM0545008 Serial # E06601199B
To find a manual for this generator go to powermate.com and search your model and serial number. Good luck!
Dec 05, 2008 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
1,150 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Rivera
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
