Question about Kenwood KAC-7202 Car Audio Amplifier
Amplifier cuts out sound and then turns back on then couple of more seconds the amp. cuts back out
  • 631 Answers
There could be several problems. The following page should help you determine if you have a problem with the amp or something connected to the amp.
Amplifier in Protection Mode - Troubleshooting
Let me know if you have any other questions.
Posted on Sep 18, 2008
When i turned the bass up to high on my head unit my amp cuts out on overprotection, just for a second and them comes back on. why?
go into your settings in the deck by holding down the volume on most models for 10 seconds then change your hpf settings and your lpf settings your bass will sound much better and not cut out. hpf recommended 160......lpf recommended 140.... good luck
Jun 03, 2010 | Car Audio & Video
Technics amplifier su-v98, cuts off at 22-24 desibls
The most common cause of this is defective coupling caps inside. These allow some DC voltage to pass through to the final amp stage. This DDC voltage is detected by the protection circuit and the unit shuts down. This unit will require service. Please note that this should be a simple and inexpensive repair. The cost should be less than $10 for parts.
Dan
Jul 04, 2009 | Technics SUV500 2-Channel Amplifier
Pioneer GM-7200M power problem
Check your GROUND wire might be touching something and making bad contact.
Jun 09, 2009 | Pioneer GM-7200M Car Audio Amplifier
No sounds coming out of subwoofers
CHECK INSIDE UR SUBWOOFER BOX ...
Apr 11, 2009 | Pyle PLAM2300 Car Amp
Sonamp 260 cuts out
Normally this denotes a protect condition. Remove the speaker wires from the back of the amp and see if the green light stays on. If this fixes the problem, then there is a short circuit in your wires, speaker level volume control or speakers. The amp sees the short and goes into protect. After a couple seconds it closes the connection again and if the short is still present it goes back into protect.
Aug 03, 2008 | Sonance Sonamp 260 MKII 2-Channel...
Amplifier power cutting out
not enough power to amp and or amps location is too hot might want to invest in a couple cooling fans from computer store and attach where needed
an amp should take up to 3/4 load but when not enough air to it to cool it off it will shut down
try this turn gain all the way down and slowly work up too desired amp volume setting
May 07, 2008 | Audio Players & Recorders
Amp cuts out when turned up
that amp cutting out like that means that its probably shot and it time to start looking for a new one
Apr 09, 2008 | Directed D800 Car Audio Amplifier
Sherwood Amplfier
Sounds like you like your music like me... LOUD. If you've done this a number of times, there are a few things that can happen:
1. You've blown the speakers... but you've said it operates for 2 seconds, then cuts out.
2. You've damaged the amplifier modules within the amp and they immediately overheat upon power-up. Does the music come back like 5 or 10 seconds after the unit cuts out?
3. Thermal switch has malfunctioned and just cuts off the power to the amplifier modules as soon as it sees any heat.
4. If you've gotten the amp really HOT during playing, it's possible that it's as simple as the amp modules are only intermittently connected (fatigued/stressed or cold solder joints) at the on the PCB. Just resolder the connections of the amp module to the PCB. I've seen that happen numerous times and that's where I'd place my money.
Jan 02, 2008 | Audio Players & Recorders
Plz Help - unknow problem
Sounds like a short circut protection on the amp kicking in. It sences the power going to the drivers and cuts itself out before damage is inflicted on the subs.
Mar 18, 2007 | Kenwood KAC-7252 Car Audio Amplifier
High volume cut out
power amplifier circuitry problem,you need a qualified serviceman.
Oct 04, 2006 | Sony STR-DE595 5-Channel Amplifier
Kenwood KAC-7202 Car Audio Amplifier Logo
156 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
