Acer ScanPremio 1220ST Flatbed Scanner Logo
Andrew Hess Posted on Sep 22, 2011
Getting Acer ScanPrimo ST 1220ST to work with Windows 7 and a PCI host adapter with an LSI20329IE Ultra 320 using a VHDCI 68 PIN TO CENTRONICS 50 PIN (CN50) CABLE
  • 2 more comments
  • Andrew Hess Sep 23, 2011
    This is an older scanner that can also scan negatives and
    transparencies up to 8x10 and is an inexpensive alternative to a newer model.
    It uses the old Centronic SCSI type connection but can be made to work with Windows 7 and LSI PCI host adapter LSI20329IE Ultra 320 using a VHDCI 68 PIN TO CENTRONICS 50 PIN
    (CN50) CABLE. I had trouble getting the new host adapter to see the scanner. I
    purchased a new 6 foot cable and it seems to connect more reliably. I have now
    purchased a third cable with internal High Byte termination to see if this
    cable improves Windows' ability to recognize the scanner further. During my
    testing I purchased a third party driver called VueScan to replace the old MiraScan
    driver that came with the scanner. The VueScan install seemed to cause both
    drivers to work properly under Windows 7 - go figure?
    This is an older scanner that can also scan negatives and transparencies up to 8x10 and is an inexpensive alternative to a newer model. It uses the old Centronic SCSI type connection but can be made to work with Windows 7 and LSI PCI host adapter LSI20329IE Ultra 320 using a VHDCI 68 PIN TO CENTRONICS 50 PIN (CN50) CABLE. I had trouble getting the new host adapter to see the scanner. I purchased a new 6 foot cable and it seems to connect more reliably. I have now purchased a third cable with internal High Byte termination to see if this cable improves Windows' ability to recognize the scanner further. During my testing I purchased a third party driver called VueScan to replace the old MiraScan driver that came with the scanner. The VueScan install seemed to cause both drivers to work properly under Windows 7 - go figure?
  • Andrew Hess Dec 10, 2012
    If you have the
    scanner attached through an SCSI card and Windows 7 does not reliably see the
    scanner here is the fix:
    Download Devcon.exe from Microsoft, a command line device
    utility.
    From the command prompt utility run Devcon.exe with the "rescan"
    argument listing the fill path to the command where Devcon.exe is installed on
    your machine.
    For example:
    C:\Users\Andrew\AppData\Local\Temp\i386\Devcon rescan
    As an alternative the command can be pated as above into a
    shortcut on your Windows 7 desktop and initiated at any time causing the system
    to find the scanner.
    You can also consider creating a batch command file that
    includes the driver to initiate the finding of the scanner and the opening of
    the scanning utility in one action.
    You can test the function of this fix by looking to see if
    the scanner shows up in the device list in the Control Panel's Device manager,
    deleting the device and running the Devcon utility to reinstall it.
    If you have the scanner attached through an SCSI card and Windows 7 does not reliably see the scanner here is the fix:
    Download Devcon.exe from Microsoft, a command line device utility.
    From the command prompt utility run Devcon.exe with the "rescan" argument listing the fill path to the command where Devcon.exe is installed on your machine.
    For example:
    As an alternative the command can be pated as above into a shortcut on your Windows 7 desktop and initiated at any time causing the system to find the scanner.
    You can also consider creating a batch command file that includes the driver to initiate the finding of the scanner and the opening of the scanning utility in one action.
    You can test the function of this fix by looking to see if the scanner shows up in the device list in the Control Panel's Device manager, deleting the device and running the Devcon utility to reinstall it.
  • Andrew Hess Aug 11, 2014
    Update: I found that if I turn the Windows 7 computer on then open control panel/device manager then turn thte scanner on and while it is going through its startup sequence right clic in device manager and select scan for new devices Windows finds the scanner every time.
  • Andrew Hess Dec 17, 2017
    Update 12/17/2017 the original posting procedure works for Windows 10 as well.
Andrew Hess
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 22, 2014
Andrew Hess
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
119
Points
Acer ScanPrimo ST 1220ST to work with Windows 7 and a PCI host adapter works just fine I use it every day. The key is to use a third party scanner software called Vue Scan 9.0.57 and using the following start-up procedure so Windows 7 can find the scanner on the SCSI controller. First open windows device manager, then turn on scanner, immediately right mouse click in device manager and select scan for new devices. Windows 7 will immediately find the scanner. It seems that windows will only see the scanner through the SCSI interface during the scanners startup sequence. It has been a while but I believe this works with Mira Scan V4.03 as well.
Testimonial: "Update: 12/17/2017 The above also works for Windows 10."
1 Related Answer
Anonymous
  • 4 Answers
  • Posted on Mar 05, 2011
SOURCE: Problem with the Acer AcerScan Prisa 340P Flatbed
BenQ has not (and never will) write drivers for Windows 7. The scanner technology does not allow a parallel port scanner to work in Windows 7.
2helpful
2answers
Acer Extensa5620z originally had Vista, I wiped the hard drive and installed W7. Its not as simple as I thought. Now I need to update drivers and Acer.com doesn't have anything listed. In the det
Windows 7 should automatically install device drivers for the Audio, Video and Network, If you are unable to find/download a device driver that works on your computer and your computer is connected to the Internet then - 1. Remove the driver that isn't working if it was installed.
2. Set Win-7 "Windows Device Installation" to 'AUTO'
3. Windows will automatically search the internet for the driver.
4. Reboot your computer.
Enter natexpolar
As per your question, you are facing problems with the Sony 2 Bays 68-Pin SCSI3 External Drive Case, you can try with checking all it's cables and power connectors. If the problem still exists you can visit this web page for more help and support :
http://www.bixnet.com/2bayscsi3enc.html.
1helpful
Silicon Image Ultra-133 Medley ATA (Maxtor Ultra ATA/133 PCI Card
No I do not think there is unfortunaely. Contact Maxtor and ask if they are going to support it under Windows 7?
Not getting data cable
This drive is a SCSI hard drive. 9.1 GB SCSI ULTRA 2 68 PIN.
It needs a 68 pin Ultra-2 SCSI cable.
SCSI Inquiry Command Failure w/Tandberg TDC 4120 tape drive
Try putting the tape drive on the last scsi termination point.
Hi tried that... sound card is connected and vm-ware tools is also installed... its surely a problem with the windows 2003 server. because the error sound is played through the macbook speakers but not any...
see heres the thing when using VM-Ware, VM-Ware doesnt use drivers for your physical hardware, because it emulates the hardware that is seen in the hardware information of your system preferences.
So installing even drivers for the "emulated" hardware will not work, as VM-Ware uses its own drivers for the hardware, which are included with the VM-Ware Tools, if that doesnt seem to work, you may want to contact VM-Ware support, as they may have a better solutiuon.
AWARd pci/pnp 68
DOWNLOAD THIS BOOK FOR FREE AND SOLVE ANY PC HARDWARE, SOFTWARE OR OPERATING SYSTEM PROBLEMS.
DOWNLOAD NOW......
Download mirror 1 ( Hosted by HostingDude)
Download mirror 2 ( Hosted by Softpedia )
Download mirror 3 ( Hosted by Soft32 )
Download mirror 4 ( Hosted by fileflyer )
Download mirror 5 ( Hosted by Rapid Share
379
Top Acer Office Equipment & Supplies Experts
SmartAviator
SmartAviator
k24674
ADMIN Andrew
ADMIN Andrew
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
