Question about Toshiba Satellite A100-S8111TD Notebook
EToshiba Satellite A100-S8111TD - Laptop do not finish boot on startup
I donot get pass toshihia sign at bootup
  • fred nelly Sep 19, 2008
    hello! xtnf
    i tryed what you told me.the screen i get is in `touch tomorrowtoshiba please wait. now computer will not cutoff went i push qff buttion
    fnelly
    Scholar:
  • 135 Answers
Upon powering on, press the F8 button to load other options, choose safe mode only and hit enter.
If you were able boot windows under safe mode, you can try to do system restore or uninstall any program you've recently installed which cased the problem.
If you were NOT able to boot to safe mode, you need to do full system recovery and re install the OS. Insert the recovery disc and press F12 upon powering on to load boot menu then choose CD/DVD rom.
Hope this helps,
Posted on Sep 18, 2008
  • Christian Fernandez Sep 20, 2008
    Hi fnelly.
    Remove the battery and the AC adapter. Let the unit rest for about a minute. Then plug only the AC adapter. do not put yet the battery. Then try to power on again the unit. See if you can pass the toshiba splash screen. If not, do this:
    Shutdown unit, Press and hold the F8 then power it on and still hold that F8 button down. It should give you advanced options screen and try to boot to safe mode.
    If still nothing happens. shut down unit and this time hold down F12 while powering it up. It should lead you to Boot menu. Check if you can see HDD, If you can see HDD, you need to do full system recovery like what I mentioned on the previoous post. But if you can't see the HDD on the list, the issue is with your Hard drive, your system board could not detect it that's why you're stuck at the toshiba splash screen.
    Or you may be on the Toshiba splash screen where you can see icons down below that you can select. Icons should be like a circle that looks like a disc(this is the CD/DVD rom), another one is 3 circle plates on top of each other (this is the HDD), others would be like a stick (this is the USB).  If your on this screen, insert your recovery disc and choose the single circle (CD/DVD rom) then press enter. It should lead you to recovery options.
    Hope this helps.
My laptop can't id a partition so no startup
Try this: boot to your CD that has the Operating System on it. re-install Windows
May 16, 2010 | Toshiba Satellite A100-S8111TD Notebook
Have a toshiba satetllite laptop and i have error code 0xc000000f but was not givin a recovery cd and the old press f9 is not working. any ideas?
try going into safe mode with command line utility enabled. (F8 on bootup). in command console type chkdsk /f /r and enter y for yes at the prompt. wait for it to finish, it may take a while. If that doesn't solve it try typing fixmbr. If that doesn't work, manually load the os to boot from cd-rom. tap F1 while rebooting. in the BIOS go to boot options. in boot options change first boot device to cd. put the cd in the tray, save and exit your settings. The comp will boot from the windows disk. follow the prompts.
May 04, 2010 | Toshiba Satellite A100-S8111TD Notebook
My toshiba satellite laptop gos into a password when you boot it
The password to turn the computer on and start working on it?
or what kind of password are you talking about?
Apr 23, 2010 | Toshiba Satellite A100-S8111TD Notebook
Sg ram wanted for toshiba lap top 256mbs
Here are some links that could help you:
http://www.crucial.com/uk/upgrade/compatible-memory-for/Toshiba/Satellite+A100-S8111TD+(Intel+Core+Solo%2FDuo+Processors)/list.html
http://www.memoryupgrade.pro/toshiba-laptop-notebook-so-dimm-ram-satellite-satellite-a100-s8111td.html
I hope that will help you.
Mar 28, 2010 | Toshiba Satellite A100-S8111TD Notebook
Reset toshiba satellite A100-TA2 to factory settings
try this link, at appears as if u can download the disks here
http://www.user-guides.co.uk/toshiba/toshibarecovery/toshiba.asp?keywords=toshiba+satellite+a100+ta2+recovery+discs+downloads&recor=121
Mar 18, 2010 | Toshiba Satellite A100-S8111TD Notebook
Power issues in toshiba s1800-911
Sounds like you have a problem with your power adapter, battery and or charge port ... I would suggest you let the unit "charge" overnight and try again.
Dec 22, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite M100 Laptop fails to boot
trying holding the F8 key and they may give you a recovery option which could be the only way you can get your system up and running
Dec 07, 2008 | Toshiba Satellite A100-S8111TD Notebook
Boot up problem continues
Looks like you will have to replace RAM modules.
May 15, 2008 | Toshiba Satellite A100-S2311TD Notebook
Toshiba laptop will not startup
Do you mean won't power up or won't boot up?
Jan 06, 2008 | Toshiba Satellite A100-S8111TD Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
123 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
